New 8-Amp EZ-Peak Plus 4s Charger
Enjoy the Safety and Convenience of the Traxxas iD® Charging System
There’s a new charger in the powerful line of Traxxas EZ-Peak® chargers: the 8-amp EZ-Peak Plus with 4S LiPo capability. The new EZ-Peak Plus 4s packs all the same great EZ-Peak features like one-button setup, powerful peak-detecting charging, and the safety and convenience of Traxxas’ exclusive iD® system. An LED progress bar and audible alerts keep you informed while the advanced high-resolution peak detection delivers a perfect charge every time. With up to 8 amps of charging power, the EZ-Peak Plus 4s is the fastest, easiest, and most convenient way to charge your Traxxas batteries.
The iD Advantage
There has never been an easier or safer way to charge your batteries than the Traxxas iD® system. Just plug a Traxxas iD-equipped battery into an EZ-Peak® charger and press Start - that’s all there is to it! Traxxas pioneered this exclusive iD technology to eliminate complicated charger programming. The iD system detects which Traxxas iD-equipped battery you are using and automatically configures the charger’s settings for the optimal charge.
Power & Convenience
The faster your batteries charge, the sooner you’re back out having fun. No one understands this better than Traxxas which is why we outfitted the EZ-Peak Plus 4s with 8 full amps (75 watts) of charging power. NiMH batteries charge faster than ever with 5 amps of charging power. LiPo batteries charge even faster with up to 8 full amps. A large 40 mm cooling fan keeps the temperatures down inside the charger for extended charging sessions. A balance port is built into the charger for older-style LiPo batteries with external balance leads. The EZ-Peak Plus 4s combines EZ-Peak power with the safety of Traxxas' exclusive iD technology in one convenient and easy-to-use package.
EZ-PEAK® PLUS 4S FEATURES |
Traxxas EZ-Peak Family of Chargers
