Page 1 of 3 123 LastLast
Results 1 to 40 of 95
    Dec 2013
    Philadelphia
    61
    Ford fiesta!.... Need tips??
    Wassup RC Drivers.... Im new to this so i would be needing some good advice and important information...
    Im looking to drop a different motor in her (brushless) im looking for power. I was wondering if a 2 cell battery any good? What's a good choice for pinion gears and spur's? should I put some oil shocks in my inventory? I'm also looking for larger wheels that fits something stylish good with handling. So basically I'm trying to put together something fast And furious (R.I.P Paul Walker)
    Any help out there?????
    Alma, Michigan
    12,314
    The stock V380 is pretty powerful... the price gap between that and the next step up is pretty steep with a Neu at around $170. A stock V380 is around $30... just be sure to get a different ESC as the 3M ESC is the weak point. A Castle SV3 makes for a great upgrade.
    A SPC 2S 2500 is a great pack... lots of available amperage for a good amount of punch. They also sell 3S packs, but I found my 3S packs collected more dust than anything else... just too much for where I could run.
    As far as gearing... that depends a lot on you. There is no such thing as the perfect gearing for everybody... there are way too many variables. Start with stock and gear appropriately from there.
    Stock shocks are oil filled... this is a hobby grade RC.
    As far as tires... check out this thread:
    http://traxxas.com/forums/showthread...ape%2C+vintage
    RC Champion dcfox's Avatar
    SE Texas
    1,202
    Traxxas offers a power up trade in program where you can trade your brushed motor/esc in for a brushless setup ar a discounted price.
    "Dude,I almost had you"
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    Brushless would be better right?
    Dec 2013
    Philadelphia
    61
    Thanks for the tips...
    SE Texas
    1,202
    Quote Originally Posted by Streetz Daddi View Post
    Yes...definitely.
    Stick with a 380 can though...the BB can raises the COG...which is a bad thing.
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    I was wondering if this motor Would be a better replacement for the stock.
    VXL-3m traxxas brushless
    http://www.amazon.com/gp/aw/d/B002AV...&pi=SX200_QL40
    Alma, Michigan
    12,314
    The power up program has ended up being more expensive in the long run due to chop shops like Dollar Hobbyz. It is hard to beat a motor for $30: http://www.dollarhobbyz.com/traxxas-...ess-motor.html especially when the ESC in the combo is not that desirable.
    Don't forget you will need a different motor mount, plate, and gear cover for the smaller motor:
    7077 Gear cover/Hardware
    7090 Motor Plate
    7060 Motor Mount
    The stock brushless V380 is the motor we have been discussing... the ESC is something I would pass on though.
    Dec 2013
    Philadelphia
    61
    [QUOTE=Jimmie Neutron;5623000]The power up program has ended up being more expensive in the long run due to chop shops like Dollar Hobbyz. It is hard to beat a motor for $30: http://www.dollarhobbyz.com/traxxas-...ess-motor.html especially when the ESC in the combo is not that desirable.
    7090 Motor Plate
    7060 Motor Mount
    The stock brushless V380 is the motor we have been discussing... the ESC is something I would pass on though.[/QLUOTE]
    I should get a heat sink too right?
    Alma, Michigan
    12,314
    Yes... just don't install it until you have it geared so it does not overheat.
    Heat sinks and fans are meant to bring an already properly geared system down in temps so it will last longer... not to solve heat issues. Gearing is supposed to be used to solve heat issues.
    Dec 2013
    Philadelphia
    61
    Would that castle ESC SV3 fit being through its a 1:10 or is their one for 1:16?
    Alma, Michigan
    12,314
    There is no 16th specific ESC... other than stock.
    The SV3 fits fine on its side right where the stock ESC is located.
    SE Texas
    1,202
    you just have to trim a notch in the rail for the stock esc so the s3 will sit flat on the chassis
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    Ok im going to go with the 380 BL and the ESC SV3 with a LiPo 2cell. Sounds like a fun project... Later on down the line I'm going to shoot for the stars and spend that 170$ ;-)
    Dec 2013
    Philadelphia
    61
    Wanted to know if two 2cell batteries can be installed to that 380?
    Alma, Michigan
    12,314
    2 cells can be used with the 380, yes.
    Some have even used 4 cells for speed runs.
    Dec 2013
    Philadelphia
    61
    I was asking if two batteries can be hooked up at once with a connector wire harness?
    Alma, Michigan
    12,314
    Ah, gotcha.
    Yes... in parallel.
    With that question, the ESC is more of the limiting factor than the motor... the motor can handle up to 4S sparingly, which is twin 2S packs in series, but the stock 3M ESC cannot. Even the SV3 cannot handle 4S voltage.
    Dec 2013
    Philadelphia
    61
    How about one 3s wit that SV3?
    Alma, Michigan
    12,314
    You can use two 3S if you wish... in parallel. As a matter of fact I suggest running all batteries in parallel in the 16ths.
    Aug 2012
    Toronto
    414
    If your after speed and deciding to use 4s after, I'd spend the extra money on a mmax pro.
    Especially spending $170 on a neu motor.
    Dec 2013
    Philadelphia
    61
    Is their any hot body Shells that fit?? Share link if so
    SE Texas
    1,202
    Basically what I've found are...
    Traxxas Rally
    Traxxas Fiesta
    Traxxas Boss 302
    Traxxas Camping World Toyota Truck
    Proline Protoform Rally
    Proline 2011 Camaro GS
    In my opinion...IF you can find one...it's hard to beat the Ken Block Gymkhana Fiesta...
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    SE Texas
    1,202
    That's the Proline Protoform.
    It's pretty sweet...and the Traxxas Fiesta rear wing fits it perfectly.They designed it to use that wing.
    http://racepf.com/mini-micro/tornado...ss-clear-body/
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    Quote Originally Posted by dcfox View Post
    I like this body right here.... Looks real sporty! But im not too big on the stickers. Maybe a couple.. But im looking to spray my shell and cleat coat... any suggestions?
    Alma, Michigan
    12,314
    These shells get painted from the inside... the shell itself is the clear coat.
    SE Texas
    1,202
    Yep...basic spray painting skills and proper sticker placement can even make a beginner look like he knows what he's doing.
    This was the very first rc body that I ever painted...
    R.I.P Paul Walker
    Dec 2013
    Philadelphia
    61
    Nice! What size are the wheels?
    Dec 2013
    Philadelphia
    61
    Show me your fiesta
    SE Texas
    1,202
    Those are cheap Integy 1/10 tires and wheels.
    If you look further up... The same wheels are on my Ken Block car in that pic.
    I also have a brushed Fiesta body... But it's just dark red with the factory stickers removed and a bunch of other stickers stuck all over it.lol
    R.I.P Paul Walker
    Alma, Michigan
    12,314
    Show me your fiesta
    I don't have one.
    I sold my 16ths a while back... just too small for where I run.
  33. #33
    Dec 2013
    Philadelphia
    61
    Lol i seen them on the Ken Block.. but I think they look better on the Mustang... Show me the brush body
    So 1/10wheels fit perfect?
    I don't have one.
    So what's your toy now
    Im shooting for the Traxxas xo-1 around income tax time lol.... that's three feet of fun ;-)
  34. #34
    Alma, Michigan
    12,314
    One for slow and one for go...
    10th scale Summit - Custom 8 channel pistol grip radio, custom wiring, DeWALT powered, twin 2S batteries.
    8th scale MT4G3 - MM2/2200 powered, single 5S battery, custom body mounts, custom ESC mount, custom wiring.
  35. #35
    Dec 2013
    Philadelphia
    61
    Any pics or vids?
    Edited for language abuse. If you see a starred out word in your post, you must edit it out to avoid earning warning points.
  36. #36
    Alma, Michigan
    12,314
  37. #37
    SE Texas
    1,202
    Yes...1/10 tires/wheels fit just fine.
    R.I.P Paul Walker
  38. #38
    Dec 2013
    Philadelphia
    61
    Well i just order my Ford Fiesta should be here by the middle of next week... I brought some treats to come with her ;-) thanks to 5the tips i should make out good.. But we just got hit with 8" of snow so i gotta wait to have real fun... I'll keep u posted
  39. #39
    Dec 2013
    Philadelphia
    61
    7090 Motor Plate
    7060 Motor Mount
    I want to know when it comes to pinion gears for this motor can a 12T mini 8 fit right on??
  40. #40
    Jan 2014
    Hey guys. I have a stock brushed Ford Fiesta that I run on qty 2 Traxxas niMh (stock batteries) and of course, using the Traxxas parallel connector. I wanted to have more drifting action so I added a strip of electrical tape on the wheels. After 5 minutes of play, the car stopped, ESC was no longer responding and emited smoke, and my steering servo stopped working and now shows a curious hole in its side as if something punctured it from the inside-out. Can anyone tell me what happened ?
