Page 2 of 2 FirstFirst 12
Results 41 to 49 of 49
  1. #41
    19,592
    Quote Originally Posted by traxxaspro View Post
    Anyways what settings could my new battery's be charged at
    5600mh 50c 3s lipos
    Also my 2s 5000mh 30c one
    Always abide by the battery manufacturer's recommendations.
    Alt-248 on the number pad =
  2. #42
    Ontario
    662
    general rule is one amp per every 1000 mAh
    so
    5000 mAh 5 amps
    5600 mAh 5.6 amps
    8000 mAh 8 amps
    unless you are charging two batteries in parallel, then double the amps
    Ok thanks and yes I got a parallel board as well
  3. #43
    Ontario
    662
    And the axle snapping begins
    My work station
  4. #44
    Ontario
    662
    Well this is coming in the mail 300w
    http://www.progressiverc.com/the-ticket-350w-combo.html
  5. #45
    Ontario
    662
    First run in the 6s went well nothing broken
    Much faster then the 4s that's for sure
  6. #46
    Ontario
    662
    Hey guys what are optimal running temps for motor n esc ?
  7. #47
    kansas
    8,668
    A temp gun is kind of a must have.....
    Hot motor + cool esc = under geared.
    Cool motor + hot esc = over geared
    Everything warm just right..
    Motor ~ 180/190*F (82/88*C) maximum, ideally 140/160*F (60/71*C), temps can be 10*F higher inside the motor
    ESC ~ pretty much same temps / Fan comes on @ 150*F (65*C)
    The MXL-6S / MM2 fan runs non-stop, also should be taken off when driving in wet conditions.
    Lipo's ~ 140*F (60*C) max, ideally 100/120*F (38/49*C).........
  8. #48
    Ontario
    662
    Thxs and yeah I got a temp gun
  9. #49
    Ontario
    662
    My battery charger box copied mz
    And just because
