Battery & Charger
Sold Separately
TRX-6 Flatbed Hauler w/Winch
Name:
TRX-6 Ultimate RC Hauler
Type:
Trail / Crawler
Skill Level:
1
1/10
10.7 pounds (4.83 kg)
37.5 inches (953 mm)
9.8 inches (249 mm)
Front Track:
9.8 inches (249 mm)
Rear Track:
9.8 inches (249 mm)
11.9 inches (303 mm)
23.7 inches (603 mm)
Center Ground Clearance:
3.14 inches (80 mm)
Driveline:
Shaft-driven 6WD
Transmission:
2-speed high/low, remote shifting
4-gear, remote locking
32 pitch
Steering Servo:
2075X metal gear, digital high-torque waterproof
TQi™ 2.4 GHz 4-channel transmitter with 6533 receiver
Battery Compartment Specs:
159 mm X 47 mm X 23/26 mm
Name:
Titan® 550 21T Reverse Rotation
Motor Type:
High-torque brushed motor
8.47 ounces (240 g)
Diameter:
1.53 inches (39 mm)
Shaft Size:
3 mm
Connector Type:
Bullet
Name:
XL-5™ HV
ESC Type:
Brushed
Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 1.04 inches (26 mm)
2.6 ounces (74 g)
Motor Connectors:
Bullet
Battery Connectors:
Power Wire:
14 gauge
Large-Scale RC Hauler Rig Body
Molded black chrome scale details
Fuel tanks, tool boxes, side rails, unique bumpers
Molded side mirrors and roll bar
Authentic decals
Full Nylon composite wheel wells
Detailed multi-piece hauler bed with adjustable wheel chocks
Installed LED Light Kit
Molded headlights with amber marker lights
Clearance and marker lights on roof, roll bar, and hauler bed
Tail lights integrated into rear bumper
Sealed waterproof design
25 individual LED lights
Regulated voltage for consistent and reliable power output
Pro Scale® Winch
Detailed scale appearance
Rugged waterproof design
10-pound towing capacity
Included 2-channel remote
Trail-tuned XL-5™ HV Waterproof Electronic Speed Control
Fully waterproof design
Five drive profiles
Sport Mode — forward / brake / reverse
Race Mode — forward / brake / no reverse
Training Mode™ - 50% forward / 100% brake / 50% reverse (patented)
Trail Mode — forward / brake / reverse / with trail-tuned drag brake in neutral
Crawl Mode — forward / instant reverse - no neutral with 100% hill holding brake
Large, efficient heat sink
Wide voltage latitude 6–7 cell NiMH (7.2–8.4 V) and 2–3S LiPo (7.4–11.1 V)
Two stage low voltage protection (LVD)
Titan® 550 Motor
Powerful Titan 21T reverse rotation motor with internal cooling fan
Precise, preset gear mesh adjustments
Motor retention separate from gear mesh
TQi™ 2.4 GHz Radio System
Compatible with Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately)
Automatically stores and loads settings for up to 30 Traxxas Link enabled models
Exclusive Cruise Control feature for extended trail driving
Adjustable steering and throttle endpoints
Patented waterproof receiver box with easy-access plug
Extended Chassis Design
Full-length 30″ steel frame rails
1.5 mm thick for increased torsional rigidity
Rails run from bumper to bumper
Extended wheelbase for full length tow bed
Bearing-supported intermediate driveshaft
Wire management clips integrated into frame rails
Drivetrain
Full-time shaft driven 6-wheel drive
Tough 6 mm stub axles
Steel front CV driveshafts
Hardened steel rear axle shafts
Remote locking steel gear differentials with cable-actuation
Steel gear transfer case
Portal Axles
Increase ground clearance
Eliminate torque twist
Steel gears
Improve axle geometry and reduce strain on driveshafts
Transmission
Two speed high/low range with remote shifting
Dual horizontal shafts
Twin friction plate slipper clutch
Easily removed for servicing
Steering
Chassis mounted 2075X metal gear digital servo
Superior 45° steering angle
Steering geometry corrected for bump steer
Suspension
Front — 3 link with panhard
Rear — Dual triangulated 4 link
Heavy-duty rod ends with steel hollow balls
5 mm diameter lower steel link rods with 4 mm threaded ends
Aluminum GTS Shocks
Oil-filled coilover GTS shocks
Silver-anodized aluminum bodies
Threaded bodies with collars easily adjust ride height
Silky smooth damping for the toughest trails
O-ring cap seal and dual X-ring shaft seals
Wheels and Tires
2.2″ black chrome big rig wheels with hub inserts
2.2″ Canyon RT all-terrain tires with foam inserts
Sticky S1 rubber compound
12 mm steel hex
Sealed Ball Bearings
Hex hardware with rust-resistant black oxide coating
Patented O-ring sealed watertight receiver box keeps the micro receiver dry
MODEL 88086-84 : TRX-6® Ultimate RC Hauler: 1/10 scale 6WD electric flatbed truck, Ready-To-Explore® , with TQi™ Traxxas Link™ enabled 2.4 GHz radio system, XL-5™ HV ESC (fwd/rev), Titan® 550 motor, and Pro Scale® winch.
What’s In The Box:
TRX-6 Ultimate RC Hauler XL-5 HV waterproof electronic speed control Titan 21T reverse rotation motor TQi 2.4 GHz radio system with cruise control High quality maintenance tools
What You’ll Need:
Batteries
TRX-6 accepts a wide variety of NiMH (6–7 cell) and LiPo (2s–3s) batteries.
Charger
AA Alkaline Batteries
ULTIMATE RC HAULER
Based on the hugely capable TRX-6® platform, the TRX-6 Ultimate RC Hauler is the biggest, baddest rig in the TRX lineup. The rear bed features adjustable wheel chocks and tie-down bands to haul and display 4-Tec® models with style. A highly detailed LED lighting system and black-over-black chrome body accessories give the Hauler a tough, menacing look. The Ultimate RC Hauler is built Traxxas Tough™ with portal axles, high/low transmission, and T-Lock™ remote locking differentials. When you’re ready for big-scale RC fun, nothing comes close to the Traxxas Ultimate RC Hauler.
BUILT TO HAUL
The Ultimate RC Hauler is the largest TRX-6 model with an extra long 23.7" (603 mm) wheelbase and oversize bed to haul your 4-Tec models in style. The highly detailed truck features deep gloss black paint over molded black chrome body accessories for an intimidating look to match its big rig attitude.
DETAILED BED AND LIGHTS
Adjustable wheel chocks with tie-down bands on the Ultimate Hauler’s tow bed accommodate any 4-Tec 2.0 or 3.0 model and keep precious cargo secure. A powerful and true-to-scale LED lighting system with 25 individual lights makes twilight adventures a reality.
TRX-6 CAPABILITY
Built on the supremely capable TRX-6 platform, the Ultimate RC Hauler uses six drive wheels to get into the action with trail-conquering grip of three remote-locking T-Lock™ differentials to get back out. A remote-shifting high/low range transmission amplifies the motor’s torque down low to move heavy loads while still providing ample cruising speed when unloaded.
FACTORY-INSTALLED PRO SCALE WINCH
The Ultimate RC Hauler now includes a Traxxas Pro Scale® Winch standard, raising the scale realism to a new level. Utilize the winch to pull and secure your 4-Tec models onto the Hauler's detailed bed with the included remote. The winch is pre-wired and ready to go out of the box.
Innovation
The Ultimate RC Hauler combines proven TRX-6 technology with detailed scale elements to create a whole new way to enjoy the RC experience.
Scale Details
The Ultimate RC Hauler checks all the boxes with molded side mirrors, unique bumpers, gas tanks, and big rig wheels. LED lighting on the cab and tow bed score extra detail points whether you’re cruising unloaded or carrying your prized 4-Tec® .
Extended Length Steel Chassis
The RC Hauler maintains its rigid structure by using single-piece frame rails from bumper to bumper. Each frame rail is over 30" long and reinforced at multiple points for maximum strength.
Realistic Tow Truck Bed
The Hauler’s tow bed features full-length side rails and adjustable wheel chocks with tie-down bands to accommodate the different wheelbases of all 4-Tec 2.0 or 3.0 models. For a new level of realism, the Hauler now features a factory-installed Pro Scale® Winch to pull your car into position. (Learn more)
Detailed Big Rig Style Wheels
Deep-dish black chrome wheels are styled to look just like real thing with unique front and rear designs. Replica 10-lug caps conceal the wheel lugs for a perfect scale appearance.
T-Lock Remote Locking Differentials
Leave the Hauler’s differentials unlocked to get in and out of tight spaces. When venturing off-road, flip the rocker switch on the transmitter to lock just the front differential or lock all three differentials for extreme 6-wheel-drive traction. Sleeved micro cables control the differential action for reliable performance in all conditions.
High/Low Range Transmission
Low range gearing provides plenty of torque for climbing the steepest grades, even when fully loaded. When the road opens up, shift into high range and the big rig makes quick work of even the longest hauls.
The Power Of Portals
Portal axles lift the truck at the wheels for huge center pumpkin ground clearance. In order to achieve the same clearance with straight axles, your tires would have to be over an inch taller than the tires on the TRX-6.
Torque Twist Eliminated
Portal axles use gear reduction at the wheels to virtually eliminate torque twist. That’s especially important with longer vehicles like the RC Hauler. Rather than wasting energy flexing the chassis, the Titan motor’s torque translates into powerful forward motion.
GTS Aluminum Shocks
Six oil-filled coil-over GTS shocks deliver silky-smooth damping performance and a smooth ride for your cargo. Threaded aluminum shock bodies allow for easy ride height adjustment to compensate for loaded and unloaded configurations.
3s Power System
The XL-5™ HV electronic speed control brings 3s LiPo capability for strong efficient running. The powerful 21T Titan® motor provides torque for hauling heavy loads and climbing steep grades. This efficient system provides exceptional run time with a Traxxas 3s 5000 mAh LiPo battery pack!
TQi Radio System With Cruise Control
The Traxxas TQi™ features our exclusive cruise control to make long-distance hauls a breeze. Set your speed using the transmitter and then use the multi-function knob to fine-tune it faster or slower. Add a 6511 Traxxas Link Wireless Module (sold separately) to enhance your driving experience with real-time telemetry capability, inclinometer gauges, and more!
Waterproof Electronics
The TRX-6 is fully waterproof, not “splash resistant.” There is a big difference. Traxxas’ patented innovation gives you the freedom to haul your cargo through water, snow, and mud without worrying about your electronics.
Details
Detailed Truck Body
The Ultimate RC Hauler transports your 4-Tec in style with scale looks to match its rugged performance. Whether you’re cruising down the road or blazing an off-road trail, the RC Hauler gets there in style.
Real Hauling Capability
Load up the full range of 4-Tec 2.0 or 3.0 models with RC Hauler's unique full-length bed with adjustable wheel chocks. Transport your GR Supra GT4 to race events or display your Corvette Stingray with show-stopping style.
Factory-Installed Pro Scale Winch
The Ultimate RC Hauler includes the Pro Scale Winch. This extra dose of scale realism is fully functional with an included remote to help pull cars onto the realistic tow truck bed.
One-Piece Steel Frame Rails
The key to the RC Hauler’s robust chassis are its one-piece frame rails. At over 30? long, these strong steel rails run from bumper to bumper for class-leading strength and maximum torsional rigidity.
Factory-Installed LED Lighting
With 25 separate LEDs and a regulated power supply, the Ultimate RC Hauler sets a new standard for scale lighting. Bright white headlights, marker and clearance lights, and a full array of red tail lights track your progress.
T-Lock Differentials
Traxxas gives you the freedom and versatility to lock and unlock both the front and rear differentials remotely from your transmitter. With its differentials unlocked, the RC Hauler defies its length with a tight turning radius and easy maneuverability. When heading off-road, lock just the front or lock the front and both rear axles for superior pull and grip over any terrain.
4.6 x 2.2" Canyon RT Tires
Large 2.2" big rig wheels come pre-glued to aggressive 4.6" Canyon RT tires. Deep tread blocks on the soft-compound tires flex to provide unparalleled grip on all types of terrain. A standard 12 mm hex provides compatibility across the full line of TRX-4 wheels and tires.
Detailed Tow Truck Bed
The realistic tow bed features adjustable wheel chocks with tie-down bands to secure your 4-Tec for transport. Full-length bed rails and functional LED lighting provide an extra layer of scale detail to the Hauler.
Realistic Black Chrome Details
Molded black chrome body accessories give the Ultimate RC Hauler an aggressive look on the trail or the road. Detailed fuel tanks, tool boxes, big rig wheels, and rugged scale bumpers pair with blacked out paint and windows for a sinister presence.
Extended 6X6 Driveline
The Ultimate RC Hauler uses the same style hardened steel U-joints and center driveshafts as all proven TRX-4 models. A new bearing-supported center carrier reinforces the intermediate shaft to maintain alignment throughout the extended wheelbase design.
High/Low 2-Speed Transmission
Big rigs utilize multi-gear transmissions to move heavy loads and climb steep grades. Use low gear to get your RC Hauler moving in rougher terrain, and then shift into high gear on the fly to make quick work of longer transits with the transmitter’s Cruise Control function.
Titan 21T Motor
Moving heavy loads requires massive torque, and the TRX-6’s proven Titan motor is tuned to get things underway smoothly. An integrated cooling fan keeps temperatures down for long hauls and more fun behind the wheel.
Portal Axles
Three independent portal axles lift the center pumpkins higher than standard axles for superior ground clearance. Their innovative design also improves axle geometry and reduces axle strain on the driveshafts. Steel internals provide trouble-free performance haul after haul.
GTS Aluminum Shocks
Six oil-filled coil-over GTS shocks smooth out bumpy roads for secure transport. These silver-anodized aluminum shocks deliver silky-smooth damping with threaded bodies for easy right height adjustment. They look great and perform even better with an O-ring cap seal and dual X-ring shaft seals.
Metal Gear Steering Servo
The Hauler’s metal gear digital servo and steel servo horn provide the durability and steering authority you need to confidently and reliably power through tough challenges.
