Skip to main content
Receive Traxxas News
  • Model Showroom
  • Parts & Accessories
  • Batteries & Chargers
  • Community
  • Support
  • News
  • On Sale
latest news
Installing WideMaxx kit
How to Install the WideMaxx® Suspension Kit for the Traxxas Maxx
Get Even More Handling Performance from Your Maxx
The Traxxas Maxx offers outstanding rough-terrain handling with its long-travel suspension. For even greater stability in extreme terrain, especially when running the Maxx with full 4-cell LiPo power, Traxxas offers the 8995 WideMaxx Suspension Kit. The kit is available in six different colors and includes a complete set of upper and lower arms, toe links, and stiffer rear springs. Installation is easy, and can be completed in less than an hour. Just follow these steps.
Step-By-Step Video
8995 WideMaxx Suspension KitPlacing the WideMaxx arms next to the standard ones, the extra width is obvious
The 8995 WideMaxx suspension kit’s arms are 20 mm longer than the stock parts for a total width increase of 40 mm (just over 1.5 inches). Longer toe links are also included in the kit (not shown).
You can use the tools supplied with the Maxx, but for faster, easier wrenching, we recommend the 8712 7-Piece Metric Hex and Nut Driver Essentials Set. This set includes all the hex- and nut-driver bits required to work on all Traxxas models, plus a convenient carrying and storage pouch. TIP: The optional 8720 Large handle allows you to apply more torque with less effort for easier tightening and loosening of larger fasteners, such as the Maxx’s 8 mm wheel nuts and 4 mm screw pins.
8012 Tool Kit
Required Tools
  • 2.0 mm hex wrench or driver
  • 2.5 mm hex wrench or driver
  • 8 mm nut driver or kit-supplied box wrench
1) Begin by removing the wheels using an 8 mm nut driver or the wrench supplied with your Maxx. Remove the 4 mm screw pins (arrowed) to release the front steering hub and rear axle carrier. Also remove the 3x18 button-head that secures the toe link to the steering block.
Remove the wheelsRemove the wheels
Unscrew the Steering BlocksUnscrew the Steering Blocks
Unscrew the Axle CarriersUnscrew the Axle Carriers
2) Remove the caster block/steering block assembly and rear axle carrier. The female halves of the driveshafts will come out with them.
Remove the Steering BlocksRemove the Steering Blocks
Remove the Axle CarriersRemove the Axle Carriers
3) The bumpers and skid plates must be removed to access the lower suspension arms. Remove the arrowed 4x25 mm button-head screws. Next, turn the chassis over and remove the 4x10 mm countersunk screws from the front and rear skid plates.
Remove the 4x25 mm ScrewsRemove the 4x25 mm Screws
Remove the Countersunk ScrewsRemove the Countersunk Screws
4) Flex the bumper and skid plate up, and pull it away from the chassis. The wheelie bar will come off with the rear skid plate.
Remove the Bumper and Skid PlateRemove the Bumper and Skid Plate
Remove the Wheelie BarRemove the Wheelie Bar
5) The arrowed screw pins and a 4x12 mm button-head screw hold the suspension arms in place. Remove the button-head screw and slide the tie bar mount and the metal tie bar off of the suspension pins.
Remove Screw PinsRemove Screw Pins
Remove the Tie BarRemove the Tie Bar
6) Remove the lower suspension arms and pins. Next, remove the screw pins and upper arms. The screw pins and suspension pins will be reused for the WideMaxx arms.
Remove the Lower Suspension ArmsRemove the Lower Suspension Arms
Remove the Upper Suspension ArmsRemove the Upper Suspension Arms
7) Reverse the disassembly steps to install the WideMaxx arms. The lower arms are labeled LF - RR (Left Front - Right Rear) and RF - LR (Right Front - Left Rear) to help with proper installation. The upper arms are all identical, just flip them over for the proper orientation. The tie bars are labeled F (front) and R (rear), install accordingly.
Lower Suspension ArmsLower Suspension Arms
Suspension Arm OrientationSuspension Arm Orientation
Tie Bar OrientationTie Bar Orientation
8) Here are the arms in their correct orientations. The arrows point towards the front of the Maxx.
Right FrontRight Front
Right RearRight Rear
Left FrontLeft Front
Left RearLeft Rear
9) With the new arms in place, you can now reinstall the steering block/caster block and rear axle carriers. The caster blocks and axle carriers are labeled R and L to indicate right and left, and the driveshaft halves are keyed to maintain correct universal-joint alignment. There are marks in the shafts to show correct alignment, but you can just rotate the female half until it slides over the male half. The shafts only fit together when properly aligned, so it’s goof-proof.
Reinstall Steering & Caster BlocksReinstall Steering & Caster Blocks
Parts Labeled Left and RightParts Labeled Left and Right
Line Up DriveshaftsLine Up Driveshafts
10) Reinstall the screw pins to secure the caster blocks and rear axle carriers. Next, reinstall the front and rear skid plates by reversing the previous steps.
Reinstall Caster BlocksReinstall Caster Blocks
Reinstall Axle CarriersReinstall Axle Carriers
Reinstall Skid PlatesReinstall Skid Plates
11) Replace the stock toe links with the WideMaxx kit’s longer versions. Remove the button-head screw that secures the toe link and install the new link. Note that the toe links have a different type of hollow ball in each end. The end with the taller, hourglass-shaped hollow ball is the bellcrank end.
Replace Stock Toe LinksReplace Stock Toe Links
Install WideMaxx Toe LinksInstall WideMaxx Toe Links
Hollow Ball OrientationHollow Ball Orientation
12) The longer WideMaxx arms call for stiffer springs, which are included with the kit. The springs are “blue,” indicated by a spot of blue paint on each spring. Install the blue springs on the rear shocks, and replace the front springs with the springs you removed from rear shocks. A screw secures each spring perch. Remove the screw, then push up on the perch and slide it off the shaft to remove the spring. To recap:
-Replace the rear springs with the BLUE springs.
-Move the rear springs to the FRONT shocks.
-The stock front springs are not used.
Replace SpringsReplace Springs
Remove the Old SpringsRemove the Old Springs
13) Reverse the steps to install the new spring. Be careful not to mix up the front and rear springs when swapping them. Reinstall the button-head screws that secure the shocks and toe links, and the WideMaxx Suspension Kit installation is complete!
Install the New SpringsInstall the New Springs
Reinstall ScrewsReinstall Screws
Now that your Maxx is an extra 1.57″ wider, you’ll experience ever greater stability and high-speed cornering grip.
Standard MaxxStandard Maxx
WideMaxxWideMaxx
