Results 1 to 18 of 18
    Feb 2014
    56
    How to solder trx connectors
    I need to solder a traxxas connector for my esc but I have no idea what I do please help
    Mojave Desert
    2,979
    take it to your local hobby shop and they'll do it...probably for a small fee. Mines is charging me only $5 to solder one connector.
    Feb 2014
    56
    I don't really have a local one but I'll try
    Va
    488
    The esc wires comes with solder steady on them. You need to put you iron on the traxxas metal tabs to heat it up then press your solder on to the tab. Heat the tab, not the meat. Then put your esc wire into the solder on the tab. Wait for the solder on the wire to melt. Then take off your iron and it will harden. Check out squirrels videos on YouTube. He has one on how to do traxxas connectors
    Twin Brushless Latrax Teton, .21TM Jato
    Feb 2014
    56
    What's the meat??? And I found out how to from Jang
    19,430
    Quote Originally Posted by ThatdudewithaMERV View Post
    I think duramaxin intended to write "metal" and not "meat".
    Something you have to be very careful about is not letting the solder go past the solder line.
    Alt-248 on the number pad =
    Dec 2013
    Cape Coral, FL
    173
    Yes, no solder past the line or they will never click in place...
    Feb 2014
    56
    Oh hh ok it has a little X and also a line right?
    19,430
    See the Traxxas How-to video:
    How To Assemble a Traxxas High-Current Connector (HCC), especially 1:30 to 1:56.
    13,773
    I must confess, I have cooked a hot dog with a soldering iron... he could have meant meat if he was hungry...8)
    Ya can't polish fertilizer...
    Feb 2014
    56
    Haha how was it
    13,773
    Burnt from the inside out of course 8)
    Feb 2014
    56
    Nice did you eat it :P
    RC Turnbuckle Jr. mwe-maxxowner's Avatar
    Feb 2004
    pageland, sc(south of monroe)
    5,394
    Quote Originally Posted by Lipo-power-please1582 View Post
    I gave up on this. I do the best I can, then trim everything up with a file and a dremel a little at a time until it clicks into the housing properly.
    460, straightpipes, buried throttle, nuff said :D
    13,773
    I just c-clamp a Popsicle stick tightly across that line, and no issues...
    I was hungry... yes I ate it.
    19,430
    I do much the same.
    Feb 2014
    172
    Put foil on the part of the metal tab that you DONT want solder to go onto. Solder won't flow or stick to the foil. You'll get a perfect line. Helps to tape the little tab to a scrap block of wood or something also. Just to keep it from scooting on you.
    Strip the wires to exact length, tin wires, tin metal tabs, hold tab and wire together, apply heat. Solder flows. Done.
    13,773
    I do much the same.
    I think I will try some Italian sausage next...
