Battery & Charger
Sold Separately
Rustler 4X4 Brushless
Name:
Type:
Stadium Truck
Speed:
35+ mph with 2s LiPo battery, 50+ mph with 3s
Skill Level:
1
1/10
5.12 pounds (2.32 kg)
18.78 inches (477 mm)
12.94 inches (329 mm)
Front Track:
Rear Track:
6.35 inches (161 mm)
11.62 inches (295 mm)
Center Ground Clearance:
1.1 inches (27 mm)
Driveline:
Shaft driven 4WD
Transmission:
Single speed
Hardened steel bevel, sealed, limited slip
Gear Ratio (Internal):
13.97:1
32 pitch
Steering Servo:
2057 metal gear waterproof
TQi™ Sport 2.4 GHz 2-channel radio with TSM®
Battery Compartment Specs:
162 mm X 50 mm X 23 mm, 25 mm
Name:
Velineon V3200 (patent pending)
Motor Type:
Sensorless brushless
7.48 ounces (212 g)
3.15 inches (80 mm)
Diameter:
1.53 inches (39 mm)
Shaft Size:
5 mm
Connector Type:
3.5 mm Bullet
Name:
VX3 Electronic Speed Control
ESC Type:
Brushless
Voltage Range:
2-cell or 3-cell LiPo (NiMH not supported)
Case Size:
2.40″ (61 mm) x 2.09″ (53 mm) x 1.69″ (43 mm)
4.20 ounces (119 g)
BEC Voltage:
6.0 volts
Motor Connectors:
3.5 mm Bullet
Battery Connectors:
35+ mph with 2s LiPo. 50+ mph with 3s LiPo (no gearing change required) NEW Clipless Painted BodyImproved 4-latch design is even easier to use Reinforced clipless supports resist pull-through damage Rugged roof skids for rollover protector Molded composite plastic wing Extreme Heavy-Duty Upgrade Kit Installed Caster blocks, axle carriers, and steering blocks beefed up with extra material Maxx duty driveshafts Oversize diameter 6 mm axles Steel wheel hexes NEW TQi™ Sport 2.4 GHz 2-Channel Radio SystemRemovable grip adapter High-output signal delivers outstanding range Simple one-button programming 30-model memory 3-channel micro receiver with fail-safe security Traxxas Stability Management® (TSM) Improves straight line acceleration and braking on low-traction surfaces Maintains steering composure to allow throttle-on powerslides Never dulls throttle or slows the truck Activated or deactivated directly from the transmitter Large aluminum heat sink with cooling fan NEW Velineon® VX3 Waterproof Electronic Speed ControlThree programmable drive profiles Sport Mode - forward / brake / reverse Race Mode - forward / brake Training Mode™ - 50% forward / brake / 50% reverse (patented) Traxxas EZ-Set® one-button setup Telemetry capable with optional accessories High-Resolution Linear Braking Compatible with 2s and 3s LiPo batteries (NiMH not supported) NEW Velineon V3200 Brushless MotorUltra high-temperature sintered Neodymium magnets provide massive torque and linear power 3200 Kv optimized for power and efficiency in 1/10th scale vehicles 5 mm output shaft Internal & external cooling fans for longer run times Low-maintenance design Efficient, high-speed ball bearings Chassis Low-CG design for responsive handling Modular composite tub design Latching battery strap Reinforced integrated wheelie bar High-approach front bumper to climb curbs Driveline NEW Torque-Biasing Center DriveFull-time shaft-driven 4-wheel drive Oil-filled steel gear front and rear differentials Large 32-pitch steel gears One-piece center driveshaft with center bearing support Suspension NEW Composite GTR ShocksThreaded shock collars for precise ride height adjustment Large oil capacity for consistent damping White powder-coated springs Spring retainers captured with a screw 3.5 mm shaft Durable solid camber links eliminate the need for adjustment Captured rod ends won't pop off Steering NEW 2057 waterproof, metal-gear servoFull metal gear train for improved durability Dual bellcrank design with integrated servo saver Wheels and Tires Large 2.8" black chrome wheels Talon™ EXT tires Sealed Ball Bearings Hex hardware with Rust-Resistant Black Oxide Coating
MODEL 67464-4 : Rustler® 4X4 Brushless: 1/10 scale 4WD stadium truck, fully-assembled, waterproof electronics, Ready-To-Race® , With TQi™ Sport 2.4 GHz 2-channel radio system, Traxxas Stability Management (TSM)® , Velineon 3s brushless power system, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Rustler 4X4 VXL with VX3 ESC and V3200 motor TQi Sport 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
Batteries
Rustler 4X4 Brushless requires a single 2-cell or 3-cell LiPo battery.
Charger
AA Alkaline Batteries
A New Generation of Stadium Truck
Rustler® 4X4 Brushless captures the performance of a stadium truck and injects it with a massive dose of strength and power. Rustler’s new Velineon® 3s brushless power system delivers 4-wheel burnouts and 50+ mph speed right out of the box with no gearing changes required. New GTR shocks deliver an ultra-plush ride to power over rough terrain without breaking a sweat. With more power and performance than ever before, Rustler 4X4 remains the ultimate stadium truck.
New 3s Brushless Horsepower
Rustler 4X4’s new Velineon 3s power system is a brushless powerhouse that transforms 3s LiPo power into brutal acceleration and 50+ mph speed, out of the box with no gearing changes required. The fan-cooled VX3 speed control is feature-packed and simple to use with Traxxas EZ-Set® one-button programming. The powerful V3200 motor is the pinnacle of speed, power, and efficiency.
New GTR Shocks
New composite GTR shocks complement Rustler’s 4X4’s long-travel suspension to create a supremely plush ride. GTR shocks hold over 70% more oil than standard Ultra Shocks for consistent damping performance. X-ring seals keep oil in and dirt out for smooth suspension compression and rebound. Spring preload and ride height changes are as simple as turning the threaded collar and the spring retainers are captured with a screw so they can't pop off.
New Clipless Body
Rustler 4X4 receives an updated clipless body mounting system with four latches, one above each wheel, for quick and easy removal. Just press down on the body and the latches lock tight with a reassuring snap. The sleek, aerodynamic body features a rugged internal structure with body reinforcements to reduce the likelihood of pull-through damage.
New Sledgehammer ST Tires
Rustler puts its brushless 3s power to the ground thanks to the outstanding grip of its new high-performance Sledgehammer® ST tires. The Sledgehammer’s open-block tread design clears away mud and debris for unrivaled traction on loose surfaces. Large 2.8” RXT 6-spoke black wheels give Rustler 4X4 a powerful stance.
Enhanced Suspension Performance
Rustler 4X4’s revised suspension maximizes performance across all surfaces and allows the chassis to soak up bumps to put the power down. New GTR shocks dramatically improve suspension compliance on rough terrain while Rustler’s low-CG chassis delivers razor-sharp cornering and stability.
Unparalleled Strength
Engineered for maximum strength, the Extreme Heavy-Duty Upgrade Kit fortifies Rustler with a full complement of driveline and suspension parts designed to work together as a complete package. Combined with Traxxas’ HD suspension arms, Rustler 4X4 sets a new standard for brushless durability.
Heavy-Duty 4X4 Driveline
Rustler’s shaft-driven four-wheel-drive system uses a rigid center driveshaft with center bearing for extra support. A new Torque-Biasing Center Drive absorbs driveline shocks and distributes power equally between the front and rear. Power reaches the wheels through massive Maxx-duty® driveshafts with 6 mm axles for unbeatable strength and durability.
Clipless Body Mounting
Rustler 4X4 features a new clipless body that’s even easier to use. No body posts, no clips – just drop the body onto the chassis and snap it into place for a secure hold. When it’s time to change the battery, depress the tabs above the wheels and lift up to access the chassis in just seconds.
TQi Sport Transmitter
The TQi™ Sport transmitter packs the range and performance of the TQi into a compact design for maximum comfort and portability. The ergonomic grip features a removable adapter to accommodate smaller hands and simple one-button programming for ease-of-use. A class-leading high-output 2.4 GHz signal delivers the outstanding range and glitch-free performance required by Rustler’s blistering speed.
Traxxas Stability Management (TSM) works behind the scenes to harness Rustler 4X4's extreme brushless horsepower. TSM maximizes acceleration and braking by keeping Rustler 4X4 arrow straight without pulling power or dulling throttle response, even on low-traction surfaces. TSM can also be switched off directly from the TQi Sport transmitter.
Modular Simplicity
A modular chassis design allows the entire front section to be removed with just 5 screws, and the rear assembly with just 4 screws. In less than a minute using a power screwdriver, you have full access for easy service and adjustment.
Details
Tough Reinforced Bumpers
Tough reinforced bumpers protect the chassis against impacts. The specially designed front bumper provides a high approach angle that allows the Rustler to climb up and over obstacles with ease.
Body Reinforcements
Rustler’s clipless body latches mount to tough external body reinforcements that spread out impact forces to reduce the likelihood of pull-through damage. Additionally a roof skid protects the body during self righting and mount securely to internal braces underneath the body.
Functional Rear Wing
Rustler 4X4's functional rear wing reduces drag while still providing valuable downforce for high-speed stability. The wing mounts directly to the internal body reinforcements for lasting durability.
Extreme HD Suspension Components
Rustler 4X4 comes outfitted with the Extreme Heavy Duty Upgrade Kit already installed for ultimate strength and durability. The axle carriers, C-hubs, and steering blocks are beefed up with more material and stronger construction.
Heavy-Duty Suspension Arms
Heavy-duty suspension arms are stronger than ever before. Molded from a tough composite material, the arms stand up to even the most punishing drivers and resist breakage for non-stop fun behind the wheel.
Dual Bellcrank Steering
A dual-bellcrank design pivots on rubber-sealed ball bearings for smooth action in the harshest conditions. The integrated cam-operated servo saver protects the servo gears from crash impacts without sacrificing steering precision.
Waterproof Receiver Box
Rustler’s innovative waterproof receiver box allows easy access to the receiver. The antenna and servo wires route neatly through a patented watertight seal to protect the receiver from water. No matter what the weather, Rustler 4X4 is ready for action!
Metal Gear Servo
Rustler 4X4 features a new servo with the durability of an all-metal gear train. The new servo delivers quick, precise control with the security and convenience of fully waterproof construction.
3-Channel TQi Sport Receiver
The TQi Sport receiver is compatible with all TQi and TQi Sport transmitters. A built-in failsafe returns the throttle to neutral and holds the steering in the last known position in the event of a signal loss. The receiver features full Inclinometer and telemetry functionality accessible through a TQi radio using the Traxxas Link app.
The fully waterproof VX3 ESC transforms 11.1 volts of LiPo power into 50+ mph performance with the simplicity of Traxxas’ EZ-Set® one-button programming. A large aluminum heat sink with cooling fan keeps temperatures down for longer run times. The VX3 comes loaded with high-tech features like race-inspired High-Resolution Linear Braking and real-time telemetry via Traxxas Link™.
Velineon V3200 Motor
Designed for 3-cell LiPo power, the V3200 motor is optimized for extreme power and efficiency with a large 5 mm output shaft. Ultra-high temperature sintered Neodymium magnets provide massive torque and linear power. The unique low-maintenance design features high-speed ball bearings with both internal and external cooling fans for consistent high-power output, run after run.
Clipless Battery Strap
Rustler 4X4 holds batteries securely in place with the convenience of a rugged clipless battery strap. Swing the heavy-duty strap up and out of the way to swap batteries. Once loaded, just snap the tab into the latch and your battery stays safe and secure until you release it.
Low-CG Chassis
Rustler 4X4 rides on a low-CG chassis for improved handling and extra stability. The low center of gravity and wide track width helps the Rustler 4X4 stay planted in the turns for thrilling high speed fun.
Fixed Gear Adapter
Rustler’s fixed gear adapter takes the guesswork out of setting your gear mesh with five preset gearing positions. Insert the motor screw through the desired gearing position for a perfect gear mesh every time. The fixed positioning also keeps the gear mesh tight, even after the harshest landings.
Durable One-Piece Camber Links
Durable one-piece camber links are perfect for bashing because they maintain proper suspension geometry and never require adjustments. Captured rod ends provide unmatched durability and they won't pop off.
Wheelie Bar
A wheelie bar is an absolute necessity on a vehicle with the power and speed potential of Rustler 4X4 Brushless. The reinforced wheelie bar provides additional impact resistance for the bumper and also protects the wing during 100-foot wheelies.
Maxx-Duty Driveshafts
Rustler 4X4’s Maxx-duty driveshafts with beefed-up U-joints are built to handle brushless power without breaking a sweat. Large 6 mm axles key into the included steel wheel hexes for unmatched strength and durability.
Sealed Differentials
Rustler 4X4's sealed front and rear differentials utilize steel-gear internals for maximum durability. Silicone gaskets and X-ring seals allow you to tune the amount of locking action by varying the viscosity of the fluid inside the differentials.
Rigid Center Driveshaft
The one-piece center driveshaft is ultra-rigid for maximum power transfer between the differentials, but still flexible enough to resist impact damage. A central bearing support ensures the driveshaft runs straight and true, even at high RPM.
Heavy-Duty 32-Pitch Gears
Designed from the start to handle big brushless horsepower, Rustler’s 4X4 driveline uses a rugged spur gear with large 0.8 module/32-pitch teeth for reliability no matter how much power you pour on.
Rustler 4X4’s Torque-Biasing Center Drive absorbs shocks to improve driveline durability and distributes equal power to all four wheels for mind-blowing acceleration. It’s easy to tune for different traction surfaces by replacing the oil inside the sealed housing.
