Battery & Charger
Sold Separately
Slash 4X4 VXL Ultimate
Name:
Slash 4X4 Ultimate Clipless
Type:
Short Course Truck
Speed:
60+ mph with optional gearing and 3s LiPo battery (sold separately)
Skill Level:
2
1/10
5.03 pounds (2.28 kg)
22.36 inches (568 mm)
11.65 inches (296 mm)
Track:
7.60 inches (193 mm)
12.75 inches (324 mm)
Center Ground Clearance:
1.85 inches (47 mm)
Driveline:
Shaft-driven 4WD
Hardened steel bevel, sealed, limited slip
Gear Ratio (Internal):
11.82:1
32 pitch
Steering Servo:
2075R metal gear, digital high-torque, waterproof
TQi™ 2.4 GHz 2-channel transmitter with TSM® receiver and 6511 Wireless Module
Battery Compartment Specs:
165 mm X 49.5 mm X 23 mm , 25 mm
Name:
Velineon® 3500
Type:
Sensorless brushless 3500 Kv
9.24 ounces (262 g)
Diameter:
1.41 inches (36 mm)
Shaft Size:
3 mm
Connector Type:
3.5 mm bullet
Name:
Type:
Case Size:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
Power Wire:
12 gauge Maxx® Cable
Pre-Installed Heavy-Duty Aluminum Upgrades Blue-anodized 6061-T6 aluminum C-hubs Blue-anodized 6061-T6 aluminum steering blocks Blue-anodized 6061-T6 aluminum rear hub carriers Blue-anodized 6061-T6 aluminum axle nuts Clipless ProGraphix® Painted Body Pre-painted body with applied decals Scale dimensions and looks of actual short course race trucks Chassis nerf bars absorb impact and support the body Scale front and rear tube-style bumpers VXL-3s™ Waterproof Electronic Speed Control Three programmable drive profiles: Sport Mode - Forward / Brake / Reverse Race Mode - Forward / Brake Training Mode™ - 50% Forward / Brake / 50% Reverse (patented) Traxxas EZ-Set® one-button setup Large heat sink Built-in two-stage low-voltage detection for LiPo batteries NiMH battery packs: 6-9 cells (7.2 to 10.8 volts) LiPo battery packs: 2-3 cells (7.4 to 11.1 volts) Velineon® Brushless Motor Ultra high-temperature sintered neodymium magnets Optimized for power and efficiency in 1/10th scale vehicles Low-maintenance, unique Traxxas design Efficient, high-speed ball bearings Precision-balanced rotor 3500 kV Brilliant blue-anodized finish Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the truck Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz High Output Radio System TQi 2-channel transmitter 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Compatible with optional TQi Traxxas Link Wireless Module (6511) to access full Traxxas Link app functionality (sold separately) Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Programmable multi-function knob Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle sensitivity (exponential) Adjustable steering and throttle end points Patented waterproof receiver box with easy-access plug Low-CG Reinforced Monocoque Chassis Batteries and electronics held low for improved handling Low-CG design dramatically increases corner speed Modular chassis makes maintenance quick and easy Long 12.75″ wheelbase for increased stability Easy motor access with single-screw motor plate attachment All electronics securely fastened to chassis Integrated personal transponder mount Easy Access Battery Compartment Adjustable battery hold down Accepts 6- and 7-cell NiMH flat packs Accepts many 2s and 3s LiPo battery configurations Transmission and Driveline Full-time shaft-driven 4WD Blue-anodized aluminum center driveshaft Torque-Control™ slipper clutch with large 32-pitch gearing Sealed, silicone-filled differentials with steel gears Upgraded Extreme-duty telescoping driveshafts Steering Digital high-speed 2075R waterproof metal gear steering servo Dual bellcrank steering system with integrated servo saver Suspension Impact resistant heavy-duty suspension arms Adjustable front and rear sway bars Adjustable steel turnbuckles Captured rod ends won't pop off Springs and Shocks High-volume GTR shocks with adjustable-collar blue PTFE-coated aluminum bodies and titanium-nitride coated shafts Race-tuned white powder-coated springs Wheels and Tires Officially-licensed BFGoodrich® Mud-Terrain™ T/A® Tires molded in S1 race compound 2″ outer diameter, 3″ inner diameter dual-profile SCT wheels Rubber-Sealed Ball Bearings Precision Hex Hardware Backed by Unparalleled Traxxas Support and Parts Availability Requires Battery, and Charger (Sold Separately)
MODEL 68277-4 : Slash® 4X4 Ultimate: 1/10 scale 4X4 short-course truck, waterproof, Ready-To-Race® , with TQi™ 2.4 GHz 2-channel radio system with factory-installed Wireless Module and telemetry sensors, VXL-3s™ speed control, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Slash 4X4 Ultimate with Velineon VXL-3s and 3500 Kv motor TQi 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
Batteries
Slash 4X4 VXL accepts a wide variety of NiMH (6–7 cell) and LiPo (2 or 3-cell) batteries.
Charger
AA Alkaline Batteries
The Ultimate 4X4 Short Course Race Truck
Experience the pinnacle of short course truck performance with Slash® 4X4 Ultimate. Carve corners like a pro thanks to the low-CG chassis, adjustable sway bars, and ultra-smooth PTFE-coated aluminum GTR shocks. Slash 4X4 Ultimate adds over $275 of aluminum hop-up parts and performance accessories for added strength and show-stopping looks. For precision control, Slash Ultimate features a Wireless Link-equipped TQi™ 2.4 GHz radio system with factory-installed telemetry.
Superior Handling
Carve corners like a pro thanks to Slash Ultimate’s adjustable sway bars and ultra-smooth, PTFE-coated aluminum GTR shocks. Slash 4X4 Ultimate’s agility and 4-wheel drive grip is further enhanced by its ultra-soft S1-compound racing tires. Slash Ultimate's low-CG chassis positions the battery and electronics deep in the chassis for superior handling on and off the track.
Included Wireless Module
A Traxxas Link™ Wireless Module comes standard on Slash 4X4 Ultimate along with factory-installed telemetry sensors to unlock the full potential of the TQi™ transmitter. Adjust the transmitter’s settings on the fly and record real-time telemetry data like speed, RPM, and battery voltage on your mobile device using the free Traxxas Link app.
Over $275 in Upgrades!
Slash 4X4 Ultimate comes fully loaded with over $275 in premium upgrades for maximum durability. Aluminum caster blocks, steering blocks, axle carriers, and a high-speed metal-gear servo deliver superior strength and precision. The high-capacity aluminum GTR shock bodies are hard-anodized and PTFE-coated for ultra-smooth damping performance.
Details
TQi Transmitter with Wireless Module
Slash 4X4 Ultimate’s 2.4 GHz TQi transmitter comes with a factory-installed Wireless Module to access the full range of powerful TQi tuning and telemetry tools on your mobile device. Use the free Traxxas Link™ app to control steering and throttle sensitivity; steering percentage; braking strength; and throttle trim by simply touching and dragging the sliders on the high-definition graphic interface.
S1-Compound BFGoodrich Tires
Slash 4X4 Ultimate rides on replica BFGoodrich ® Mud-Terrain™ T/A ® tires for authentic scale looks. The tires’ soft-compound S1 rubber provides realistic performance and enhanced control. Black Chrome SCT wheels complete the look with equal parts style and strength.
GTR Shocks
GTR shocks represent the peak of suspension technology. The blue PTFE-coated aluminum shock bodies hold over 70% more oil than the standard Ultra Shocks™ and their slick titanium-nitride coated shafts resist scuffing, increase durability, and eliminate "stiction." X-ring seals keep oil in and dirt out for smooth, consistent damping, and plush suspension action. Spring preload and ride height changes are as simple as turning the threaded collars--no spacers required.
Low-CG Chassis
Slash 4X4 Ultimate's battery and electronics are held deep in the chassis to position weight as low as possible. The low-CG design dramatically increases corner speed and stability. Slash's low center of gravity allows high-output Velineon brushless power to be channeled into the track with superior traction, resulting in harder launches and faster lap times.
Aluminum Hub Carriers
6061-T6 aluminum stub axle carriers add both strength and beauty to Slash 4X4 Ultimate without compromising its carefully tuned suspension geometry.
Aluminum Wheel Nuts
Slash's aluminum wheel nuts lock tightly onto its replica short course wheels for intense racing action. The color-matched anodized finish contrasts the dark wheels for maximum impact.
High Speed Metal Gear Servo
Slash 4X4 Ultimate needs a fast and powerful servo to match its lightning-quick reflexes. The fully waterproof 2075R digital metal gear servo combines commanding steering authority with the superior durability of all-metal gears for the ultimate driving experience.
Aluminum Center Driveshaft
Slash's center driveshaft is formed from extruded aluminum and extremely lightweight for lower rotating mass. There are no dogbones to wear out, no drive cups to wobble and the shaft runs perfectly straight and true with superior rigidity and durability.
Adjustable Sway Bars
Slash 4X4 Ultimate’s front and rear sway bars reduce chassis roll and increase corner speed on high-traction surfaces—perfect for hard-packed tracks and pavement running. Adjustable linkages allow for fine tuning to suit different tracks and conditions.
Aluminum Caster and Steering Blocks
Slash 4X4 Ultimate’s caster and steering blocks combine the strength of 6061-T6 aluminum with carefully engineered steering and suspension geometry. The brilliant-blue anodized finish adds high-tech style with laser-etched logos to show off your genuine Traxxas performance parts.
Copyright © 2026 MNA, Inc. All rights reserved.
