Page 1 of 2 12 LastLast
Results 1 to 40 of 41
    Aug 2014
    7
    Mudslinger / wheel info
    Hi all, first post.
    Got a 10th scale summit the other day, been after one for ages and finally went for it, I love it!
    So the modding begins......
    I'm going to order some mudslinger 3.8 40 series tires, now I also want some proper bead lock wheel, I'm just unsure of what to order and where from?
    So just after any info on what you run on your own?
    I've searched plenty of posts but just after bit more advice.
    Thanks
    Aug 2014
    346
    I'm using ax8042 axle wraith rims they r good rims and if I was u I would go down on the pinion to about 15 maybe 14 because these r some big tires.
    Aug 2014
    346
    And I also run jumbo kongs they r 8 and a half inch tall they r some tall tires and 4.75inch wide
    2,088
    correct me if ime wrong but aren't you asking about gearing and heat issues in your own thread? we have no idea what his setup is but its probably brushed, your suggesting stock gearing he is most likely running,with the bigger tires on the stock setup 12t pinion or even lower would work with those tires.... I apologize if it sounds rude I don't mean to be....
    Quote Originally Posted by Billgates1234 View Post
    I have run the axial beadlocks and they rubbed hard on the a arms, others have run the narrow version without issues, the axials are nice and strong but make sure they are the narrow version if you go that way.
    Sep 2013
    Maysville,Ky. USA
    773
    The narrow axial bead locks are gonna be hard to find and costly. You could use the wider version with some extended hex hubs from Integy.
    Oct 2013
    424
    Yeah I run the wide sometimes and as Jaman said - they run hard against the a arms. They have actually worn a groove into my a arms. But good luck finding narrows & if you find them they may cost you a kidney
    Aug 2014
    7
    My summit is in standard stock barring a pair of 5000mah lipos.
    I want to use mudslingers but obviously I'm unsure of the wheels.
    Pics would help aswell.
    When you say the wheels rub, how can this be solved
    I plan to either fit a dewalt or go brushless but not sure which set up to use.
    Aug 2014
    7
    Also when you say use the narrow axial wheels which wheels exactly do you mean, part numbers or links would be brilliant.
    Sep 2009
    3,286
    Rc4wd (the makers of the mudslingers) sells about 2-3 styles of beadlock rims that can run on a summit (yes they are costly but that heavy aluminum actually helps when crawling).
    If you are willing to change hub sets from the stock17mm to 23mm then you could go with RedCat Racing 40 series rims (they are narrow and common on ebay) or a set of Proline Chayenne beadlocks (harder to find but worth it)
    MAN, Use Common Sense.
    Outside? THERE IS NO BOX !
    Aug 2014
    346
    I thought the stock pinion was like a 17 lol I only used the stock setup one time and never used it again but OK so if it have a 12 pinion stock he should be OK
    Aug 2014
    346
    If u go brushless u need Upgrades drive shafts Upgrades bearing up grades lol u need alot upgraded
    Aug 2014
    346
    Yes I was asking but I got it fix that's why I said 14 pinion my heat issues r fixed!
    Sep 2009
    3,286
    http://www.axialracing.com/products/ax8043
    I believe this is the axial narrow ereyone is referring to. Double check on the demensions, im not 100% sure.
    Aug 2014
    346
    Yes I see what yall r talking about what the world I'm mad now my a arms has big cuts in them from my beadlock rims wow that's unbelievable I payed all all that money for my rims and tires and they r eating my a arms up
    Aug 2014
    346
    Thier on ebay all day long lol ax8043
    Sep 2013
    Maysville,Ky. USA
    773
    Quote Originally Posted by noir 522 View Post
    Nope wrong ones but there is a used set on eBay starting at 200 bucks .
    Sep 2009
    3,286
    $200? That seller must be trolling the summit boards.
    Sep 2013
    Maysville,Ky. USA
    773
    For 200 bucks I'd buy the real aluminum bead locks from RC4WD. I still want a set of these so bad i can taste it.
    [IMG][/IMG]
    http://int.rc4wd.com/Thorax-40-Serie...el_p_2766.html
    Sep 2012
    173
    Malonefamily2003 those are nice but check out the Huntsman Spiders from rc4wd. Same price as the ones you posted
    http://www.bigsquidrc.com/rc4wd-hunt...eadlock-wheel/
    Im thinking about selling my second Summit to buy a set with Mudslingers
    Aug 2014
    346
    Ttypedan and family2003 yall 2 have some beast of some trucks and yall sure know yall stuff. I have learned alot from yall 2!!
    2,088
    Quote Originally Posted by GarTanz View Post
    AX8046 are the wide ones, they wore a grove in the a arm from rubbing cause they have the metal beadlock both sides, and they are sharp, when the suspension flexes they connect the a arms cutting in.......also if you search guys have narrowed the wide rims to work.
    Aug 2014
    7
    i dont really like these wheels - http://int.rc4wd.com/Thorax-40-Serie...el_p_2766.html
    dont mind theses but not into paying the price - http://www.bigsquidrc.com/rc4wd-hunt...eadlock-wheel/
    also has anyone got a link to the narrow axial wheels? also what size are they?
    Aug 2014
    346
    Hey family2003 they have them demolisher universal rims in in-stock again
    Aug 2014
    7
    will AX8014 wheels work with mudslingers 40 series with out any issues?
    Aug 2014
    346
    This is a joke I looked on rc4wd about 4hours ago and they had the demolisher universal rims in Stock now I came back to buy me some now they out of stock this is bull crap had like 27 in Stock now they all wow
    Sep 2013
    Maysville,Ky. USA
    773
    They have the same specs as the AX8046 so no luck there.
    Sep 2013
    Maysville,Ky. USA
    773
    Try again i just checked it and they had 27 left. I no longer need them myself the ones i made work quite well and are 4 pounds lighter.
    Aug 2014
    346
    How much in all do the tires and rims weigh together?
    Aug 2014
    346
    It said thier out of stock still
    2,088
    I just checked as well and there in stock.....
    2,088
    and then I check again and it says out of stock, there site may be glitching........email them and ask.
    Sep 2013
    Maysville,Ky. USA
    773
    16 pounds for all 4 rims and tires.
  33. #33
    2,088
    dang that's heavy.....
    Quote Originally Posted by malonefamily2003 View Post
  34. #34
    Aug 2014
    7
    is this regarding the ax8014's?
  35. #35
    Sep 2013
    Maysville,Ky. USA
    773
    Yes they have the same specs just a different design.
  36. #36
    Aug 2014
    7
    Can they they be cut and made smaller?
  37. #37
    Sep 2013
    Maysville,Ky. USA
    773
    Yes and it's easy to do . I did basically the same with stock rims to make rims wide enough for my Super Swampers .
  38. #38
    Aug 2014
    346
    Good god dude that's insane I'm no expert but I'm thinking that's putting some strain on that motor wow 16 pounds just with tires and rims that's not even counting the summit that's a good 26 to 30pound in all wow that thing is heavy lol
  39. #39
    Sep 2013
    Maysville,Ky. USA
    773
    The last time i put Overkill on the scales he was around 32 pounds. HEAVY.
  40. #40
    Aug 2014
    346
    Oh and I thought my truck was heavy lol man them swampers u have make my jumbo Kongs look like 2.2 inch mud slingers lol
