Thread: Tekin RS8 Gen 2
    Jan 2014
    South NJ
    294
    Tekin RS8 Gen 2
    i want to know is possible to put a tekin rs8 gen 2 into a merv and a cc4600kv motor have both just sit around and could i run this set up with 6s lipo 2 3s in series i know that the rs8 can handle 6s lipos
    Kyosho Inferno VE, Anza Slash, Rustler VXL
    Rotterdam, Netherlands
    8,232
    Quite a large ESC to put in a Merv. The problem that you will have to face is to find decent batteries that deliver enough amps.
    The 4600Kv on 6S is useless. That will kill it. Even 4S is above the motor specs.
    If you can get the ESC under the hood, which will be a challenge, I would stick to 3S.
    Hamburg/Germany
    443
    If you allready have a RS8 laying around why not just try to make it fit?
    Castle says you can run the 4600KV up to 3S max -if the car weights below 4lbs. In a car >4lbs only 2S is recommended.
    An average MERV should be around 3-3.5lbs i reckon.
    As Peter mentioned: A Castle 1406 motor will draw a lot of amps. You'll really need to run batteries in parallel to supply enough power. Otherwise you might overwork them and risk to kill your lipos or your esc.
    Jan 2014
    South NJ
    294
    i have the same esc in my kyosho 1/8 buggy and it is smaller than the stock esc so if i have to i will in a way to make it fit
    Hamburg/Germany
    443
    My fault i mixed the Tekin RS2 with RX2 (1/8 scale esc) ..
    RS2 should fit. But the motor limit would worry me, per Tekin website:
    Motor Limit Brushless Mode 2S: 8.5 Turn 2-pole 36mm, 4lb chassis
    Motor Limit Brushless Mode 3S: 10.5 Turn 2-pole 36mm, 4lb chassis
    Castle 1406 4600KV is a 4-pole 36mm motor.
    RS2 is 3S max, 6S will fry it.
    Duh, meant to write RS8 and RX8 above, sorry for the needless confusion..
