    Feb 2014
    91
    will these fit the MERV????
    has anyone tried to see if the HPI nitro firestorm wheels will fit our platform with out any major modification?
    http://www.ebay.com/itm/HPI-Nitro-Fi...8#ht_697wt_916
    i really dig the way they look!
    Mar 2014
    38
    The merv comes with 12mm hex, best check that these are.
    Feb 2014
    91
    Quote Originally Posted by richardmarais View Post
    they are 12mm hex, im more curious about the off set and the width of the inner wheel and if i will be able to thread thw wheel nut on.
    Hamburg/Germany
    443
    Yep, HPI Scorch 2.2 will fit.
    They come with an adapter assortment and washers. The smallest inner adapter will fit the diameter of 1/16 Traxxas axles
    Feb 2014
    91
    Quote Originally Posted by CMD-J View Post
    is this similar to the axial wheels where you can also use the bushings from the rocker arms?
    Hamburg/Germany
    443
    I'm not sure how the bushing trick on Axials actually works?
    HPI uses this design on all their 2.2 wheels:
    The pic shows HPI Dish 2.2, but Scorch wheels are the same.
    Feb 2014
    91
    yep, same concept. basically you just use the bushings that come in the rocker arms (part 5123 i believe) and insert it into the wheel just like you would the adapter you are showing. i happened to save mine after i did the bearing swap in the rockers and it worked perfect.
    Mar 2014
    21
    It looks a lot like proline desperadoes it might be easier to get those
