Results 1 to 2 of 2
    Jan 2014
    5
    Idle speed problem
    Hi guys,
    I have a problem with my Traxxas Slayer Pro. I adjust the Idle speed, low-speed and high-speed screws. The engine working fine, sounds great but the idle speed going gradually higher and higher.
    I tried to lower idle speed screw but the engine not start.
    I try to explain with video.
    Thanx.
    10,509
    I can't view the video at work...based upon what you are saying it sounds like a lean LSN as the engine is starving for fuel. Put the idle gap at 1.0mm and leave it. The LSN should start at 1.75 turns from closed (which is flush with the barrel) and may need to be richened from there.
