Battery & Charger
Sold Separately
Slayer Pro 4X4
WARNING: This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Name:
Slayer® Pro 4X4
Type:
Short Course Truck
Speed:
45 mph, 50+ with optional 17-tooth clutch bell (5217), sold separately
Skill Level:
4
1/10
7.78 pounds (3.53 kg)
23.54 inches (598 mm)
12.68 Inches (322 mm)
Front Track:
Rear Track:
7.87 inches (200 mm)
13.9 Inches (353 mm)
Center Ground Clearance:
2.5 Inches (63.5 mm)
Driveline:
Shaft-driven 4WD
Transmission:
Auto two-speed forward only
Bevel gear, sealed, limited slip
Gear Ratio (Internal):
15.75:1 (1st gear) 10.05:1 (2nd gear)
1.0 metric pitch (Mod 1)
Steering Servo:
2075 dual digital high-torque waterproof
Starter:
Electric EZ-Start®
Carburetor:
Two-needle slide carburetor
Air Filter:
Dual-stage foam
Tank Size:
150 cc
Engine Name:
TRX® 3.3 Racing
Fuel Type:
Nitromethane
Displacement:
3.3 cc
Starter:
Electric EZ-Start®
Carburetor:
Air Filter:
Dual-stage foam
ProGraphix® Painted Body
Pre-painted body with applied decals
Scale dimensions and looks of actual short course race trucks
Chassis nerf bars absorb impact and support the body
Scale front and rear tube-style bumpers
TRX® 3.3 Racing Engine
Large bore piston and sleeve deliver extreme power
High-volume dual-stage air filter
Tuned polished aluminum Resonator™ exhaust pipe
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
2-channel high output transmitter
Automatically stores and loads settings for up to 30 Traxxas Link-enabled models—just switch on and drive, "model selection" is not required
Multi-Function knob
Compact receiver and battery box with integrated personal transponder mount
EZ-Start® Electric Starting System
Lights the glow plug and cranks the engine with the push of a button
Status LEDs
Includes starter battery and charger
Blue-Anodized Aluminum Chassis
Blue-anodized 3 mm aluminum 3D semi-monocoque chassis
Long wheelbase chassis and wide track suspension arms
Waterproof steering and throttle/brake servos
Large 150 cc fuel tank extends run time
Transmission and Driveline
Two-speed forward only transmission with adjustable shift point
Ultra-compact with fewer moving parts
Low rotating mass for quick, high-revving acceleration
Constant drive engagement is smooth and instantly responsive
Sealed case protects gears & two-speed from damaging debris
Tunable front and rear sealed, limited-slip gear differentials
Large diameter semi-metallic brake disc
Torque-Control™ slipper clutch
Semi-metallic pads
Finned aluminum alloy pressure plates
Super-duty U-joint driveshafts
Steering
Digital, waterproof, high-torque Traxxas 2075 steering servo
High-performance bellcrank system minimizes bump steer
Suspension
Progressive pushrod rocker-actuated suspension
Shocks are rigidly mounted to the chassis to minimize crash damage
Sealed pivot ball suspension arms
Springs and Shocks
Precise GTR™ shocks provide smooth, consistent damping performance
Threaded shock bodies for precise ride height adjustment
Hard-anodized PTFE-coated shock bodies with TiN coated shock shafts
Red powder-coated springs
Wheels and Tires
Pre-glued short course racing tires with foam inserts
Split-spoke SCT chrome-center wheels with color-molded beadlock-style trim rings
Backed by Unparalleled Traxxas Support and Parts Availability
Precision rubber-sealed ball bearings
Precision metric hex hardware throughout
MODEL 59076-3 : Slayer® Pro 4X4: 1/10 scale 4WD nitro short course truck, fully assembled, Ready-To-Race® , with TQi™ 2.4 GHz radio system with Traxxas Stability Management® , TRX® 3.3 Racing Engine, and painted body.
What’s In The Box:
Slayer 3.3 with TRX 3.3 engine Quick Start Guide TQi 2.4 GHz radio system Starter box with battery and charger Fuel bottle, spare filter & glow plug, and maintenance tools
What You’ll Need:
Nitro Fuel
Traxxas Top Fuel, 20% or 33%
Eight AA Alkaline Batteries
Four AA alkaline batteries for transmitter, four AA alkaline batteries for receiver pack.
