Traxxas Pro Scale® Lighting
Traxxas LED lighting sets the standard for adventure after dark with authentic shadow-chasing brightness on the trail. Now, Traxxas LED lighting is even more realistic with the new Pro Scale Advanced Lighting Control System. The Pro Scale system puts you in command of high- and low-beam headlights; turn signals; brake lights; reverse lights; and even hazard signals for the ultimate in scale off-roading.
Pro-Scale Realism
All the lighting control of a full-scale truck is at your fingertips. Turn the headlights on and off, and select high or low beams. Signal for turns, with automatic cancellation. The brake lights glow when you slow or stop. Hit reverse, and backup lights glow automatically. The Pro Scale system makes it easy.
Multiple Driving Modes
The Power Module puts you in control. In Daytime Mode, the headlights and taillights are off. As the sun sets, choose Low Mode to activate the tail lights and low-beam headlights. High Mode turns on the high beams for trail-blasting brightness. In all modes, the brake and reverse lights operate automatically.
50+ MPH SPEED
Traxxas Link and the optional Wireless Module make it easy to configure your lights your way, right from your iOS or Android device. Switch individual lights on and off, assign lights to each mode setting, and add additional LED accessories to the Lighting Power Module with just a touch. You’re in control.
Video
Overview Video
Get a detailed look at how the Pro Scale Advanced Lighting system brings ultimate scale realism to your TRX-4 Scale and Trail Crawler.Application Guide
Pro Scale lighting requires the Pro Scale Lighting Control System, along with the LED light set and Installation Kit for your specific model. Traxxas makes installation simple with detailed step-by-step instructions and illustrated diagrams.
*All LED light kits and installation kits sold separately. Install LED lights kit(s) prior to installation of the Pro Scale Advanced Lighting Control System.
**Includes additional amber and/or reverse lights (as required by model).
† Includes additional amber, fog, and reverse lights. LED light kit 8030 for Land Rover® Defender® (model 82056-4) is not compatible with the Pro Scale Lighting Power Module.
