    Oct 2013
    108
    running problems
    Ok so I think I've got an air leak. My engine won't tune and there are bubble in the fuel line. But my tank is good. All of the lines are good to. Is it the carb then. I'm having this same problem with both of my .15 4 tecs
    Gurley, Alabama
    797
    A bad exhaust o-ring, cracked header, bad coupler, or even a broken pipe can all cause fuel pressure problems. How did you check the tank and lines? They can suck air without leaking fuel.
    Oct 2013
    108
    It doesn't leak fuel. I blew in one hole and plugged the other. No Auer leaked. I think it could be the exhaust. I bought a new rubber pipe.
    Oct 2013
    108
    I'll check in a bit
    Aug 2013
    Brazoria, Texas
    1,638
    Tip the car over with fuel in the tank. If the o ring on the tank Is good then it shouldn't leak at all. That caused me so much issues.
    Spartan Jet Boat
    Alias
    Fiero GTP
    Oct 2013
    108
    Ok I let you know in a bit
