Nitro Rustler
WARNING: This product can expose you to chemicals including Nitromethane, which is known to the State of California to cause cancer, and Methanol, which is known by the State of California to cause birth defects or other reproductive harm. For more information go to
www.P65Warnings.ca.gov .
Name:
Nitro Rustler
Type:
Stadium Truck
Speed:
50+ mph
Skill Level:
3
1/10
4.41 pounds (2 kg)
17.25 inches (438 mm)
12.5 inches (318 mm)
Front Track:
Rear Track:
12.38 inches (314 mm)
6 inches (152 mm)
11.31 inches (287 mm)
Driveline:
Rear-wheel drive
Transmission:
Nitro Magnum 281™
Planetary gear
Gear Ratio (Internal):
2.81
32 pitch
Steering Servo:
2055 high-torque
Size:
2.5 cc
Starter:
Electric EZ-Start®
Carburetor:
Two-needle slide carburetor
Air Filter:
Single-stage foam
Tank Size:
75 cc
Engine Name:
TRX® 2.5
Fuel Type:
Nitromethane
Displacement:
2.5 cc
Starter:
Electric EZ-Start®
Carburetor:
Painted Body
Pre-painted body with applied decals
Aggressive, aerodynamic body with rear wing
TRX® 2.5 Racing Engine
True ABC construction for long life
Dual-needle carburetor for easy tuning
High-volume air intake system with filter
Aluminum piston with oil groove
Channeled-beam connecting rod
Tuned exhaust system
EZ-Start® Electric Starting System
Lights the glow plug and cranks the engine with the push of a button
Status LEDs
Includes starter battery and charger
Maintains steering composure to allow throttle-on powerslides
Never dulls throttle or slows the vehicle
Blue-Anodized Aluminum Chassis
Strong 6061-T6 aluminum construction
Fiber composite upper deck
TQi 2-channel transmitter
Programmable multi-function knob
Adjustable steering and throttle percentage (dual rates)
Adjustable steering and throttle end points
Transmission and Driveline
Adjustable slipper clutch
Planetary gear differential
Large diameter brake disc
Telescoping U-joint driveshafts and yokes
Steering
High-torque Traxxas 2055 steering servo
High-performance bellcrank system minimizes bump steer
Suspension
Adjustable steel turnbuckles
Springs and Shocks
Fully adjustable oil-filled Ultra Shocks™ with X-ring technology
White powder-coated springs
Wheels and Tires
Pre-glued Alias® step-pin rear tires and ribbed front tires with performance foam inserts
2.8" Mirror-chrome All-Star™ wheels
MODEL 44096-3 : Nitro Rustler® : 1/10 scale 2WD stadium truck, fully assembled, Ready-To-Race® , with TQi™ 2.4 GHz radio system with Traxxas Stability Management® , TRX® 2.5 Racing Engine, and painted body.
What’s In The Box:
Nitro Rustler with TRX 2.5 engine Quick Start Guide TQi 2.4 GHz radio system with TSM Starter box with battery and charger Fuel bottle, spare filter & glow plug, and maintenance tools
What You’ll Need:
Nitro Fuel
Traxxas Top Fuel, 20% or 33%
Eight AA Alkaline Batteries
Four AA alkaline batteries for transmitter, four AA alkaline batteries for receiver pack.
