Battery & Charger
Sold Separately
TRX-4 Chevrolet Blazer High Trail Edition
Name:
TRX-4® Chevrolet® K5 Blazer High Trail® Edition
Type:
Trail / Crawler
Skill Level:
1
Chassis:
Steel Ladder Frame
1/10
7.26 lbs (3.30 kg)
20.67 inches (525 mm)
10.63 inches (270 mm)
Track:
11.22 inches (285 mm)
12.28 inches (312 mm)
Center Ground Clearance:
4 inches (99 mm)
Driveline:
Shaft-driven 4WD
Transmission:
2-speed high/low, remote shifting
4 gear, remote locking
32 pitch
Steering Servo:
2075X metal gear, digital high-torque waterproof
TQi™ 2.4 GHz 4-channel transmitter with 6533 receiver
Battery Compartment Specs:
159 mm X 47 mm X 23 mm, 26 mm
Name:
Titan® 550 21T reverse rotation
Motor Type:
High-torque brushed motor
390 g (13.76 oz)
3.071” (78 mm) overall length, 2.25” (57 mm) can length
Diameter:
1.532” (39 mm diameter)
Shaft Size:
3 mm
Connector Type:
Bullet
Name:
XL-5™ HV
ESC Type:
Brushed
Case Size:
1.23 inches (31 mm) / 2.18 inches (55 mm) / 1.04 inches (26 mm)
2.6 ounces (74 g)
Motor Connectors:
Bullet
Battery Connectors:
Power Wire:
14 gauge
Officially Licensed Chevrolet® K5 Blazer Body Scale details: deep-inset front grille, chrome bumpers, side mirrors, door handles, side trim and wipers LED-ready headlights, tail lights, and side markers Authentic decal sheet Full Nylon composite wheel wells and floor pans Clipless Body mounting Clipless design for smooth body appearance Rugged internal body cage for added rigidity Body details mount directly to internal frame Trail-tuned XL-5™ HV Waterproof Electronic Speed Control Fully waterproof design Five drive profiles Sport Mode — forward / brake / reverse Race Mode — forward / brake / no reverse Training Mode™ - 50% forward / 100% brake / 50% reverse (patented) Trail Mode — forward / brake / reverse / with trail-tuned drag brake in neutral Crawl Mode — forward / instant reverse - no neutral with 100% hill holding brake Traxxas EZ-Set® one-button setup Large, efficient heat sink Wide voltage latitude 6–7 cell NiMH (7.2–8.4 V) and 2–3 cell LiPo (7.4–11.1 V) Two stage low voltage protection (LVD) Titan® 550 Motor Powerful Titan 21T reverse rotation motor with internal cooling fan Precision, preset gear mesh adjustments Motor retention separate from gear mesh Portal Axles Increase ground clearance Eliminate torque twist Steel gears Improve axle geometry and reduce strain on driveshafts Driveline Full-time shaft driven 4-wheel drive Tough 6 mm stub axles Steel front CV driveshafts Hardened steel rear axle shafts Remote locking steel gear differentials with cable-actuation Steel gear transfer case Factory-Installed Long Arm Lift Kit Increases ground clearance over 1″ Maintains precise steering geometry Accommodates oversize 2.2" wheels and tires TQi™ 2.4 GHz Radio System 4-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link enabled models Exclusive Cruise Control feature for extended trail driving Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle endpoints Patented waterproof receiver box with easy-access plug Reinforced Steel Ladder Frame Full-length 1.5 mm thick steel frame rails Bumpers adjust fore and aft Rugged rock rails adjust for width Wire routing clips integrated into frame rails Innovative Battery Compartment Hinged battery strap allows quick and easy battery access No pins to lose Accommodates different height batteries Accepts full-size long battery packs Integrated compartment accepts smaller 1/16 scale batteries (with optional strap) Secondary front battery tray accepts smaller 1/16 scale batteries (with optional strap) Transmission Two speed high/low range with remote shifting Dual horizontal shafts Twin friction plate slipper clutch Easily removed for servicing Steering Chassis mounted 2075X metal gear digital servo Superior 45° steering angle Direct steering (no servo saver) Steering geometry corrected for bump steer Suspension Front — 3 link with panhard Rear — Triangulated 4 link Heavy-duty rod ends with steel hollow balls 5 mm diameter steel link rods with 4 mm threaded ends Extended Aluminum GTS Shocks Oil-filled coilover GTS shocks exclusive to TRX-4 chassis Extra-long aluminum bodies for greater articulation Silver-anodized aluminum bodies Threaded bodies with collars easily adjust ride height Silky smooth damping for the toughest trails O-ring cap seal and dual X-ring shaft seals Oversize Wheels and Tires 2.2" chrome mag wheels wheels with hub inserts Pre-mounted 2.2" Canyon Trail tires with trail-tuned foam inserts Trail tuned S1 rubber compound 12 mm steel hex Sealed Ball Bearings Hex hardware with Rust-Resistant Black Oxide Coating Requires Battery and Charger (Sold Separately)
MODEL 92086-4 : TRX-4® Scale and Trail® crawler with 1972 Chevrolet® K5 Blazer body and Long Arm Lift Kit: 1/10 Scale 4WD electric truck. Ready-To-Explore® , with TQi™ Traxxas Link™ enabled 2.4 GHz radio system, XL-5™ HV ESC (fwd/rev), and Titan® 550 motor.
What’s In The Box:
TRX-4 Scale and Trail crawler XL-5 HV waterproof electronic speed control Titan 21T reverse rotation motor TQi 2.4 GHz radio system with cruise control High quality maintenance tools
What You’ll Need:
Batteries
TRX-4 accepts a wide variety of NiMH (6–7 cell) and LiPo (2s–3s) batteries.
Charger
AA Alkaline Batteries
HIGH TRAIL ADVENTURE
Traxxas High Trail Edition™ TRX-4 models are the biggest and baddest trucks on the trail and now classic Blazer fans have reason to celebrate. The 1972 Chevrolet® K5 Blazer gets the full High Trail treatment with a big, lifted stance and beautifully detailed body. The factory-installed Long Arm Lift Kit boosts the Blazer’s ground clearance by more than an inch with larger 2.2″ wheels and tires to conquer the roughest terrain. K5 Blazer High Trail Edition delivers more of what you crave—extreme all-terrain capability, stunning scale looks, and Traxxas-Tough™ durability.
HIGH TRAIL EDITION
Large 2.2″ chrome mag wheels and Canyon Trail tires tame even the most technical trails to extend your scale adventures farther than ever before. The factory-installed Long Arm Lift Kit raises K5 Blazer over an inch taller for superior ground clearance.
DETAILED REPLICA BODY
The TRX-4 K5 Blazer faithfully reproduces one of the most iconic Chevy trucks to ever hit the trail. Bright chrome accents contrast the high-gloss paint for an unmistakable look. The injection-molded grille, side mirrors, and simulated wood trim give K5 Blazer uncompromising scale presence.
CLIPLESS BODY MOUNTING
The clipless body’s hidden latching system gives K5 Blazer High Trail Edition clean, flowing lines for new level of scale realism and convenience. On the trail, K5 Blazer’s clipless body holds tight when you need it, but releases in just seconds to access the chassis.
Factory-Installed Lift Kit
K5 Blazer High Trail Edition’s factory-installed lift kit and oversize tires add over an inch of trail-conquering ground clearance. Extended 110 mm GTS shocks deliver silky-smooth damping performance with greater wheel articulation for increased off-road capability. Extended steel links and a revised servo mount maintain TRX-4’s superior suspension geometry.
Scale Details
Injection molded parts elevate Blazer’s scale detail with a deep inset front grille and chrome bumpers with colored lenses. The chrome side trim features simulated wood inserts for period-correct authenticity with side markers, wipers, and chrome side mirrors for maximum visual impact. The 8-hole chrome mag wheels are designed in exacting detail for perfect scale proportions.
Clipless Body Mounting
K5 Blazer’s clipless body mounts hold tight on the trail, but release in seconds. An invisible quick-release system secures the body without interrupting its clean lines with body posts and clips.
Oversize 2.2" Wheels & Tires
Aggressive S1-compound Canyon Trail tires feature large lugs for increased grip and 2-stage foam inserts for realistic trail performance. The tires come mounted and glued to large 2.2" chrome mag wheels. Detailed replica locking hubs conceal the wheel nuts for a cleaner look.
TRX-4 Capability
K5 Blazer High Trail Edition comes loaded with award-winning TRX-4 features like portal axles, remote-operated T-Lock™ differentials, high/low 2-speed transmission, aluminum GTS shocks, and a steel ladder frame; with the added benefit of higher ground clearance.
The Power Of Portals
K5 Blazer’s portal axles work in tandem with the Long-Arm Lift Kit to lift the truck for huge center ground clearance. With over 2 inches of clearance under the center pumpkin, K5 Blazer climbs over obstacles that would snag other trucks. Internal gear reduction virtually eliminates torque twist, keeping the truck straight and on course.
Rigid Steel Frame
A heavy-duty formed-steel ladder frame with molded cross members creates an extremely rigid backbone. You’ll feel the difference on trails when navigating technical terrain.
3s Power System
The XL-5™ HV electronic speed control brings 3s LiPo capability for strong efficient running. The powerful 21T Titan® motor provides torque for hauling heavy loads and climbing steep grades. This efficient system provides exceptional run time with a Traxxas 3s 5000 mAh LiPo battery pack! (Part 2872X)
TQi™ Radio System
The 4-channel TQi radio system unlocks exclusive TRX-4 features such as remote operation of the 2-speed transmission and the T-lock locking differentials. The TQi also adds cruise control to set and maintain your travel speed for long haul comfort as well as 30-model memory to control your entire Traxxas fleet. You can even customize settings via smartphone with the 6511 Wireless Module (sold separately).
Waterproof Electronics
K5 Blazer High Trail Edition shrugs off mud, snow, and streams with its waterproof electronics. The speed control and servos are waterproof, and the receiver is fully protected by a watertight enclosure. Like all TRX-4 models, Blazer delivers all-season, all-weather adventure.
Accessory LED Lighting Available
Take your K5 Blazer’s realism to the next level with the optional 8090X LED Light Kit used on the standard TRX-4 Blazer. The Pro Scale® Advanced Lighting Control System adds full-function headlights, brake and reverse lights, turn signals, multiple driving modes, and much more to your TRX-4.
Details
Molded Scale Details
K5 Blazer High Trail Edition features beautiful precision-molded details for a whole new level of scale realism. Chrome mag wheels, side mirrors, windshield wipers, and top of the line Chevy Cheyenne wood trim provide the perfect scale touches.
The Traxxas Long Arm Lift Kit includes extended GTS aluminum shocks, longer links and rod ends, extended driveshafts and T-Lock cables, and a new servo mount. The lift kit works as one engineered system not only to raise the truck, but also to maintain TRX-4’s carefully tuned suspension geometry.
Clipless Convenience
K5 Blazer’s heavy-duty clipless body mounts integrate into its rugged inner fenders to form a vise-like grip. When it’s time to release the body, simply reach under the fender and pull the tabs. It’s that easy.
Heavy-Duty Frame Rails
A thick 1.5 mm steel ladder frame with molded cross members provides exceptional torsional rigidity to resist even the worst chassis twisting articulation. This extremely rigid backbone lets the suspension do the work it was designed to do. You’ll feel the difference on trails where the elimination of chassis flex allows for precise wheel placement when navigating technical terrain.
Chrome-Finish Differential Covers
Classic style meets modern technology underneath the K5 Blazer with realistic mirror chrome differential covers. These polished details take the scale look of the front and rear portal axles to the next level.
Raised Center Driveshafts and Suspension Links
TRX-4’s radical portal axle design raises the axle centerline higher to improve axle geometry and reduce driveshaft angles. Higher driveshafts and suspension links pass over obstacles to avoid high-centering your truck and reduce overall grinding wear.
High/Low Transmission
Why carry your crawler down the trail when you can drive? Blazer K5 High Trail Edition features a high speed gear to get you to your next crawling challenge quickly. When you get there, flip the rocker switch on your transmitter to engage low range and conquer tough terrain with exceptional torque.
Molded Inner Fenders and Floor Pans
Tough inner fenders mount directly to the frame and shock towers to provide a realistic and substantial feel to Blazer K5 High Trail Edition. Molded floor pans integrate into the fenders to keep rocks, mud, and twigs out of the chassis.
Titan 21T 550 Motor
Torque rules the trail! TRX-4’s massive Titan 21T motor pumps out huge torque to get you up and over anything that gets in the way. An integrated cooling fan keeps temperatures down for extended run times.
2.2" Canyon Trail Tires
K5 Blazer rides on oversize Canyon Trail tires for additional ground clearance and rock-crawling performance. The ultra-soft S1-compound rubber and aggressive lug pattern, and dual-density foam inserts deliver unmatched grip and rugged climbing action.
Extended-Length 110 mm GTS Shocks
Blazer’s extra-long 110 mm GTS coil-over shocks are oil-filled to smooth out even the roughest trails. These silver-anodized aluminum shocks deliver silky-smooth damping and feature threaded bodies for easy ride height adjustment. The convincing scale realism looks great and they perform even better with an O-ring cap seal and dual X-ring shaft seals.
Torque Twist Eliminated
On conventional rigs with the limited gear reduction in the differentials, motor torque is applied to the frame to the point of twisting you right off the rocks. TRX-4’s portal axle design reduces the gear ratio at the wheels, virtually eliminating torque twist through the chassis.
T-Lock™ Remote Locking Differentials
Traxxas gives you complete control over the front and rear differentials to suit your driving needs. Leave the differentials unlocked for relaxed driving on the trail. When the trail gets technical, lock the front and rear differentials, or just the front differential, for superior pull and grip over extreme terrain. Sleeved micro cables control the differential action for scale appearance, without limiting the huge suspension articulation.
Waterproof Metal Gear Servo
A full-metal gear digital servo gives you the durability and steering authority you need to confidently and reliably power through tough challenges.
GM used under license to Traxxas.
