Results 1 to 10 of 10
    Jan 2005
    Nuclear Power Plant drainage ditch
    2,714
    Brushed to VXL-3M, Do I need anything?
    Putting the 3m in my sons brushed Merv, do I need anything? Will the brushed motor mount work? Thanks.
    All those who believe psychokinesis raise my hand
    Alma, Michigan
    12,316
    The 3M combo, right?
    Not just the ESC?
    If it is the combo:
    7077 Gear cover/Hardware
    7090 Motor Plate
    7060 Motor Mount
    Jan 2005
    2,714
    Not just the ESC?
    If it is the combo:
    7077Gear cover/Hardware
    7090Motor Plate
    7060Motor Mount
    Yes 3m combo. Good thing I asked. Local hobby store owner said I don't need anything. He said Titan motor mount will work with the 3M motor.
    Dec 2014
    17
    I used the titan motor mount coz I couldn't get the brushless motor mount, just used the slotted holes in the titan mount, just drilled round holes into the slots, had to run the pinion right on the end of the motor shaft to, doesn't run on all of the spur but have had no problems, been running like this for weeks. Will get the brushless mount eventually though.
    Sep 2011
    89
    Did you have the old titan 380 or the new 550?
    Jul 2014
    276
    and if you do go brushless make sure to shim the diffs or at least the rear because its a huge power boost and will make your diffs click.
    Dec 2014
    17
    The new 550, I run 2s and 3s, haven't had any diff issues.
    Jul 2014
    276
    brushed isnt nearly as strong as brushless stkys, on 3s there it might compare to NiMH with brushless...
    how often do you wheelie on 3s?
    i run mine on 3S and with wheeilie bar adjusted for the lowest i can flip it no problem...
    also it depends on what tires you run and where you run
    Dec 2014
    17
    I wrote 550 in response to post, mines 380 brushless, 28/50, wheelies on command at any speed, wheelie bar set at half way, just use throttle to control wheelie, can flip it over backwards no worries, got 2.2 wheels, grass to road, grass to road.
