Customized Style and Strength
The Pro Scale Aluminum Wheel System is the easiest and most advanced way to add aluminum beadlock style to your Maxx Slash or Unlimited Desert Racer. The Pro Scale Aluminum Wheel System uses tough 6061-T6 aluminum wheel centers and beadlock rings combined with pre-glued belted tires on tough nylon wheels. The result is the beauty and strength of aluminum with superior tire-holding strength and unmatched resistance to bending.
Start with pre-glued tires, then choose your wheel centers. Add trim rings and wheel washers to complete the look.
Modular Design
With a 4-piece modular design, you can customize your Pro Scale Aluminum Wheels to match your style. The modular design makes it fast and easy to change worn out tires for fresh new rubber, without the hassle of messy tire gluing.
Eye-Catching Color
Pro Scale Aluminum Wheel Centers are available in silver, gray and bronze. Pro Scale Aluminum Beadlock Rings and Wheel Washers are available in eight beautifully anodized colors.
Traxxas Tough
The Pro Scale Aluminum Wheel system uses tough 6061-T6 aluminum that resists damage from small impacts. Maxx® SC tires are molded in a long-wearing rubber compound and the internal belting limits high-speed tire expansion for a larger, flatter contact patch and game-changing precision.
Easy Installation
Traditional beadlock wheels require time-consuming and complicated tire mounting procedures. The Pro Scale Aluminum Wheel System features pre-glued tire and foam assemblies with nested Pro Scale aluminum wheel centers and beadlock rings that require only six screws per wheel.
