Battery & Charger
Sold Separately
Stampede 2WD Brushless
Name:
Velineon V3200 (patent pending)
Motor Type:
Sensorless brushless
7.48 ounces (212 g)
3.15 inches (80 mm)
Diameter:
1.53 inches (39 mm)
Shaft Size:
5 mm
Connector Type:
3.5 mm Bullet
Name:
VX3 Electronic Speed Control
ESC Type:
Brushless
Voltage Range:
2-cell or 3-cell LiPo (NiMH not supported)
Case Size:
2.40″ (61 mm) x 2.09″ (53 mm) x 1.69″ (43 mm)
4.20 ounces (119 g)
BEC Voltage:
6.0 volts
Motor Connectors:
3.5 mm Bullet
Battery Connectors:
35+ mph with 2s LiPo. 50+ mph with 3s LiPo (no gearing change required) NEW Clipless Monster Truck BodyBold, aggressive styling Body reinforcements reduce the possibility of pull-through damage Molded grille and tailgate inserts Clipless latches hold tight for intense action Quick and easy removal NEW Chassis DesignAll new tub chassis modeled after Maxx® monster truck Integrated shock towers are part of the chassis Reinforced crossbar supports Double-shear shock mounts Ultra-tough front and rear bulkheads Integrate seamlessly into the chassis Reinforced front bumper and wheelie bar NEW Velineon® VX3 Waterproof Electronic Speed ControlLarge aluminum heat sink with cooling fan Three programmable drive profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup Real-time telemetry via Traxxas Link™ High-Resolution Linear Braking Compatible with 2s and 3s LiPo batteries (NiMH not supported) NEW Velineon V3200 Brushless MotorUltra high-temperature sintered Neodymium magnets provide massive torque and linear power 3200 Kv optimized for power and efficiency in 1/10th scale vehicles 5 mm output shaft Internal cooling fan for longer run times Low-maintenance design Efficient, high-speed ball bearings NEW TQi™ Sport 2.4 GHz 2-Channel Radio SystemRemovable grip adapter for smaller hands High-output signal delivers outstanding range Simple one-button programming 30-model memory 3-channel micro receiver with fail-safe security Watertight receiver box with O-ring sealed cover Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on power slides Never dulls throttle or slows the truck Activated or deactivated directly from the transmitter NEW Suspension DesignAll-new double wishbone design Maintains proper suspension geometry Allows huge suspension travel Double-shear connections HD suspension arms NEW Battery Tray DesignBattery is protected deep in the chassis Rugged battery strap latches shut to secure batteries No battery clips to lose Accepts many 2s and 3s battery configurations Steering NEW 2057 waterproof, metal-gear servoFull metal gear train for improved durability NEW dual-bellcrank design with integrated servo saverTransmission and Driveline Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system NEW 32-pitch spur and pinion gearPlanetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access NEW Composite GTR ShocksThreaded shock collars for precise ride height adjustment Large oil capacity for consistent damping White powder-coated springs Spring retainers captured with a screw 3.5 mm shaft Wheels and Tires Large 2.8″ black monster truck wheels NEW Talon MXT TiresTall monster truck profile Angled tread pattern for massive forward bite Precision Hex Hardware Rubber-Sealed Ball Bearings
MODEL 136454-4 : Stampede® 2WD Brushless: 1/10 scale monster truck, fully-assembled, waterproof, Ready-To-Race® , with TQi™ Sport 2.4 GHz 2-channel radio system with TSM® , Velineon® 3s brushless power system, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Stampede 2WD monster truck with VX3 ESC and V3200 motor TQi Sport 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
Batteries
Stampede 2WD Brushless requires a single 2-cell or 3-cell LiPo battery.
Charger
AA Alkaline Batteries
A Legend Is Reborn
In the history of RC monster trucks no name carries more weight than Stampede® . As the original Ready-To-Race® monster truck, Stampede set the standard for everything that followed. Now there’s an all-new Stampede with Maxx® strength and durability, backed by Velineon® 3s brushless power. With its all-new double-wishbone suspension and GTR shocks, Stampede 2WD Brushless obliterates conventional designs to usher in a new era of monster truck performance.
