Battery & Charger
Sold Separately
TRX-4 Land Rover Defender
Name:
TRX-4® Land Rover® Defender®
Type:
Trail / Crawler
Skill Level:
1
1/10
7.43 pounds (3.37 kg)
23.07 inches (586 mm)
9.78 inches (249 mm)
Front Track:
Rear Track:
11.48 inches (292 mm)
12.75 inches (324 mm)
Center Ground Clearance:
3.14 inches (80 mm)
Driveline:
Shaft-driven 4WD
Transmission:
2-speed high/low, remote shifting
4 gear, remote locking
32 pitch
Steering Servo:
2075X metal gear, digital high-torque waterproof
TQi™ 2.4 GHz 4-channel transmitter with 6533 receiver
Battery Compartment Specs:
159 mm X 47 mm X 23 mm, 26 mm
Name:
Titan® 21T Reverse Rotation
Motor Type:
High-torque brushed motor
8.47 ounces (240 g)
Diameter:
1.53 inches (39 mm)
Shaft Size:
3 mm
Connector Type:
Bullet
Name:
XL-5™ HV
ESC Type:
Brushed
Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 1.04 inches (26 mm)
2.60 ounces (74 g)
Battery Connectors:
Bullet
Motor Connectors:
ESC Power Wire:
14 gauge
Clipless Officially Licensed Land Rover® Defender® Body
Injection molded scale details including grille, snorkel, and side mirrors
Rugged, functional roll cage
Tough fender flares
Front bumper with tow hooks and replica winch
Rear bumper with scale accessories and functional spare tire
Full Nylon composite wheel wells and floor pans
Quick and Easy Removal
Trail-tuned XL-5™ HV Waterproof Electronic Speed Control
Fully waterproof design
Five drive profiles
Sport Mode — forward / brake / reverse
Race Mode — forward / brake / no reverse
Training Mode™ - 50% forward / 100% brake / 50% reverse (patented)
Trail Mode — forward / brake / reverse / with trail-tuned drag brake in neutral
Crawl Mode — forward / instant reverse - no neutral with 100% hill holding brake
Large, efficient heat sink
Wide voltage latitude 6–7 cell NiMH (7.2–8.4 V) and 2–3s LiPo (7.4–11.1 V)
Two stage low voltage protection (LVD)
Titan® 550 Motor
Powerful Titan 21T reverse rotation motor with internal cooling fan
Precision, preset gear mesh adjustments
Motor retention separate from gear mesh
Portal Axles
Increase ground clearance (3.14″)
Eliminate torque twist
Steel gears
Improve axle geometry and reduce strain on driveshafts
TQi™ 2.4 GHz Radio System
Automatically stores and loads settings for up to 30 Traxxas Link enabled models
Exclusive Cruise Control feature for extended trail driving
Adjustable steering and throttle endpoints
Patented waterproof receiver box with easy-access plug
Rigid Steel Frame
1.5 mm thick steel frame rails increase torsional rigidity
Innovative design allows four wheelbase positions (300 mm, 312 mm, 324 mm, 336 mm)
Adjustable rear shock tower positions for SWB and LWB configurations
Bumpers adjust fore and aft
Rugged rock rails adjust for width
Wire routing clips integrated into frame rails
Innovative Battery Compartment
Hinged battery strap allows quick and easy battery access
No pins to lose
Accommodates different height batteries
Accepts full-size long battery packs
Integrated compartment accepts smaller 1/16 scale batteries (with optional strap)
Drivetrain
Full-time shaft driven 4-wheel drive
Tough 6 mm stub axles
Steel front CV driveshafts
Hardened steel rear axle shafts
Remote locking steel gear differentials with cable-actuation
Steel gear transfer case
Transmission
Two speed high/low range with remote shifting
Dual horizontal shafts
Twin friction plate slipper clutch
Easily removed for servicing
Steering
Chassis mounted 2075X metal gear digital servo
Superior 45° steering angle
Steering geometry corrected for bump steer
Suspension
Front — 3 link with panhard
Rear — Triangulated 4 link
Heavy-duty rod ends with steel hollow balls
5 mm diameter steel link rods with 4 mm threaded ends
Aluminum GTS Shocks
Oil-filled coilover GTS shocks
Silver-anodized aluminum bodies
Threaded bodies with collars easily adjust ride height
Silky smooth damping for the toughest trails
O-ring cap seal and dual X-ring shaft seals
Wheels and Tires
1.9″ Canyon Trail tires with trail-tuned foam inserts
Pre-glued and mounted to tough black scale wheels
Trail tuned S1 rubber compound
12 mm steel hex
Sealed Ball Bearings
Hex hardware with Rust-Resistant Black Oxide Coating
Requires Battery and Charger (Sold Separately)
MODEL 82256-4 : TRX-4® Land Rover® Defender® : 1/10 Scale and Trail® crawler, fully-assembled, waterproof, Ready-To-Explore® , with TQi™ 2.4 GHz radio system, XL-5™ HV electronic speed control, and clipless painted replica body.
What’s In The Box:
TRX-4 trail truck XL-5 HV waterproof electronic speed control Titan 21T reverse rotation motor TQi 2.4 GHz radio system with cruise control High quality maintenance tools
What You’ll Need:
Batteries
TRX-4 accepts a wide variety of NiMH (6–7 cell) and LiPo (2s–3s) batteries.
Charger
AA Alkaline Batteries
Take the Path Less Traveled
TRX-4® Land Rover® Defender® delivers innovation versatility, and capability to match its incredible scale looks. Underneath the rugged body TRX-4 Defender is built with extreme capability to take your off-road adventures to new heights. Portal axles deliver maximum ground clearance that turn “no way” into “no problem.” Whether you are enjoying outdoor trails or getting technical on the rocks, the remote-locking front and rear differentials and high/low range transmission provide unmatched driving versatility.
Scale and Trail® Crawler
Innovation
Radically innovative technology combines with precision engineering to create a breed of Scale and Trail® Crawler…Only from Traxxas.
The Power of Portals
Portal axles lift the truck at the wheels for huge center pumpkin ground clearance. In order to achieve the same clearance with straight axles, your tires would have to be over an inch taller than the tires on TRX-4.
Torque Twist Eliminated
The portal axles use gear reduction at the wheels to virtually eliminate torque twist. The Titan® 550 motor’s torque translates into straight, powerful, forward motion, rather than wasted energy twisting your rig right off the rocks.
All-New Chassis Design
TRX-4 instantly obsoletes the status quo with greatly expanded features, versatility, and capability. Performance and technology combine in a revolutionary new chassis that looks as good as it performs.
Rigid Steel Frame
A heavy-duty formed-steel ladder frame with molded cross members creates an extremely rigid backbone. You’ll feel the difference on trails when navigating technical terrain.
Scale Details
TRX-4 features a fully licensed and highly detailed Land Rover Defender body. Scale details abound from the detailed front grille and bumper to the functional spare tire in the back. Realistic lighting details, side mirrors, bumpers and even the included jack all add to the rugged and authentic appearance.
Remote Locking Differentials
Traxxas allows you to lock and unlock both the front and rear differentials remotely from your transmitter. New sleeved micro cables control the differential action for scale appearance, without limiting suspension articulation.
GTS Aluminum Shocks
Oil-filled coil-over GTS shocks deliver silky-smooth damping performance and feature threaded aluminum shock bodies for easy ride height adjustments. The convincing scale realism looks great and they perform even better.
High/Low Range Transmission
When the going gets tough, shift into low range for incredible 4WD pulling torque. Shift into high range for blasting down the trail. The TRX-4 Scale and Trail Crawler adapts to any situation or driving style.
3S Power System
The XL-5™ HV electronic speed control brings 3s LiPo capability for stronger, more efficient running. The powerful 21T Titan® motor provides torque to tackle the steepest climbs and all-out speed on flat terrain. This efficient system provides up to 2 hours of run time with a Traxxas 3s 5000 mAh LiPo battery pack!
TQi Radio System with Cruise Control
The Traxxas TQi™ features our exclusive cruise control for long-distance treks. Set your speed using the transmitter and then use the multi-function knob to fine-tune it faster or slower to match precisely the pace of your caravan of trail explorers.
Accessory Light Kits
Optional light kits illuminate the trail ahead and provide an authentic appearance. A separate regulated power supply ensures powerful lighting with consistent brightness.(All light kits and light kit accessories are sold separately.)
Waterproof Electronics
TRX-4 is fully waterproof, not “splash resistant.” There is a big difference. Traxxas’ patented innovation gives you the freedom to tackle creeks, snow, and mud without worrying about water in your electronics.
Heavy-Duty Steel Frame Rails
Adjustable Wheelbase
Molded Wire Retainers
Dual Battery Tray
Floor Pans
Aluminum Scale Shocks
Heavy-Duty Steel Links
Precision Hex Hardware
Portal Axles
Hardened Steel U-Joints
Twin Friction Plate Slipper Clutch
Raised Center Driveshafts and Suspension Links
High Steering and Drag Links
45° Steering Angle
Extreme Approach Angles
High Ground Clearance
Front Motor Design
XL-5™ HV ESC
Titan 21T 550 Motor
Waterproof Metal Gear Servo
Waterproof Micro Servos with Sleeved Cables
Accessory Light Kits (sold separately)
Molded Inner Fenders
Rock Sliders
1.9″ Scale Wheels and Tires
Rugged Roll Cage
Tough Fender Flares
Secure Body Mounting System
Land Rover and the Land Rover Logo are trademarks owned and licensed by Jaguar Land Rover Limited.
