Battery & Charger
Sold Separately
Rustler 4X4 BL-2s
Name:
Rustler 4X4 BL-2s
Type:
Stadium Truck
Skill Level:
1
1/10
5.13 pounds (2.33 kg)
18 inches (457 mm)
12.94 inches (329 mm)
Front Track:
Rear Track:
6.35 inches (161 mm)
11.6 inches (295 mm)
Center Ground Clearance:
1.10 inches (27 mm)
Driveline:
Shaft-driven 4WD
Hardened steel bevel, sealed, limited slip
Gear Ratio (Internal):
12.81:1
32 pitch
Steering Servo:
2056 high-torque waterproof
2.4 GHz 2-channel radio
Battery Compartment Specs:
162 mm X 50 mm X 25 mm
Name:
BL-2s 3300 Kv
Motor Type:
Sensorless brushless
7.51 ounces (213 g)
3.15 inches (80 mm)
Diameter:
1.42 inches (36 mm)
Shaft Size:
3 mm
Motor Connector Type:
Traxxas Quick Connect Motor Plug
Name:
BL-2s Electronic Speed Control
ESC Type:
Brushless
Case Size:
1.53″ (39 mm) x 2.31″ (59 mm) x 1.21″ (31 mm)
3.07 ounces (87 g)
Motor Connectors:
Battery Connectors:
Clipless Body
Tough front and rear bumpers
Reinforced inner cage
Rugged roof rollover protector
Quick and easy removal
Holds tight for intense action
Extreme Heavy Duty Upgrade Kit Installed
Strengthened C-hubs, axle carriers, and steering blocks
Extreme heavy duty driveshafts
Oversize diameter
6 mm axles
Steel wheel hexes
TQ™ 2.4 GHz Transmitter
Full-size 2-channel transmitter
All-day comfort with precise long-range control
BL-2s™ Waterproof Electronic Speed Control
Heat sink accepts accessory cooling fan
Three Programmable Drive Profiles
Sport Mode - Forward / Brake / Reverse
Race Mode - Forward / Brake
Training Mode™ - 50% Forward / Brake / 50% Reverse (patented)
Built-in two-stage low-voltage detection for LiPo batteries
NiMH battery packs: 6-7 cells (7.2 to 8.4 volts)
LiPo battery packs: 2 cells (7.4 volts)
BL-2s Brushless Motor
Integrated cooling fan
Low-maintenance design
Efficient ball bearings
3300 Kv
Steering
Chassis-mounted 2056 servo
Dual bellcrank design with integrated servo saver
Chassis
Modular composite tub design
Secure battery hold-down latch
Low-CG design
High-angle bumpers
Suspension
Heavy duty suspension arms
Oil-filled Ultra Shocks™
White powder-coated springs
Driveline
Full-time shaft-driven 4-wheel drive
Oil-filled steel gear front and rear differentials
Large 32-pitch steel spur gear
Wheels and Tires
2.8″ gray RXT wheels
All-terrain Talon™ EXT tires
Rubber-Sealed Ball Bearings
Precision Hex Hardware
MODEL 67164-4 : Rustler® 4X4 BL-2s: 1/10 scale 4X4 brushless stadium truck, fully-assembled, waterproof electronics, Ready-To-Race® , with TQ™ 2.4 GHz 2-channel radio system, BL-2s™ speed control, and clipless painted body. Requires: battery and charger.
What’s In The Box:
Rustler 4X4 with BL-2s ESC and 3300 Kv motor Quick Start Guide TQ 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
Batteries
Rustler 4X4 requires a single 6-7 cell NiMH or 2-cell LiPo battery.
Charger
AA Alkaline Batteries
Four AA alkaline batteries for the TQ transmitter.
A NEW BREED OF STADIUM TRUCK
Rustler® 4X4 is the definitive go-to machine for speed, agility, and unstoppable 4WD traction. Beneath the reinforced clipless body, Rustler’s chassis sits low and wide for increased stability and sharp handling. Rustler’s BL-2s™ brushless power system delivers effortless power for all-day fun with an added boost of torque for 4-wheel burnouts and lightning-fast acceleration. Additionally, Rustler 4X4 comes standard with Traxxas’ Extreme Heavy-Duty Upgrade Kit to become the new standard for strength and durability.
BL-2s Brushless Power System
Rustler 4X4’s BL-2s brushless power system ramps up the fun with up to 60% more speed and faster acceleration than comparable brushed power systems. Improved efficiency, high-speed ball bearings, and an internal cooling fan allow Rustler 4X4 to run battery after battery for all-day fun. With no brushes to wear out, the BL-2s 3300 Kv is long-lasting and requires virtually no maintenance.
Rustler 4X4’s factory-installed Extreme Heavy-Duty Upgrade Kit replaces key drivetrain and suspension components with beefed-up parts made for ultimate strength and durability. From the HD suspension arms to the steel wheel hubs, this is the strongest driveline ever offered in a Rustler.
Clipless Body Mounting
Rustler 4X4 uses a clipless body latching system for secure mounting and fast, one-handed removal and installation. The sleek, aerodynamic body features a rugged internal structure and external rollover protection for long life and Traxxas-Tough™ durability.
Unparalleled Strength
Engineered for maximum strength, the Extreme Heavy-Duty Upgrade Kit fortifies Rustler with a full complement of driveline and suspension parts designed to work together as a complete package. Combined with Traxxas’ HD suspension arms, Rustler sets a new standard for durability at skate parks, race tracks, and backyards.
Low-CG Chassis
Rustler 4X4 rides on an extended low-CG chassis for extra stability. The low center of gravity and wide track width helps Rustler stay planted in the turns for thrilling high speed fun.
Clipless Convenience
Rustler 4X4’s rugged and innovative clipless body latching system delivers secure mounting and easy one-handed removal. Battery changes are fast and there are no body clips to keep up with. The internal body cage with integrated roof skid and molded wing strengthen the body for extra-long life.
Waterproof Electronics
Your RC experience should be filled with fun and adventure, not limited by the electronics. Traxxas’ patented waterproof technology gives you the freedom to live out your wildest adventures, regardless of the weather
The waterproof BL-2s electronic speed control packs powerful features like three separate drive profiles, low-voltage detection for LiPo batteries, patented Training Mode™, and Thermal-Shutdown Protection to prevent overheating. The sensorless BL-2s 3300 Kv motor with integrated cooling fan delivers strong brushless performance with nearly zero maintenance.
TQ 2.4 GHz Radio System
The TQ™ 2.4 GHz radio system keeps the focus on having fun, not worrying about interference from other vehicles. The TQ radio’s advanced programming provides long-range control with smooth, glitch-free performance and its ergonomic design is comfortable for all-day driving.
Modular Simplicity
Rustler 4X4’s modular chassis design allows the entire front section to be removed with just 5 screws, and the rear assembly with just 4 screws. In less than a minute using a power screwdriver, you have full access for easy service and adjustment.
Details
Gray 2.8" RXT Wheels and Talon EXT Tires
Rustler’s gray 2.8" RXT wheels provide terrain-conquering ground clearance and a commanding presence. Aggressive Talon™ EXT tires dig into dirt and grass for outstanding 4X4 traction. The EXT’s tire compound provides extra durability on pavement with a unique design that resists “ballooning” at high speeds.
Hex Hardware
Rustler 4X4’s hex-drive hardware provides a more positive and secure connection than other fasteners. The black-oxide coating provides a rust resistant high-tech look and feel.
Long-Travel Suspension
Rustler 4X4 has huge amounts of seemingly bottomless, ultra-plush suspension travel to swallow up jumps and delivers incredible control. Performance-optimized suspension components provide maximum articulation without binding or interference.
Oil-Filled Ultra Shocks
Rustler 4X4’s oil-filled Ultra Shocks™ utilize X-rings for a perfect seal and super-smooth performance. Adjust the ride height and pre-load on the white powder-coated springs with the included spacer clips. Ultra Shocks are fully tunable with a wide range of oils, springs, and pistons available.
Innovative Chassis
Rugged Battery Hold-Down
An innovative battery hold-down features a beefed-up latch for solid locking action to keep batteries secure no matter how wild the action gets.
The patented High-Current Connectors funnel maximum power to the vehicle’s electronics. High-Current Connectors also provide the quickest, safest charge for Traxxas batteries.
Waterproof Receiver Box
Rustler’s waterproof receiver box keeps the receiver safe and dry while still allowing easy access for maintenance. The antenna and servo wires route neatly through a patented water-tight seal for true all-weather fun.
3-Channel Receiver with Fail-Safe Security
In the event of signal loss due to an accidental transmitter switch-off or depleted batteries, the receiver automatically returns the throttle to neutral and holds the last commanded steering position. The fail-safe programming is conveniently built-in and does not need to be activated.
Digital Steering Servo
The Traxxas 2056 steering servo provides powerful steering authority on tough terrain with 80 oz-in of steering muscle. The fully-waterproof servo uses special O-ring seals to keep the fun going even when things get wet.
Dual-Bellcrank Steering with Servo Saver
Rustler 4X4’s dual-bellcrank design pivots smoothly even in the harshest conditions. An integrated cam-type servo saver protects the steering servo from crash impacts without sacrificing steering precision.
Clipless Body
Rustler 4X4 uses a rugged clipless body latching system for secure mounting and easy one-handed removal. The latching system incorporates an internal body cage that greatly strengthens the body for long life. The body comes pre-painted and cut with decals already applied.
Heavy-Duty Suspension Arms
Molded from our toughest composite material, Rustler 4X4’s heavy-duty suspension arms provide just the right amount of flex to resist breaking—even in cold weather! From skate parks to 10-foot ramps, these suspension arms stand up to even the most punishing drivers for non-stop fun behind the wheel.
Tough Reinforced Bumpers
Tough reinforced bumpers protect the chassis against impacts. The specially designed front bumper provides a high approach angle that allows the Rustler to climb up and over obstacles with ease.
Extreme Suspension Components
Rustler 4X4 comes outfitted with the Extreme Heavy-Duty Upgrade Kit already installed for ultimate strength and durability. The axle carriers, caster blocks, and steering blocks are beefed up with more material and stronger construction.
Large 32-Pitch Gears
Rustler’s 4X4 driveline is built to handle standard brushless horsepower power and even the extreme Velineon 3s brushless power upgrade down the road. The spur gear features large 32-pitch teeth for total reliability no matter how much power you pour on.
Upgraded Slipper Clutch
Rustler 4X4’s slipper clutch features larger alloy pressure plates and high-temperature aluminum pads for superior power handling. The slipper clutch delivers equal power distribution front to rear for instant throttle response through the drive system and aggressive four-wheel-drive grip.
Maxx-Duty Driveshafts
Rustler 4X4’s Maxx-duty® driveshafts with beefed-up u-joints are built to handle brushless power without breaking a sweat. Large 6 mm axles key into the included steel wheel hexes for unmatched strength and durability.
Sealed Steel-Gear Differentials
Sealed steel-gear differentials are ready to handle brushless power without costly upgrades. Silicone gaskets and X-ring seals allow the differentials to be tuned for specific running conditions by varying the viscosity of the oil inside them. Rustler 4X4’s modular chassis design makes differential access quick and easy.
