Results 1 to 34 of 34
    RC Turnbuckle Jr. Jimdog's Avatar
    Iowa City, Iowa, USA
    3,639
    Thinking of getting one.
    My mini isnt good off road so im thinking of getting a stampede 4x4 vxl. I want to get some proline sand paws for it and some tires that I can race around the lawn with. I will probably be going through sand snow grass and dirt. Any gearing recommendations for 2s lipo? Also what tires are good for normal bashing?
    Sent from my SCH-R970 using Tapatalk
    WOW! Look at those pieces fly!
    Oct 2013
    509
    I like my mashers or trenchers for bashing. And honestly i run stock gearing on 2s 12/54 but i have castle sct 3800 in my truck so its a little more power than stock. Sand paws are awesome at the beach and snow. Good truck though veryyyy reliable
    Just my 2 cents
    Wales in the UK
    6,462
    It's an awesome little monster truck man I would say the same as K money you can not go wrong with mashers or trenchers they both rock.I had my trenchers for ages running on and off road and the grip was spot on and the don't wear quick....peace
    3,639
    Would they be good in snow?
    Wales in the UK
    6,462
    I think mashers would be better than trenchers in the snow but no where near as good as sand paws......peace
    RC Champion dgudenau's Avatar
    Michigan
    1,176
    For an all around bashing tire, trenchers seem to take the cake, closely followed by the mashers. As stated above, the sand paws would be ideal for snow and sand running though.
    Anza Slash VXL
    Rustler VXL
    3,639
    Are there any things that need to be addressed out of the box? Weak diffs, weak axles ect.
    Michigan
    1,176
    Quote Originally Posted by Jimdog View Post
    Depending on your driving style and battery used, the rear axles seem to be the weak point for the p4de. Many people upgrade them to either mip or tekno replacements, which both are a bit costly but a good investment none the less. The stock, plastic motor mount also doesn't seem to last. King Headz makes an aluminum replacement that will be a great improvement. Other than that, upgrade as parts break and you should be set.
    Anza Slash VXL
    Rustler VXL
    Wales in the UK
    6,462
    The one thing if running 2s only is the aluminium bearing adapter part number 6893x.But if 3s upgrade the driveshafts to mip,teknos,or traxxas steel cvds and get the kings head motor mountplus if you like the jumps get aluminium shock caps......peace
    3,639
    Ok. So for jumps and 2s abuse I should get a motor mount, and aluminum caps. What is the bearing adapter?
    Wales in the UK
    6,462
    It on the slipper clutch unit and the stock one is plastic and melts so changing it to aluminium is a must to me ....peace
    3,639
    What is the difference between the 2 traxxas aluminum motor mounting plates and the kings head one?
    Wales in the UK
    6,462
    The kings head uses a bigger bearing which needs less maintenance.but I use the traxxas aluminium one with a ceramic bearing and it's running like butter....peace
    Apr 2013
    Burnaby BC
    87
    I only run 2S...
    I've had to upgrade ALL of these except the shockcaps (went Traxxas BigBore instead)
    Kingshead motor mount is a higher quality piece than the Traxxas one...
    My LHS strongly suggested the KH one that he could not supply versus the Traxxas one he could.
    Wales in the UK
    6,462
    The traxxas one is very well made its just the bearing size is smaller.I have had mine over two years and it's been awesome at dissipating heat and stopping chassis flex but you do need a good bearing in thereand I do run 2s and 3s with a tenshock 4 pole torque monster......peace
    Michigan
    1,176
    With 2s you will probably only need the shock caps, bearing adapter, and the rear axles. The kingz head motor/traxxas motor mounts are not a necessity at this point but are a good investment.
    Anza Slash VXL
    Rustler VXL
    3,639
    Whats wrong with the stock motor mount?
    RC Champion No One's Avatar
    May 2005
    Minnesota
    1,136
    Its plastic and has a smaller bearing Vs king headz. Most people that I know run 2s and don't have many issues.
    But the Aluminum bearing adapter is a good idea even on 2s
    Slash 4x4
    Stampede 4x4
    Wales in the UK
    6,462
    The stock one is plastic and it retains heat instead of dissipating it and the aluminium one stops chassis flex....peace
    3,639
    I have a traxxas brushless system on the way. I will put an xq power servo in it. I have a couple fly sky receivers coming. I have my 2s 6500 mah spc ready. I just ordered some desperado wheels snd proline masher tires. Now I need a body, a pinion, and......a roller.
    Wales in the UK
    6,462
    Sounds awesome dude looking forward to seeing how it comes together.....peace
    3,639
    These are the parts I have so far.
    Got my order in for a roller.
    http://m.ebay.com/itm?itemId=111241906044
    Wales in the UK
    6,462
    Nice man it's all starting to come togetherkeep us posted.......peace
    3,639
    I will be getting a proline chevy 2500 hd body and I will paint it black to try to make it look my real truck.
    It'll probably look a bit shorter though.
    Michigan
    1,176
    I really like the look of the proline chevy shell; it should look nice once everything is together. Good luck!
    Anza Slash VXL
    Rustler VXL
    Wales in the UK
    6,462
    That will be a sick body in black dude and an awesome photo of them together....peace
    3,639
    What is different about the traxxas style beads?
    Can anyone explain?
    Wales in the UK
    6,462
    It's the design of the rim that the tyre sits on dude.the traxxas one has no out side lip....peace
    3,639
    I have the final piece on the way. The aluminum bearing adapter. My parts should be getting here in the next week. I am expecting the esc and motor tomorrow. My wheels and tires are supposed to be here on wednesday. The roller should be here on wednesday. Then my body, pinions, and bearing adapter will come on friday.
    Wales in the UK
    6,462
    Wow you are not messing about dude and am stoked on seeing the truck when done......peace
    3,639
    Well. My esc and motor arent herevyet and now the roller isnt expected to be here until next tuesday. I wish I could change to priority mail now.
    Michigan
    1,176
    Ouch. I hate waiting on new parts, but the wait will definitely be worth it.
    Anza Slash VXL
    Rustler VXL
    3,639
    Got it put together. How can I make a shroud to keep snow out?
    Wales in the UK
    6,462
    Look into the material they use to cover home hi if speakers that should stop the snow but still let air get the the brushless setup to keep cool.And use Velcro to hold in on the chassis....peace
