Results 1 to 8 of 8
Thread: Need some help
    Sep 2013
    8
    Need some help
    Hi, I'm new to this world of rc car, I have a rally 1/16 vxl and I have a problem, what happens is that when running only bends slightly to the left.
    Now you change the (front diff) with the axles and still the same problem ... and not the remote. please help and thanks
    Rotterdam, Netherlands
    7,646
    Did you try to solve it with the steering trim on your transmitter?
    Sep 2013
    8
    if you try it, what I see is that the left axis vibrates a lot., and sorry my English is not very good
    12,316
    Are your knuckles wore out?
    This part-
    7,646
    Vibrations in an axle can be caused by worn bearings or, like Jimmie already explained, worn knuckles.
    7,646
    Quote Originally Posted by wilo View Post
    That looks like a bent axle.
    Aug 2014
    11
    Agreed....or worn out cups in the carrier.
    Pull off the left front. Check the play in the carrier vs. the right. Then pull the carrier and check the axle and bearings. There are two bearings.
