Sledge Technology: TQi Radio System with TSM
Ultimate Convenience and Control for the Sledge
Precise control and long-range reliability are a must when you’re in command of a 70+ mph 1/8 scale truck. Traxxas delivers with the TQi radio system and the innovative Traxxas Stability Management® (TSM) system. As you drive, TSM seamlessly corrects your steering inputs to prevent fishtailing and spinouts so you can put down full 6s power—even in loose conditions that challenge even the best drivers. The full-featured TQi is also Traxxas Link enabled for pro-level tuning, easy model management, and telemetry capability via your smart device and the free Traxxas Link app when you add the optional Wireless Module. Simply put, no other RTR radio system is as versatile, powerful, and feature packed as the TQi.
Easy, Instant TSM Adjustment
It’s simple to dial in as much or as little TSM assistance as you like, right from the TQi transmitter. Just twist the Multi-Function Knob to increase or decrease TSM’s input, or even turn it off completely. There’s no need to power-down or access the receiver. No matter how much or how little stability assistance you prefer, TSM never limits throttle so you always have full 6s power. TSM is engineered to help you have more fun, not hold you back.
Premium Feel, Long-Range Control
The TQi transmitter’s ergonomic case, ball-bearing-supported wheel, padded steering grip, and smooth trigger action deliver the superior feel and precision you expect when operating a high-quality, high-performance vehicle like Sledge. And with its powerful 2.4GHz signal, TQi delivers the long-distance control that lets you pull the trigger on 70+mph knowing you’re in complete command. Other brands’ basic systems can’t offer that kind of confidence.
Real-Time Telemetry, Pro-Grade Adjustability
When you add the optional Wireless Module to your TQi and install the free Traxxas Link app on your smart device, you can view, record, and share Sledge’s speed, RPM, and speed control temperature on a customizable dashboard. No extra sensors are required, they’re built into the Velineon power system. Traxxas Link also gives you pro-grade tuning and setup controls via the Drive Effects screen, and you can save multiple profiles for each vehicle stored in the TQi’s 30-model memory.
30-Model Memory
Basic radio systems can only pair with one model at a time. Sledge’s TQi transmitter can operate an entire fleet of Traxxas models—up to thirty in all, each stored and retrieved automatically from Traxxas Link Model Memory. For example, if you bind Sledge’s TQi to your TRX-4 Bronco, X-Maxx, and Slash 4X4 VXL, the TQi will automatically load the settings for those models. Power-off your Sledge and the transmitter, then power the transmitter back up and switch on your TRX-4 or any one of the other stored models, and the TQi will automatically load the saved settings. There’s nothing to select, just switch on and drive.
UP NEXT: Premium High-Torque Servo
