    Jan 2014
    42
    SO whats your basic suspension setup... Bashing and Stability & Cornering
    Thought we made a small database of what are our specs for racing & bashing...
    Lets start like this:
    Bashing:
    Rockers P1, P2 or P3.
    Oil Weight: 50wt to 100wt
    Springs Color Front//Rear
    Wheel Tire combo
    Stability & Cornering:
    Wheel Tire combo
    Lets Roll...
    kansas
    8,436
    Ride Height & Suspension Set~Up:
    My Bash set up:
    P2 Rockers 80 wt Shock Fluid, Blue Rear Silver Front, inner hole, and Traxxas sway bars.
    I set the shock preload by pushing the chassis to the ground.
    If the springs fully compress, back off the preload, if not fully compress increase the preload..
    Will also give you a little more ride height..
    Dec 2013
    25
    P2 Rockers 60 wt Shock Fluid
    Rear: gold springs, upper hole, middle hole.
    Front: orange springs, lower hole, middle hole.
    Traxxas sway bars, center diff (100wt), back diff (50wt), front diff (30wt).
    Great handling.
    Dec 2013
    Norway
    282
    My Bash set up:
    You use the 120mm travel springs with the p2 rockers, not LT rockers? Maybe ill try that too. Need more ride hight..
    Erbe
    Custum Erbe
    Bandit VXL
    Feb 2009
    785
    Quote Originally Posted by ronnyen View Post
    Its not so much that you get more ride height but that they are stiffer springs.
    If it didn't break you can do it again.
    Dec 2013
    Norway
    282
    just adjusted pushrods to inner hole and changed to blue rear and silver springs in front. Lookin' good. Cant wait for tomorrows bashin extravaganze.
    Erbe
    Custum Erbe
    Bandit VXL
    Apr 2013
    Austria
    13
    My Bash Setup:
    P2 Rockers with P3 Pushrods, Middle Hole
    60wt Shock Oil with Black Springs front and Blue in the rear
    Traxxas Sway Bars, 100k Diff Oil front and rear.
    Feb 2014
    Midway Ga
    69
    Bashing,
    Rockers P2
    Oil Weight: Stock 40wt
    Springs Color
    Front-Silver
    Rear-Blue
    Inner hole Front and Rear
    preload set max with out binding springs
    Wheel Tire-Stock but have been Tapped
    Springs Color
    Front-Silver
    Rear-Blue
    outter hole Front and Rear
    preload set about halfway up threads on rear giving it a slight lean forward to help with understeer issues on med acceleration.
    New ERBEWP, going 2s2p 9400mAh
