Battery & Charger
Sold Separately
Maxx
Name:
Maxx
Type:
Monster Truck
Speed:
60+ mph with 4s LiPo battery and optional gearing
Skill Level:
4
1/10
10.40 pounds (4.7 kg)
22.50 inches (572 mm)
15.95 inches (405 mm)
Front Track:
Rear Track:
9.12 inches (232 mm)
13.85 inches (352 mm)
Center Ground Clearance:
2.6 inches (67 mm)
Driveline:
Shaft-driven 4WD
Transmission:
Single speed
Sealed, hardened steel bevel, limited slip
Gear Ratio (Internal):
12.37:1
1.0 metric pitch
Steering Servo:
2090 digital high-torque waterproof (285 oz-in)
TQi™ 2.4 GHz transmitter with TSM® receiver
Battery Compartment Specs:
186 mm X 48 mm X 43 mm
Name:
540XL
Type:
2400 Kv sensorless brushless
317 g (11.1 8 oz)
3.58 inches (91 mm)
Diameter:
1.41 inches (36 mm)
Shaft Size:
5 mm
Connector Type:
6.5 mm bullet connectors
Name:
Velineon VXL-4s
Type:
Brushless
Case Size:
72 mm L x 59 mm W x 49 mm H
7.09 ounces (201 grams)
Motor Connectors:
Battery Connectors:
Traxxas High-Current Connectors
VXL-4s™ Waterproof Electronic Speed Control 3s–4s LiPo compatible Built-in cooling fan Real-time telemetry via Traxxas Link Machined heat sinks 10-gauge silicone wire Integrated protection circuits LED status lights Velineon® 540XL Brushless Motor Long format brushless motor 4-pole 2400 Kv 5 mm output shaft Aluminum heat sink Cooling fan 55+ mph out of the box using single 4s LiPo battery (sold separately) 60+ mph with optional gearing and single 4s LiPo battery (sold separately) Traxxas Stability Management® Helps prevents spinouts and loss of control Adjusts from off to 100% assistance from the transmitter TQi™ 2.4 GHz High Output Radio System Traxxas Link enabled 2.4 GHz 5-channel micro receiver (6533) with fail-safe security and integrated telemetry ports Automatically stores and loads settings for up to 30 Traxxas Link-enabled models Multi-Function knob Adjustable steering and throttle percentage (dual rates) Adjustable steering and throttle sensitivity (exponential) Telemetry-ready 5-channel micro receiver Clipless Body Mount System Quick one-hand installation and removal Uses pivoting rear latch mechanism Eliminates body posts and clips Reinforced for extra protection against tearing Driveline Full-time shaft-driven 4-wheel drive Torque-Biasing Center Drive™ absorbs shocks and distributes power Sealed, silicone fluid-filled diffs with large module ring and pinion gears Splined outdrives attached with external thru-bolt method Heavy-duty Cush Drive™ Extreme-duty telescoping driveshafts Splined aluminum center driveshaft Secure Motor Mounting System Precision, preset gear mesh adjustments Motor retention separate from gear mesh 17 mm keyed wheel hex with 5 mm nut Full-length motor cradle Modular Composite Chassis Extended design interlocks with front and rear bulkheads Absorbs and distributes impact energy Easy to service and access components Driveline is sealed in the chassis to keep out dirt and grit Easy Battery Access Extended battery tray accepts 6700 mAh 4-cell LiPo battery Battery is protected deep in the chassis Battery hold-downs pivot for easy access More secure than conventional retention systems Bumpers Tough energy absorbing front and rear bumpers Lower front and rear skids for impact and abrasion resistance Integrated nerf bars for side impact resistance Wheelie bar with integrated carry handle Large-scale high-output steering servo 285 oz-in of torque 0.18 sec transit speed Triangulated mounting system to fully support case Heavy-duty double-shear bellcranks Suspension WideMaxx® double-shear suspension arms 1.57" (40 mm) wider for improved handling Tough composite formula resists impact damage, even in cold weather Engineered to optimize suspension travel and steering angles All critical suspension points have double shear strength 4 mm machined pivot balls C-hub and steering block geometry maximizes steering angle Fixed, high-strength camber and toe links Steel upper and lower tie bars GT-Maxx® Shocks Machined aluminum threaded body Extra-large bore and capacity Large-diameter damper shaft Lower seal cartridge with dual X-rings Adjustable upper spring retainer Plastic shock caps with pivot balls Lower spring perches bolted on Wheels/Tires Tough 2.8": wheels with keyed 17 mm hex receptor Sledgehammer® extreme tires for sure-footed traction 1-piece foam inserts Pre-glued and ready for action TSM® rated Full contact sealed bearings used in exposed locations
MODEL 89086-4 : Maxx® 1/10 scale monster truck. Fully assembled, Ready-To-Race® , with TQi™ 2.4 GHz radio system, VXL-4s™ brushless power system, and painted clipless body.
What’s In The Box:
Maxx Ready-To-Race monster truck with Traxxas 540XL brushless motor VXL-4s waterproof electronic speed control with integrated telemetry TQi™ 2.4 GHz radio system High quality maintenance tools
What You’ll Need:
LiPo Battery
Traxxas recommends a 4-cell 14.8 V Power Cell LiPo battery for maximum performance. A 3-cell 11.1 V LiPo battery will operate the vehicle with reduced performance. NiMH batteries are not supported.
Charger
The Traxxas EZ-Peak® Live charger 2971 is recommended for easy and fast charging performance.
AA Alkaline Batteries
A New Maxx Legacy Begins
The Traxxas X-Maxx® is a giant that forever changed the face of RC monster trucks. Its radical cutting-edge design, massive size, brutal strength, and unmatched power transformed X-Maxx into the stuff of legends. The 1/10 scale Traxxas Maxx® expertly packages X-Maxx’s innovative design elements and jaw-dropping strength into a lighter, more compact, more ferocious beast. Armed with WideMaxx® suspension and Sledgehammer® tires, Maxx stands ready for high-speed aggressive action from the start. Let the fun begin!
The Maxx Experience
Maxx turns up the dial on fun with even more of what you crave. Maxx doubles down on strength and durability with a longer and wider stance for greater stability to match its blistering 60+ mph performance. Bury the throttle, fly through corners, and let Maxx turn your wildest full-throttle dreams into reality.
60+ MPH Maxx Muscle
Traxxas Velineon® brushless power hits hard with massive 4s punch for an awe-inspiring 60+ mph top speed and effortless wheelies on demand. The high output 540XL motor features a beefy 5 mm shaft, aluminum heat sink, and a powerful fan. Of course it’s all fully protected with Traxxas’ innovative waterproofing.
Traxxas Tough
Maxx is overbuilt with components modeled after the legendary X-Series™ trucks to withstand extreme punishment and intense driving action. The Maxx chassis absorbs and dissipates impact energy across the entire structure for superior strength. Huge threaded-aluminum GT-Maxx shocks with oversized shafts soak up massive jumps for high-flying fun at every turn.
WideMaxx Suspension
WideMaxx suspension technology stretches Maxx’s wheels out for a wider, more stable stance and higher cornering speeds. A long wheelbase chassis further enhances Maxx’s straight-line stability to give Maxx race truck stability to match its brutally tough construction.
Sledgehammer Tires
Huge 5.6” Sledgehammer tires feature an aggressive open-block tread design that clears away mud and debris for unrivaled traction.
More Colors
Maxx makes a statement with several ProGraphix® new clipless bodies with our brightest and boldest color options yet.
WideMaxx from the Start
The popular WideMaxx® kit comes factory installed for rock solid cornering and ultimate stability.
Extended Chassis
Maxx’s energy absorbing chassis extends further to accommodate our most powerful 6700 mAh 4-cell LiPo battery. The ultra-tough composite chassis design with interlocking bulkheads forms a bedrock foundation for the heavy-duty suspension.
Sledgehammer Extreme Off-Road Tires
Large diameter, open tread block tires rain down massive clouds of roost and dominate any surface.
Maxx Muscle
Brutal punch off the line strains the wheelie bar as Maxx launches hard and fast on its way to 60+ mph. The advanced Velineon VXL-4s Electronic Speed Control (ESC) not only puts down the power, but it also has built-in telemetry that provides real-time speed, temperature, and voltage data. Integrated cooling fans on the ESC and the motor provide extended run times.
Integrated Wheelie Bar
A wheelie bar is mandatory equipment to handle Maxx’s wheel-standing acceleration. The wheelie bar helps prevent backflips under full-throttle acceleration and flexes to absorb impacts on less-than-perfect landings. It also features a convenient handle to transport your Maxx to the next adventure.
TQi Radio System
The high-output Traxxas TQi™ 2.4 GHz radio system delivers superior range, precision, and control. It is Traxxas Link enabled so you can add a Wireless Module (part 6511, sold separately) and connect wirelessly to the Traxxas Link™ app using your smart phone. Use it to customize your settings and view real time telemetry from the VXL-4s speed control.
Traxxas Stability Management® (TSM) works behind the scenes to help harness Maxx’s brutal 4s power for maximum acceleration and exceptional control. Go ahead, rip full throttle! TSM never limits power output and works to keep Maxx going where you point it, even when traction is destroyed by spinning tires and massive roost. Adjust the amount of assistance from off to 100% right from your transmitter.
Superior Protection
The unique Maxx chassis design completely encloses the center driveshaft inside a rigid backbone structure for ultimate protection. Rugged, non-structural front and rear skid plates are designed to take all the punishment to protect critical bulkheads and driveline components. After they have done their job, simply replace them and Maxx will look as good as new.
Maxx Duty Drivetrain
Rugged durability is job one for Maxx’s drive system. Maxx utilizes proven components and technology from much larger and heavier trucks resulting in a driveline that has strength to spare. At its core are wide face steel gears, large steel ring and pinion gears, heavy-duty splined driveshafts, and a thick-walled, splined aluminum center driveshaft.
The proven Torque-Biasing Center Drive is optimized for maximum front-to-rear power distribution. It’s tuned to deliver jaw-dropping four-wheel drive acceleration along with massive punch and instant response. Traxxas’ exclusive Cush Drive™ tech absorbs driveline impacts to further improve driveline durability without maintenance or adjustment.
Traxxas Self-Righting
Originally pioneered for the X-Maxx, this exclusive, patent-pending Traxxas innovation uses 4s LiPo power to flip Maxx back onto its wheels after a roll over. In most situations, the fun won’t stop just to rescue an upside down truck.
Fully Waterproof
Water? Mud? Snow? Bring it on! Maxx exploits Traxxas’ patented waterproofing solutions that make the huge difference between being truly waterproof and merely “water resistant.” Traxxas waterproof electronics reliably extend your fun into all kinds of places that used to be off-limits.
Reinforced Clipless Body
Maxx’s innovative clipless body mounting system replaces tiny clips with a rugged latching system. Remove and install the body in seconds with just one hand. A tough cage structure supports the body while supplemental body reinforcements protect the body against wear and damage.
Easy Battery Access
The Maxx battery tray accommodates Traxxas’ most powerful 6700 mAh 4-cell LiPo battery. Maxx cradles and protects the single 4s LiPo battery deep in the chassis and secures it with a snap-lock battery retention system. Proven in trucks like X-Maxx, this innovative Traxxas system is far more durable than traditional methods.
Power Cell LiPo Batteries
Experience full Maxx performance with Traxxas Power Cell LiPo batteries. Power Cell LiPo batteries provide maximum punch off the line and free flowing power for 60+ mph speed runs. Only Traxxas Power Cell batteries offer the safety and one-button charging convenience of patented iD® technology.
Accessory High-Output Light Kit (Sold Separately)
An optional LED Light Kit (part 8990, sold separately) is available for Maxx that features a 40 LED bright white front bar with low and high beams. Out back, a 48-LED light bar features red taillights with working brake and white reverse lights.
Details
Sledgehammer Tires
Outfitted with Traxxas’ legendary Sledgehammer® tires, Maxx is ready for action with multiple layers of biting edges for sure-footed traction on just about any surface. The Sledgehammer’s heavy duty rubber compound is specially formulated to resist tearing and bonds exceptionally well with Traxxas’ Ultra Premium tire glue. The 2.8" wheels have a large glue surface for bead mounting and utilize a 17 mm hex mounting pattern with a flanged locknut.
Full Length Motor Cradle
Maxx is built for all-day action with a full length motor cradle to fully support the 540XL motor and eliminate gear-crunching flex. The innovative fixed gear mesh system precisely sets the gear mesh with fixed pins so you can focus on driving and having fun and never have to worry about gear mesh adjustment.
Shock Tower Design
Maxx’s integrated shock towers are part of the chassis and produce a rigid, triangulated structure for secure mounting of the shocks and body. They also provide an authentic off-road look that fills in the wheel openings of the truck. Sometimes the landing after a jump does not go as planned, so the upper shock mounts are shrouded for protection against impacts and grinding.
Waterproof From the Start
Waterproofing our models has never been an afterthought at Traxxas. Patented Traxxas innovation seals out the water so that your playground is extended through water, snow, and mud. Dirty truck? Just hose it off. The receiver box allows fast radio access without removal.
Maxx Steering Authority
The steering servo in Maxx is the same size as the steering servo used on the giant X-Maxx. With 285 oz-in of torque, it has strength and power in reserve for fast response and incredible steering authority.
Battery Compartment
Maxx accommodates Traxxas' largest Power Cell 6700 mAh 4-cell LiPo battery from the X-Maxx for extended run times and even more thrills. The snap-lock retainer keeps a secure grip on the battery, but releases in seconds.
GT-Maxx Aluminum Shocks
The four extra-large bore, oil-filled GT-Maxx shocks provide super plush damping even on the roughest terrain. Extra-large diameter shock shafts move smoothly through the double X-ring seals for responsive damping. Machined aluminum bodies are threaded to adjust ride height while the lower spring retainers are captured by screws to keep them secure, even on the harshest landings.
Heavy Duty Suspension Arms
The Maxx’s oversized double wishbone suspension arms maintain proper suspension geometry throughout the entire range of travel. Double-shear connections and extra-thick steel upper and lower tie bars provide incredible strength and impact resistance. Tough composites further resist impact damage, even in cold weather.
Modular Chassis Design
The interlocking chassis design ties the shock towers, front and rear modules, and the main frame into a single rigid platform that is engineered to absorb and dissipate impact energy across the entire structure. Critical driveline, radio, and battery components are protected to keep Maxx off the workbench and out having fun. Strategically placed tool access has been thoughtfully put in place to make any needed maintenance or repairs a snap to perform.
Full Contact Sealed Bearings
Maxx utilizes full contact sealed bearings throughout the driveline to keep out the grime and grit. Less downtime for cleaning and maintaining bearings equals more run time for the Maxx.
Shock-Absorbing Cush Drive
Traxxas’ innovative Cush Drive™ uses a special elastomer damper to absorb driveline shocks at the spur gear for superior reliability. Because there is nothing to slip or adjust, Cush Drive provides instant acceleration and throttle control.
The Torque-Biasing Center Drive absorbs shocks to improve driveline durability. The center drive also distributes power to all four wheels for mind-bending four-wheel drive acceleration without the side effects of a typical center differential. Center differentials allow tires in the air to balloon uncontrollably, while the Torque-Biasing Center Drive allows wheelies off the line with seamless power distributed to all four wheels.
Aluminum Splined Driveshaft
A thick-wall, heavy-duty, splined aluminum center driveshaft carries the power to the front and rear differentials. This heavy-duty driveshaft yields precise engagement, incredible strength, and smooth running.
Extreme-Duty Telescoping Driveshafts
Traxxas telescoping splined driveshafts benefit from years of Traxxas design evolution for durable, smooth-running performance you can count on. These extreme-duty driveshafts maximize suspension travel and steering angles to radically extend the Maxx performance envelope.
Steel Gear Differentials
The Maxx’s 4-gear differentials are sealed and filled with heavyweight oil, which provides a limited-slip effect for maximum traction on loose surfaces. The reinforced differentials use 7 mm output shafts along with large-pitch, large-diameter, steel ring and pinion gears for ultimate reliability.
