Sledge Technology: High-Torque 347 Servo
Aftermarket-Grade Servo Specs Come Standard on Sledge
Sledge® comes out of the box with a powerful, reliable steering servo that delivers the premium specs that hard-hitting 6s power, high-traction tires, and 70+ mph speed demand. Sledge's 2275 servo competes with aftermarket servos with over 20 pounds (347 oz-in) of torque, and a heat-dissipating aluminum body, meaning there's no need to upgrade.
Metal Gears & Aluminum Mid Case
The High Torque 347 servo has metal where it counts for high strength and effective cooling. Heavy-duty steel gears and dual output-shaft bearings make certain the servo can withstand punishing terrain and pushback from Sledge’s massive Sledgehammer tires. The aluminum mid-case conducts heat away from the internals while increasing case rigidity so none of the 347’s torque is wasted on case flex.
True High-Torque Performance
Sledge’s 347 servo outperforms standard RTR servos, and it’s not even close. With six-volt power, the 347 puts 31% more power into the steering system. Up the voltage to 7.4, and the 347 leaps even farther ahead with an incredible 83% boost in steering torque. Sledge has all the servo muscle required for responsive steering in any terrain—right out of the box, no upgrade required.
#2275 High Torque Servo Specifications |
UP NEXT: Aluminum Motor Cradle
