Results 1 to 19 of 19
    33
    e revo battery question
    I just got the 1/10th scale e revo brushed, can I switch the nimh batteries to the 11.1 lipo batteries?
    19,278
    No. The EVX-2 electronic speed controller has a maximum rating of 4S. A 3S pack on the BEC side (the plug with the red tag on the wires) can damage the ESC.
    Alt-248 on the number pad =
    33
    Can I switch to lower voltage lipos? Or will it not help?
    19,278
    Two 2S LiPos (7.4V nominal, 8.4V maximum) work fine in the brushed E-Revo.
    Watch the heat of the Titan motors. Large LiPo packs with their accompanying extended runtime don't give the motors a chance to cool down.
    33
    I have the 1/10th scale e revo which voltage lipo battery can I use?
    19,278
    Quote Originally Posted by the boss View Post
    "Two 2S LiPos (7.4V nominal, 8.4V maximum) work fine in the brushed E-Revo."
    Recommended batteries per the Traxxas Battery Application Guide
    Registered User
    A Cube
    59
    the boss, was the unit new or used? Verify it says Low Voltage Detection on the EVX-2 on the front.
    13,773
    Is it possible to run a single 4s pack on an evx2?
    Ya can't polish fertilizer...
    Alma, Michigan
    12,314
    I have read yes and no... if it can be done, it would have to be done in NiMH mode.
    19,278
    I am not willing to try it.
    13,773
    If you cant do it, it would be a bummer for me. I want to put the evx and titan into a slash w/single 4s pack 8(
    33
    Its new I got it yesterday
    33
    Will the lipo 2s 4200 work? Also will it fit?
    Alma, Michigan
    12,314
    I am not sure if it will fit... will it?
    4200mAh is a little on the low side... 5000mAh+ is what I suggest.
    If it were mine, I would go for this one:
    http://spcracingbatteries.com/index....&product_id=66
    33
    Is the brushless battery area the same as the brushed?
    19,278
    Yes, the chassis for both E-Revos and the Summit too are identical.
    33
    How hard is it to convert to brushless does anyone know?
    Alma, Michigan
    12,314
    All it takes is a few parts...
    Motor plate
    Gear cover
    8th scale power system
    May 2010
    315
    Motor plate
    Gear cover
    If you are doing it on the cheap you don't "need" the single motor plate and gear cover, use the stock dual motor plate and cover and just cover up the hole where the other motor used to be.
    2x 2wd Slash|Slash 4x4 PE|MM E-Revo|Grave Digger
