Name:
Rustler 4X4 VXL
Type:
Stadium Truck
Speed:
65+ mph with 3-cell LiPo and 20/54 gearing
Skill Level:
2
1/10
5.12 pounds (2.32 kg)
18.78 inches (477 mm)
12.94 inches (329 mm)
Front Track:
Rear Track:
6.35 inches (161 mm)
11.62 inches (295 mm)
Center Ground Clearance:
1.1 inches (27 mm)
Driveline:
Shaft driven 4WD
Transmission:
Single speed
Hardened steel bevel, sealed, limited slip
Gear Ratio (Internal):
13.97:1
32 pitch
Steering Servo:
Battery Compartment Specs:
162 mm X 50 mm X 23 mm, 25 mm
Name:
Velineon® 3500
Motor Type:
Sensorless brushless
9.24 ounces (262 g)
Diameter:
1.41 inches (36 mm)
Shaft Size:
3 mm
Connector Type:
3.5 mm bullet
Name:
ESC Type:
Brushless
Case Size:
3.17 ounces (90 g)
Motor Connectors:
3.5 mm bullet
Battery Connectors:
Power Wire:
12 gauge Maxx® Cable
Clipless Painted Body
Easy one-handed removal
Reinforced inner cage
Strong oversized latch
Rugged roof rollover protector
Molded composite plastic wing
Extreme Heavy Duty Upgrade Kit Installed
Strengthened C-hubs, axle carriers, and steering blocks
Maxx duty driveshafts
Oversize diameter
6 mm axles
Steel wheel hexes
TQi 2-channel transmitter
Programmable multi-function knob
Patented waterproof receiver box
VXL-3s™ Waterproof Electronic Speed Control
Three programmable drive profiles:
Sport Mode - Forward / Brake / Reverse
Race Mode - Forward / Brake
Training Mode™ - 50% Forward / Brake / 50% Reverse (patented)
Large heat sink
Built-in two-stage low-voltage detection for LiPo batteries
NiMH battery packs: 6-9 cells (7.2 to 10.8 volts)
LiPo battery packs: 2-3 cells (7.4 to 11.1 volts)
Velineon® Brushless Motor
Ultra high-temperature sintered Neodymium magnets
Low-maintenance design
Efficient, high-speed ball bearings
Precision-balanced rotor
3500 Kv
Brilliant blue-anodized finish
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the truck
Chassis
Low-CG design for responsive handling
Modular composite tub design
Latching battery hold-down
Reinforced integrated wheelie bar
High-approach front bumper to climb curbs
Driveline
Full-time shaft-driven 4-wheel drive
Oil-filled steel gear front and rear differentials
Large 32-pitch gearing
Torque Control™ heavy-duty slipper clutch with aluminum pads
Anodized-aluminum center driveshaft
Steering
Chassis-mounted 2075 servo
Dual bellcrank design with integrated servo saver
Suspension
Adjustable 4 mm steel toe and camber links
HD suspension arms
Oil-filled Ultra Shocks
Rugged front and rear shock towers
White powder-coated springs
Wheels and Tires
Large 2.8" black chrome wheels
Talon™ EXT tires
Sealed Ball Bearings
Hex hardware with Rust-Resistant Black Oxide Coating
MODEL 67376-4 : Rustler® 4X4 VXL: 1/10 scale 4X4 stadium truck, fully-assembled, waterproof electronics, Ready-To-Race® , With TQi™ 2.4 GHz 2-channel radio system, Traxxas Stability Management (TSM)® , VXL-3s™ speed control, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Rustler 4X4 VXL with Velineon VXL-3s and 3500 Kv motor TQi 2.4 GHz radio system High quality maintenance tools Includes speed pinion
What You’ll Need:
Batteries
Rustler 4X4 VXL accepts a wide variety of NiMH (6–7 cell) and LiPo (2s–3s) batteries.
Charger
AA Alkaline Batteries
The RC Stadium Truck Redefined
Rustler® 4X4 VXL is a hard-charging wheelie machine that captures the speed and style of a stadium truck and injects it with a massive dose of strength and power. Beneath Rustler’s clipless body, the extreme Velineon® brushless power system feeds power through the factory-installed Extreme Heavy Duty Upgrade Kit to become the new standard for strength and durability.
Extreme HD Upgrade Kit
Rustler 4X4 VXL’s factory-installed Extreme Heavy Duty Upgrade Kit replaces key drivetrain and suspension components with beefed-up parts made for ultimate strength and durability. From the HD suspension arms to the steel wheel hubs, this is the strongest driveline ever offered in a Rustler.
Self-Righting
Rustler 4X4 VXL uses Traxxas’ patented self-righting feature to keep the fun going, even when you get carried away with the wheelies or land that big trick upside down. Simply press a button on the TQi™ transmitter and, in most circumstances, Rustler 4X4 VXL will be back on its wheels in just seconds and ready for more action (requires 3-cell LiPo battery).
Clipless Body Mounting
Rustler 4X4 VXL uses a clipless body latching system for secure mounting and fast, one-handed removal and installation. The sleek, aerodynamic body features a rugged internal structure and external rollover protection for long life and Traxxas-Tough™ durability.
Innovation
Rustler 4X4 VXL is packed with innovative engineering, even in the smallest details, to deliver a powerful and tough truck that’s all about speed, durability, and performance.
Unparalleled Strength
Engineered for maximum strength, the Extreme Heavy Duty Upgrade Kit fortifies Rustler with a full complement of driveline and suspension parts designed to work together as a complete package. Combined with Traxxas’ HD suspension arms, Rustler 4X4 VXL sets a new standard for brushless durability.
Low-CG Chassis
Rustler 4X4 rides on a low-CG chassis for improved handling and extra stability. The low center of gravity and wide track width helps the Rustler 4X4 stay planted in the turns for thrilling high speed fun.
HEAVY DUTY SLIPPER CLUTCH
Rustler 4X4 VXL’s heavy-duty slipper clutch uses alloy pressure plates and high-temperature aluminum pads for superior power handling. The slipper clutch delivers equal power distribution front to rear for instant throttle response through the drive system and aggressive four-wheel-drive grip.
Heavy Duty 4X4 Drivetrain
The super-efficient shaft-driven four-wheel-drive system uses an extruded aluminum center driveshaft that joins the front and rear differentials with smooth-running internal splines.
Self-Righting
If Rustler 4X4 VXL should happen to land rubber side up at some point, just press a button on the TQi transmitter and in most circumstances, Rustler will flip itself back onto its wheels in seconds. Traxxas’ patented self-righting feature keeps the fun going and no one else has it!
Rustler 4X4's rugged and innovative clipless body latching system delivers secure mounting and easy one-handed removal. Battery changes are fast and there are no body clips to keep up with. The internal body cage with integrated roof skid and molded wing strengthens the body for extra-long life.
Velineon 3s Power
Velineon® equals extreme brushless horsepower. The power system is optimized for speed and acceleration, from the patented Traxxas High-Current connector to the custom-wound 4-pole motor. The system delivers the ultimate in efficiency, speed, and run-time along with refined control. It’s brushless performance the Traxxas way: wicked fast and easy to use.
Waterproof Electronics
Experience 4X4 fun year-round no matter what the weather conditions. Thanks to Traxxas’ patented innovative waterproofing solutions, water, mud, and snow won’t slow down Rustler 4X4 VXL. Drive where you want, when you want—the only limit is your imagination.
TQi Radio System
The high-output Traxxas TQi™ 2.4 GHz radio system delivers superior range, 30-model memory, and maximum control. Add sensors and the (Traxxas Link Wireless Module, (both sold separately) to send real-time telemetry to your smart phone using the free Traxxas Link™ app. Learn More
Wheelie Bar
A wheelie bar is an absolute necessity on a vehicle with the power and speed potential of the Rustler 4X4 VXL. It’s perfectly positioned for massive wheelies on demand that live right on the edge of control!
Traxxas Stability Management (TSM)® works behind the scenes to help harness the Rustler 4X4 VXL’s extreme brushless power for maximum acceleration and ultra-precise control. Adjust the amount of assistance from off to 100% right from your transmitter. Learn More
Details
Modular Chassis
Rustler 4X4’s modular chassis features front and rear bulkheads that remove easily with just a few screws. In less than a minute using a power screwdriver, you’ll have full access for easy service and adjustment.
Velineon 3500 Motor
A sensorless Velineon 3500 Kv motor delivers extreme performance with nearly zero maintenance. Ultra high-temperature Neodymium magnets, high-speed bearings, and a precision, 4-pole balanced rotor deliver smooth running and long life.
VXL-3s ESC
The waterproof Velineon VXL-3s speed control is packed with technology to deliver maximum power. Large heat sink, integrated on/off switch, and three programmable drive profiles top the feature list. Two-stage low voltage detection allows full LiPo compatibility, including powerful 11.1-volt 3s packs!
Waterproof Receiver Box
Rustler’s innovative waterproof receiver box allows easy access to the receiver. The antenna and servo wires route neatly through a patented watertight seal to protect the receiver from water. No matter what the weather, Rustler 4X4 is ready for action!
5-Channel Receiver with Failsafe
The TQi 2.4 GHz radio system stores up to thirty models in memory, allowing you to use one transmitter for your entire RC garage. Integrated telemetry ports in the receiver transmit real-time data to the TQi transmitter when using the Traxxas Link™ App and telemetry sensors (sold separately). In the event of signal loss, the receiver automatically returns the throttle to neutral and holds the last steering position.
Talon EXT 2.8" Tires and Black Chrome Wheels
Rustler’s large 2.8" black chrome wheels provide terrain-conquering ground clearance and a commanding presence. Talon™ EXT tires have a square-shouldered, aggressive tread design to dig into gravel, dirt, and grass for incredible 4X4 traction and huge roost.
Ultra Shocks
Oil-filled Ultra Shocks™ utilize dual X-ring technology for a perfect seal and silky-smooth performance. The large oil capacity and rugged design soaks up big jumps and off-road abuse for smooth driving performance. They are easy to tune with a wide range of available oils, springs, and pistons.
Single-Screw Motor Access
Rustler 4X4’s innovative motor mount holds the Velineon 3500 motor securely in place and yet releases instantly with just one screw. Gear-mesh adjustments are fast and easy.
Digital High-Torque Waterproof Steering Servo
Rustler 4X4 VXL’s extreme speed and quick reflexes require a steering servo that’s both strong and fast. The included digital high-speed, high-torque servo features ball bearings for precise control and quick reflexes.
Sealed Differentials
Rustler 4X4 VXL’s sealed front and rear differentials utilize steel-gear internals for maximum durability. Silicone gaskets and X-ring seals allow you to tune the amount of locking action by varying the viscosity of the fluid inside the differentials.
Front and Rear Bumpers
Tough reinforced bumpers protect the chassis against impacts. The specially designed front bumper provides a high approach angle that allows the Rustler to climb up and over obstacles with ease. The rear bumper mounts a perfectly positioned wheelie bar to help prevent Rustler 4X4 VXL from back-flipping from its explosive power.
Heavy-Duty Suspension Arms
Heavy-duty suspension arms are stronger than ever before. Molded from a tough new composite material, the arms stand up to even the most punishing drivers and resist breakage for non-stop fun behind the wheel.
Extruded Aluminum Driveshaft
A one-piece extruded aluminum driveshaft is both strong and lightweight. Internal splines fit directly onto the input shafts of the front and rear drive assemblies. Altogether, this shaft runs straight and true for ultra-smooth driveline operation.
Progressive Rate Springs
Progressive rate springs are lighter through the initial range of travel to maintain traction and composure over small ruts and bumps. Hit the big jumps and the springs tighten up to prevent bottoming out the chassis at the extreme ranges of the suspension travel.
Maxx-Duty Driveshafts
Rustler 4X4’s Maxx-duty® driveshafts with beefed-up U-joints are built to handle brushless power without breaking a sweat. Large 6 mm axles key into the included steel wheel hexes for unmatched strength and durability.
Optimum-Geometry Steering with Integrated Servo Saver
A dual-bellcrank design pivots on rubber-sealed ball bearings for smooth action in the harshest conditions. The integrated cam-type servo saver protects the servo gears from crash impacts without sacrificing steering precision.
Heavy-Duty 32-Pitch Gears
Designed from the start to handle big brushless horsepower, Rustler’s 4X4 driveline uses a rugged spur gear with large 0.8 module/32-pitch teeth for reliability no matter how much power you pour on.
Heavy-Duty 4 mm Turnbuckles
Rustler 4X4 uses the same heavy-duty steel 4 mm turnbuckles developed for the Slash 4X4. Broad flat sections make toe and camber adjustments easy with the included wrench. The fully captured rod ends take a beating and won't pop apart during rigorous off-road pounding.
Reinforced Body
Rustler’s painted body comes trimmed and pre-painted with the decals already applied. Tough internal reinforcements maintain the body’s integrity while roof skids provide rollover protection to keep the body looking fresh.
Functional Rear Wing
The functional rear wing reduces drag while still providing valuable downforce for high speed stability. The wing mounts directly to the internal body reinforcements for lasting durability.
Secure Body Latch
Rustler’s clipless body mounts on specially designed shock towers. The easy-to-use latch unlocks instantly with the quick swipe of a thumb and locks again with a noticeable detent to let you know it’s securely fastened.
Rugged Battery Hold-Down
Rustler’s innovative battery hold-down features a beefed-up latch for solid locking action to keep batteries secure no matter how wild the action gets.
Rubber-Sealed Ball Bearings
Maximizing speed requires as little friction as possible. Rustler 4X4 rides on precision rubber-sealed bearings for super low-friction performance and maximum protection in dusty environments. They are used throughout the truck and are virtually maintenance free.
Wheelie Bar
A wheelie bar is an absolute necessity on a vehicle with the power and speed potential of Rustler 4X4 VXL. The reinforced wheelie bar provides additional impact resistance for the bumper and also protects the wing during 100-foot wheelies.
Fixed Gear Adapter
Rustler’s fixed gear adapters take the guesswork out of setting your gear mesh with five preset gearing positions. Insert the motor screw through the desired gearing position for a perfect gear mesh every time. The fixed positioning also keeps the gear mesh tight, even after the harshest landings.
Extreme HD Suspension Components
Rustler 4X4 VXL comes outfitted with the Extreme Heavy Duty Upgrade Kit already installed for ultimate strength and durability. The axle carriers, caster blocks, and steering blocks are beefed up with more material and stronger construction.
