Learn to Jump Your RC Vehicle Like a Pro
How to Perform Flips and Tricks
If you’ve ever seen a Traxxas RC freestyle show at a motorsports event then you’ve seen trucks like the X-Maxx and E-Revo catch some crazy air. With a little practice, you can learn to jump and rotate your truck in the air like the pros. The key to rotation is precise throttle control. Watch this video to see how the pros use throttle input to control their vehicles and learn some tips for your own freestyle sessions.
You don’t need any fancy equipment to start practicing jumps. Build a makeshift ramp in your backyard or try the local skate park, but always be aware of your surroundings! An RC truck flying through the air at 50+mph can cause serious damage to property, pets, or yourself. Start off slowly with smaller jumps and work your way up. Once you master the basics, the sky’s the limit!
Meet the RC Trucks
At over two feet long and nearly 20lbs, the X-Maxx is a massive truck, but its perfect weighting and 30+ volts of brushless power make it agile in the air. Huge tires and a nearly bottomless suspension soak up hard landings for repeated jump sessions. If you’re looking for big time thrills, look no further than the X-Maxx.
The new E-Revo is custom-made for your wildest tricks. Blistering power and a high-tech chassis make the E-Revo perfect for almost any stunt. E-Revo’s radical chassis flexes to absorb and distribute stress while the hardened drivetrain puts the power to the ground. From all-out speed runs to 20-foot triple backflip jumps, the E-Revo stands as the ultimate expression of power, strength, and speed.
You’ll find Slash 4X4 VXL hydroplaning across lakes and bashing in backyards and skate parks across the country. When it comes to doing it all, nothing beats the Traxxas Slash. With a 60+mph top speed, TSM stability control, and legendary durability, the Traxxas Slash 4X4 VXL is limited only by your imagination.
