Results 1 to 3 of 3
Thread: Tuned Resonator
    Jun 2014
    Guam USA
    7
    Tuned Resonator
    Is there any reason to get swap out the stock resonator for the mid-high? If anyone did was there any difference?
    10,195
    The stock resonator is a dual chamber which helps with the higher rpms. The single chamber is better for the low and may be a little louder.
    I have a THS and low end power increased a bit with a little sacrifice at high.
    SD California
    1,133
    There would be no point in upgrading to the high end resonator, you would be better off putting the money into an aftermarket pipe.
