Battery & Charger
Sold Separately
Revo 3.3
WARNING: This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Name:
Revo 3.3
Type:
Monster Truck
Speed:
45+ mph
Skill Level:
4
1/10
10.3 pounds (4.69 kg)
20.65 inches (525 mm)
17.6 inches (447 mm)
Front Track:
17.5 inches (445 mm)
Rear Track:
11.02 inches (280 mm)
13.7 inches (348 mm)
Center Ground Clearance:
4.25 inches (108 mm)
Driveline:
Shaft-driven 4WD
Transmission:
Auto two-speed fwd/rev with OptiDrive®
Bevel gear, sealed, limited slip
Gear Ratio (Internal):
25.55:1 (1st gear) 16.31:1 (2nd gear)
1.0 metric pitch (Mod 1)
Steering Servos:
Dual 2075 digital high-torque waterproof
Fuel Tank Size:
150 cc
TQi™ 2.4 GHz 3-channel transmitter with TSM® receiver and 6511 Wireless Module
Engine Name:
TRX® 3.3 Racing
Fuel Type:
Nitromethane
Displacement:
3.3 cc
Starter:
Electric EZ-Start®
Carburetor:
Two-needle slide carburetor
Air Filter:
Dual-stage foam
ProGraphix® Painted Body
Pre-painted body with applied decals
Tough front and rear tube bumpers
Adjustable wheelie bar
TRX® 3.3 Nitro Racing Engine
Large bore piston and sleeve deliver extreme power
Oversized dual-stage air filter
Polished aluminum dual-chamber tuned exhaust pipe
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
EZ-Start® Electric Starting System
Lights the glow plug and cranks the engine with the push of a button
Status LEDs
Includes starter battery and charger
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
Blue-Anodized Aluminum Chassis
Blue-anodized 3 mm aluminum 3D semi-monocoque chassis
Tall 4.25" center ground clearance
Rugged front and rear skid plates
Large 150 cc fuel tank extends run time
Includes Traxxas Link™ Wireless Module
Factory installed speed, RPM, and temperature telemetry sensors
Multi-Function knob
5-channel TSM micro receiver (6533) with fail-safe security and integrated telemetry ports
Includes 1200 mAh NiMH receiver pack battery
Enclosed radio box protects sensitive electronics from dirt and fuel spills
Transmission
Ultra-compact, fewer moving parts
Low rotating mass for quick, high-revving acceleration
Constant drive engagement is smooth and instantly responsive
Sealed case protects the gears and two-speed from debris
Rubber seals for smooth, trouble-free performance
Driveline
Shaft-driven four wheel drive
Tunable front and rear sealed, limited-slip gear differentials
Large diameter semi-metallic brake disc
Extreme deflection for the most suspension travel
Finned aluminum alloy pressure plates
Steering
Dual digital waterproof high-torque Traxxas 2075 steering servos
Heavy-duty bellcrank with integrated servo saver
Suspension
Progressive pushrod rocker-actuated suspension
Shocks are rigidly mounted to the chassis to minimize crash damage
Sealed pivot ball suspension arms
Springs and Shocks
Precise GTR™ shocks provide smooth, consistent damping performance
Threaded shock bodies for precise ride height adjustment
Hard-anodized PTFE-coated shock bodies with TiN coated shock shafts
Red powder-coated springs
Wheels and Tires
Pre-glued 6.3" tall Maxx® tires with performance foam inserts
3.8" Mirror-chrome Geode™ wheels
17 mm splined hex
Precision metric hex hardware throughout
MODEL 53097-3 : Revo® 3.3: 1/10 scale 4WD nitro monster truck, fully assembled, Ready-To-Race® , with TQi™ 2.4 GHz radio system with Traxxas Stability Management® , Traxxas Link Wireless Module, TRX® 3.3 Racing Engine, and painted body.
What’s In The Box:
Revo 3.3 with TRX 3.3 engine Quick Start Guide TQi 2.4 GHz radio system with installed wireless module Starter box with battery and charger 5-cell 1200 mAh receiver pack battery Fuel bottle, spare filter & glow plug, and maintenance tools
