Three of Our Most Popular Models Now Accept Long-Format Batteries
The Traxxas Bandit, Rustler, and Stampede are three of the best-selling RC trucks of all time. Until now, the short-format “hump pack” has been the preferred battery for these models. There’s an exciting new change happening that will now allow you to share your long-format batteries across nearly the entire Traxxas lineup. New 2WD Bandits, Rustlers, and Stampedes (including VXL models) now feature extended battery trays to accommodate both short-format “hump pack” and long-format “flat pack” batteries.
The two batteries on the left feature the same voltage and capacity. One battery features six powerful NiMH cells in rows with a single cell on top. These are commonly called “hump pack” batteries and they measure 139 mm long. The long-format battery or “flat pack” is 162 mm long and features the same six NiMH cells, but has a single cell at the end. In the past, all 2WD Bandit, Rustler, and Stampede trucks would only accept the short-format batteries. A new chassis for all three models features a longer battery tray that will accept both short and the long-format batteries typically associated with Slash models. This means you can now buy one long-format battery and use it in nearly every Traxxas model.
Identifying the Changes
If you recently purchased a Bandit, Rustler, or Stampede, you may have some questions about which battery you should use. The easiest way to determine this is to check the box panels. They will indicate which battery is included inside or if you should choose a long-format or short format battery.
Examine the Chassis
The new chassis features a longer battery tray and revised speed control mounts. These are the only two parts that change on the vehicles. This means all current parts and accessories that you have now will also fit the new long-format chassis. The easiest way to tell which vehicle you have is to measure the battery tray. If your battery tray measures approximately 139 mm, you should shop for shorter hump pack batteries. If your battery tray is approximately 164 mm, you can use either short or long format batteries. Have a look at the two versions below to identify your models.
For 2nd Generation Batteries, Use the Battery Finder Below.
Convert Your Existing Chassis to a Long-Format Chassis
If you already own a Bandit, Rustler, or Stampede with a short-format chassis and you want to use long-format batteries, Traxxas has you covered. Transfer all of your existing parts and accessories over to the new long-format chassis and add a revised speed control mounting plate and you’ll be able to share one long-format battery between most of your Traxxas vehicles. Just choose your vehicle below and click on the button to buy the necessary parts.
2WD Bandit / Bandit VXL
(Requires 3722R & 3725R)
2WD Rustler / Rustler VXL
2WD Stampede / Stampede VXL
(Requires 3622R & 3626R)
