Battery & Charger
Sold Separately
Nitro Slash
WARNING: This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Name:
Nitro Slash
Type:
Short Course Truck
Speed:
50+ mph
Skill Level:
4
1/10
5.76 pounds (2.61 kg)
22.24 inches (565 mm)
11.65 inches (296 mm)
Front Track:
Rear Track:
7.40 inches (188 mm)
13.07 inches (332 mm)
Driveline:
Rear-wheel drive
Transmission:
Nitro Magnum 281
Steel composite planetary
Gear Ratio (Internal):
2.81
32 pitch
Steering Servo:
2055 high-torque
Size:
3.3 cc
Starter:
Electric EZ-Start®
Carburetor:
Two-needle slide carburetor
Air Filter:
Single-stage foam
Tank Size:
150 cc
Engine Name:
TRX® 3.3 Racing
Fuel Type:
Nitromethane
Displacement:
3.3 cc
Starter:
Electric EZ-Start®
Carburetor:
Air Filter:
Dual-stage foam
Race Replica ProGraphix® Painted Body
Pre-painted body with applied decals
Scale dimensions and looks of actual short course race trucks
Scale front and rear tube-style bumpers
TRX® 3.3 Racing Engine
Large bore piston and sleeve deliver extreme power
High-volume dual-stage air filter
Tuned exhaust pipe
Slide carburetor
Knife-edged connecting rod
Large aluminum blue-anodized cooling head
Super-light piston and rod
High-performance ball bearings
EZ-Start® Electric Starting System
Lights the glow plug and cranks the engine with the push of a button
Status LEDs
Includes starter battery and charger
Blue-Anodized Aluminum Chassis
Strong 6061-T6 aluminum construction
Fiber composite upper deck
Large 150 cc fuel tank
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
TQi 2-channel transmitter
Programmable multi-function knob
Adjustable steering and throttle percentage (dual rates)
Adjustable steering and throttle end points
Enclosed receiver and battery box
Transmission and Driveline
Adjustable slipper clutch
Planetary gear differential
Large diameter brake disc
Heavy-duty driveshafts
Steering
High-torque Traxxas 2055 steering servo
High-performance bellcrank system minimizes bump steer
Suspension
Adjustable steel turnbuckles
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
White powder-coated springs
Wheels and Tires
Pre-glued short course racing tires with foam inserts
SCT chrome wheels with color-molded beadlock-style trim ring
Backed by Unparalleled Traxxas Support and Parts Availability
MODEL 44056-1 : Nitro Slash® : 1/10 scale 2WD nitro short course truck, fully assembled, Ready-To-Race® , with TQi™ 2.4 GHz radio system with Traxxas Stability Management® , TRX® 3.3 Racing Engine, and painted body.
What’s In The Box:
Nitro Slash with TRX 3.3 engine Quick Start Guide TQi 2.4 GHz radio system with TSM Starter box with battery and charger Fuel bottle, spare filter & glow plug, and maintenance tools
What You’ll Need:
Nitro Fuel
Traxxas Top Fuel, 20% or 33%
Eight AA Alkaline Batteries
Four AA alkaline batteries for transmitter, four AA alkaline batteries for receiver pack.
