Battery & Charger
Sold Separately
Slash 2WD Brushless
Name:
Slash 2WD Brushless
Type:
Short Course Truck
Speed:
35+ mph with 2-cell LiPo, 50+ with 3-cell LiPo
Skill Level:
1
1/10
5.82 pounds (2.41 kg)
22.4 inches (568 mm)
11.65 inches (296 mm)
Track:
7.6 inches (193 mm)
13.2 inches (335 mm)
Center Ground Clearance:
2.2 inches (56 mm)
Driveline:
2WD
Transmission:
Magnum 272™
Planetary steel gear
Gear Ratio (Internal):
2.72 (final drive: 9.05)
32 pitch
Steering Servo:
2057 metal gear waterproof
TQi™ Sport 2.4 GHz 2-channel radio with TSM®
Battery Compartment Specs:
166 mm X 49 mm X 28 mm
Name:
Velineon V3200 (patent pending)
Motor Type:
Sensorless brushless
7.48 ounces (212 g)
3.15 inches (80 mm)
Diameter:
1.53 inches (39 mm)
Shaft Size:
5 mm
Connector Type:
3.5 mm Bullet
Name:
VX3 Electronic Speed Control
ESC Type:
Brushless
Voltage Range:
2-cell or 3-cell LiPo (NiMH not supported)
Case Size:
2.40″ (61 mm) x 2.09″ (53 mm) x 1.69″ (43 mm)
4.20 ounces (119 g)
BEC Voltage:
6.0 volts
Motor Connectors:
3.5 mm Bullet
Battery Connectors:
35+ mph with 2s LiPo. 50+ mph with 3s LiPo (no gearing change required) NEW Aerodynamic Clipless Short Course BodyIncreases downforce at high speeds Body reinforcements help prevent pull-through damage Holds tight for intense action Quick and easy removal Smooth appearance with no body posts or clips NEW Velineon® VX3 Waterproof Electronic Speed ControlLarge aluminum heat sink with cooling fan Three programmable drive profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup Real-time telemetry via Traxxas Link™ High-Resolution Linear Braking Compatible with 2s and 3s LiPo batteries (NiMH not supported) NEW Velineon V3200 Brushless MotorUltra high-temperature sintered Neodymium magnets provide massive torque and linear power 3200 Kv optimized for power and efficiency in 1/10th scale vehicles 5 mm output shaft Internal cooling fan for longer run times Low-maintenance design Efficient, high-speed ball bearings Extreme Heavy-Duty Parts Installed Caster blocks, axle carriers, and steering blocks beefed up with extra material HD suspension arms Extreme HD driveshafts Extra material for improved strength NEW TQi™ Sport 2.4 GHz 2-Channel Radio System with TSM® Removable grip adapter for smaller hands High-output signal delivers outstanding range Simple one-button programming 30-model memory 3-channel micro receiver with fail-safe security NEW integrated watertight receiver box with O-ring sealed coverTraxxas Stability Management (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the truck Activated or deactivated directly from the transmitter NEW Clipless Battery CompartmentRugged battery strap latches shut to secure batteries No battery clips to lose Accepts many 2s and 3s battery configurations NEW Low-CG ChassisBattery and electronics sit low for improved handling Dramatically improved corner speed and stability Reinforced to reduce flex under load Carbon-fiber texture for a high-tech look and feel Tough tube bumpers and nerf bars to protect the chassis Long 13.2″ wheelbase for increased stability Steering NEW 2057 waterproof, metal-gear servoFull metal gear train for improved durability NEW Dual bellcrank design with integrated servo saverTransmission and Driveline Magnum 272™ metal-gear transmission Torque-Control™ slipper clutch system NEW 32-pitch spur and pinion gearPlanetary gear differential with steel ring gear Sealed gearbox protects the transmission with beefed up motor guard External gear cover with easy clutch access Suspension NEW Composite GTR ShocksThreaded shock collars for precise ride height adjustment Large oil capacity for consistent damping Spring retainers secured with screws White powder-coated springs 3.5 mm shaft Adjustable steel turnbuckles Captured rod ends won't pop off NEW steel front tie barWheels and Tires Pre-glued Replica BFGoodrich® Mud Terrain T/A® tires Performance foam inserts Softer rear tires for improved handling dynamics 2″ outer diameter, 3″ inner diameter dual-profile black split-spoke wheels Rubber-Sealed Ball Bearings Precision Hex Hardware Battery and Charger Sold Separately
MODEL 58434-4 : Slash® 2WD Brushless: 1/10 scale short course truck, fully-assembled, waterproof, Ready-To-Race® , with TQi™ Sport 2.4 GHz 2-channel radio system with TSM® , Velineon® 3s brushless power system, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Slash 2WD short course truck with VX3 ESC and V3200 motor TQi Sport 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
Batteries
Slash 2WD Brushless requires a single 2-cell or 3-cell LiPo battery.
Charger
AA Alkaline Batteries
Traxxas Slash® has defined short course RC racing for a generation. Now there’s a new Slash with even more power and performance. Slash’s new Velineon® 3s brushless power system transforms 11.1 volts of LiPo power into incredible 50+ mph speed with a new aerodynamic body to reduce high-speed lift. A new low-CG chassis delivers razor-sharp handling with revised suspension tuning for an ultra-plush ride. From the street to the track, Slash 2WD Brushless renders an authentic short course racing experience like nothing else.
More Power. More Performance. More Slash!
New 3s Brushless Horsepower
Slash’s new Velineon® 3s power system is a brushless powerhouse that transforms 11.1 volts of LiPo power into brutal acceleration and 50+ mph speed, out of the box with no gearing changes required. The fan-cooled VX3 speed control is feature-packed and simple to use with Traxxas EZ-Set® one-button programming. The powerful V3200 motor is a model of efficiency with internal fan cooling for long run times.
New GTR Shocks
Slash’s ultra-plush ride comes courtesy of new composite GTR shocks on all four corners. GTR shocks hold over 70% more oil than standard Ultra Shocks for consistent damping and a premium feel. X-ring seals keep oil in and dirt out for smooth suspension compression and rebound. Spring preload and ride height changes are as simple as turning the threaded collar and the spring retainers are captured with a screw so they can't pop off.
New Metal-Gear Servo
Slash needs a fast and powerful steering servo to match the quick reflexes and agile handling of its low-CG chassis. Slash receives a new metal-gear servo for superior strength and durability along with an improved bellcrank steering assembly. The bellcrank’s cam-operated servo saver enhances steering precision and protects the servo from impacts.
New Aerodynamic Body
With a top speed of over 50 mph, Slash must fight the wind to maintain its high-speed performance. Slash’s new aerodynamic body cuts through the air and increases downforce to deliver incredible straight-line stability. Heavy-duty clipless latches hold the body tightly for rough-and-tumble action, but release in just seconds for fast battery swaps.
A Legacy of Dominance
The impact of Slash on short course racing cannot be overstated. For 18 years, Slash’s unique combination of strength, durability, and fun has made it the best-selling truck in RC. Slash maintains its total dominance in the field, by always innovating, always improving. Slash 2WD Brushless continues that trend with over a dozen new features to keep you ahead of the pack.
Improved Suspension Performance
Traxxas engineers recalibrated Slash’s suspension to maximize performance across all surfaces. The result is an ultra-plush ride that soaks up bumps to put Slash’s massive brushless power to the ground. Slash’s long-travel suspension and GTR shocks dramatically improve suspension compliance on rough terrain while its low-CG chassis delivers razor-sharp cornering on the track.
Enhanced On-Road Handling
Slash’s low-CG chassis dramatically improves agility while a new rear tire compound enhances cornering speed. The ultra-soft rear tires lock the rear to the pavement, allowing the front tires to slide just enough to reduce traction rollovers. The result is faster turn-in speed, greater grip, and more fun as you bury the throttle and power through corners like never before.
Clipless Convenience
Slash’s revolutionary clipless body holds firm no matter how rough the racing gets. Heavy-duty latches grip the body tightly, but release in just seconds for fast battery swaps on the pit bench. This convenient hidden latching system replaces traditional body clips with large, reinforced panels to maintain body integrity and resist pull-through damage.
New TQi Sport Transmitter
The TQi™ Sport transmitter packs the range and performance of the TQi into a compact design for maximum comfort and portability. The ergonomic grip features a removable adapter to accommodate smaller hands and simple one-button programming for ease-of-use. A class-leading high-output 2.4 GHz signal delivers the outstanding range and glitch-free performance required by Slash’s blistering speed.
Traxxas Stability Management® (TSM) works behind the scenes to harness Slash’s extreme 3s brushless horsepower. TSM maximizes acceleration and braking by keeping Slash arrow straight without pulling power or dulling throttle response, even on low-traction surfaces. TSM can also be switched off directly from the TQi Sport transmitter.
High-Performance Chassis
Slash’s low-CG chassis holds the battery and electronics as low as possible for improved handling and increased corner speed. The rigid chassis is reinforced and optimized for the loads imparted by the suspension and powertrain. A new carbon fiber-look dark gray composite gives the chassis a high-tech appearance.
Unparalleled Strength
Slash’s Extreme Heavy-Duty parts work together to form a cohesive package of brute strength and maximum durability. Heavy-duty A-arms and driveshafts put Slash’s immense brushless power to the ground with beefed-up suspension components to resist impact damage. Slash 2WD Brushless sets the standard for durability at skate parks, racetracks, and everything in between.
Details
Replica Short Course Wheels and Tires
Slash’s replica BFGoodrich® Mud Terrain T/A® tires offer excellent grip in the dirt and just the right amount of slide on pavement. A new ultra-soft rear compound enhances road handling and reduces traction rolling. Their authentic scale appearance and realistic performance add to the racing experience.
Velineon V3200 Motor
Designed for 3-cell LiPo batteries, the V3200 motor is optimized for extreme power and efficiency with a large 5 mm output shaft. Ultra-high temperature sintered Neodymium magnets provide massive torque and linear power. The unique low-maintenance design features high-speed ball bearings and an integrated cooling fan for consistent power, run after run.
3-Channel TQi Sport Receiver
The TQi Sport receiver is compatible with all TQi and TQi Sport transmitters. A built-in failsafe returns the throttle to neutral and holds the steering in the last known position in the event of a signal loss.
Rugged Shock Towers
Slash’s rugged shock towers minimize flex and provide a rigid mounting point for the body. Reducing flex allows the suspension to soak up bumps without upsetting the chassis for a smooth and controlled ride.
Waterproof Electronics
Your RC experience should be filled with fun and adventure, not limited by the electronics. Slash’s new receiver box is molded into the chassis for increased strength. A patented O-ring seal keeps water out, giving you the freedom to live out your wildest adventures, regardless of the weather.
Extreme HD Driveshafts
Slash’s Extreme HD driveshafts are beefed up in critical areas to handle the outrageous power of the Velineon 3s brushless power system. The large-diameter half shafts offer excellent articulation and suspension travel while putting massive torque to the ground.
Long-Wheelbase Chassis
Slash’s long 13.2” wheelbase chassis provides superior stability on high-speed straights. A new carbon-look material gives the low-CG chassis a high-tech look to match its legendary performance.
The fully waterproof VX3 ESC transforms 11.1 volts of LiPo power into 60+ mph performance with the simplicity of Traxxas’ EZ-Set® one-button programming. A large aluminum heat sink with cooling fan keeps temperatures down for longer run times. The VX3 comes loaded with high-tech features like race-inspired High-Resolution Linear Braking and real-time telemetry via Traxxas Link (requires TQi transmitter with installed wireless module).
Clipless Battery Strap
Slash holds batteries securely in place with the convenience of a rugged clipless battery strap. Swing the heavy-duty strap up and out of the way to swap batteries. Once loaded, just snap the tab into the latch and your battery stays secure until you release it.
Metal Gear Servo
Slash features a new metal-gear servo with the durability on an all-metal gear train. The new servo delivers quick, precise control with the security and convenience of fully waterproof construction.
Bellcrank Steering
Slash’s high-performance bellcrank steering system nearly eliminates bump steer for precise wheel placement and increased cornering stability. A cam-operated servo saver increases steering precision while protecting the servo against impacts.
Chassis Nerf Bars
Tough integrated nerf bars offer side chassis protection against the fender-to-fender impacts of track competition and backyard bashing.
Heavy-Duty Suspension Arms
Slash’s heavy-duty suspension arms are molded in a new high-tech gray color from our toughest composite material to provide just the right amount of flex to resist breaking. These suspension arms stand up to even the most punishing drivers for non-stop action.
Steel Front Tie Bar
A steel front tie bar provides additional strength to keep the suspension in perfect alignment and protect against impacts.
Hex Hardware
Slash’s hex-drive hardware provides a more positive and secure connection than other fasteners. The black-oxide coating provides a rust resistant high-tech look and feel.
Clipless Body Mounting
High-flying stunts won’t upset Slash’s tough clipless body. Locking tabs hold the body tightly, but release in just seconds. Slash’s hidden latching system maximizes convenience and scale realism by removing traditional body clips which would interrupt the body’s clean lines.
Scale Front and Rear Bumpers
Slash’s front and rear bumpers mount solidly to reinforced bulkheads to absorb impacts. The tube-style bumpers offer rugged protection while looking the part of a true short course race truck. Slash's front bumper also features bosses to mount accessory LED lights.
Adjustable Steel Turnbuckles
Heavy-duty steel turnbuckles allow trackside camber and toe tuning for greater agility and high-speed performance. Captured rod ends provide unmatched durability, and they won’t pop off during a race.
Extreme HD Components
Engineered for maximum strength, Extreme Heavy-Duty components fortify Slash with a full complement of driveline and suspension upgrades designed to work together as a complete package. Slash sets a new standard for durability at skate parks, racetracks, and backyards.
Magnum 272 Transmission
The Magnum™ 272 transmission features all metal gear internals riding on ultra-smooth sealed ball bearings. The sealed gearbox protects the transmission components from dirt and rocks.
32-Pitch Gearing
Slash is built for extreme power with a large 5 mm motor output shaft and 32-pitch pinion and spur gears. Nearly 1.5x larger than standard 48-pitch gears, Slash’s 32-pitch gears deliver maximum durability with reliable, long-lasting performance.
Torque-Control Slipper Clutch
The Torque-Control™ slipper clutch uses special semi-metallic friction material and finned aluminum alloy pressure plates to dissipate heat and provide consistent traction control. Spur gears can be removed and replaced without altering the slipper adjustment.
Rubber-sealed bearings offer the ultimate in super low-friction performance and maximum protection in dusty environments. They are used in all exposed locations on the truck and are virtually maintenance free.
Steel-Composite Planetary Gear Differential
The composite planetary gear differential features a steel ring gear for long life. It uses hardened steel internal gears for maximum strength during rigorous off-road bashing. This type of differential requires virtually no maintenance, and its efficient design puts maximum tire-shredding torque to the wheels.
Copyright © 2026 MNA, Inc. All rights reserved.
