New High-Torque Waterproof Steering Servos
Get Maximum Steering Authority for your 1/10 Scale Vehicle!
Traxxas new High-Torque servos combine maximum steering authority with a long list of high performance features. Both servos utilize steel gears, dual ball bearings, and an aluminum center section for added heat dissipation. Traxxas High-Torque servos are fully waterproof, not just “water resistant” with a perfect factory fit in nearly all 1/10 scale Traxxas RC vehicles. High-Torque servos are fully compatible with Traxxas Stability Management® (TSM) and provide noticeably faster steering response than stock servos.
High-Torque 400 Red Servo
Torque is what keeps TRX-4's® wheels pointed where you want them to go. Larger wheels provide more ground clearance, but they also require more torque to turn, especially over rock faces. Get the torque you need with the new Traxxas High Torque 400 Red servo. The brushless digital motor provides smooth steering response for precise low-speed maneuvers and over 400 oz-in of torque to pull the wheels out of the deepest ruts.
High-Torque 330 Blue Servo
Designed to shred tough desert terrain, the Unlimited Desert Racer® needs powerful steering response to hold course through the deepest sand. The new High Torque 330 blue provides 330 oz-in of torque to handle the most demanding desert trails. The powerful digital coreless motor provides the speed and power necessary for a 50+ mph desert truck. Designed for perfect drop-in installation in UDR, E-Revo® VXL, and most 1/10 scale Traxxas vehicles, the High Torque 300 Blue has all the power you'll ever need.
