Results 1 to 16 of 16
Thread: axle help
    Dec 2013
    201
    axle help
    I broke my rear left axle on my summit and don't know what to do. It is the inside part of the axle that connects to the car itself not the tire. I have the axle from the 1/16 grave digger and I dont know hot to take out the little ball thats connected to the car. Any help would be great.... thanks
    Alma, Michigan
    12,314
    Here is a link for the 1/10 scale Summit:
    http://traxxas.com/forums/showthread...le-replacement
    The 16th is similar, so it should help.
    Keep in mind you are going to be replacing the entire axle if you want to switch out to the GD axle.
    RC Champion dcfox's Avatar
    SE Texas
    1,202
    You should be able to use a grave digger inner with the summit outer.
    The grave digger axles are the same as the revo axles.
    I've had hybrid revo/summit axles on my Summit many times.
    Oh...and to remove that inner from your bulkhead...you need to remove the tiny pin using a tiny hex wrench.(same one you'll use to install the new axle shaft)
    "Dude,I almost had you"
    R.I.P Paul Walker
    Dec 2013
    201
    I fixed it but now I hit a jump and the positive wire came un connected from the esc battery connector and I dont know how to put it back in
    SE Texas
    1,202
    did the whole tab come out of the plastic connector...or did the wire come loose from the metal tab?
    R.I.P Paul Walker
    Dec 2013
    201
    The wire came out of the plastic part that came out of the battery. It looks like you can slip it back on but I wasn't able to get it
    SE Texas
    1,202
    it should snap back in...but it's tight. Make sure you don't have it upside down or it will never go back in
    R.I.P Paul Walker
    Dec 2013
    201
    Ok thanks ill try
    Dec 2013
    201
    It goes in but will not stay.... here is a pic of the problem.
    Dec 2013
    201
    <a href="http://s999.photobucket.com/user/kyleurbann/media/Mobile%20Uploads/1387668920682_zps2b98ceb5.jpg.html" target="_blank"><img src="http://i999.photobucket.com/albums/af113/kyleurbann/Mobile%20Uploads/1387668920682_zps2b98ceb5.jpg" border="0" alt="summit problem photo 1387668920682_zps2b98ceb5.jpg"/></a
    Dec 2013
    201
    Sorry the picture didnt work
    SE Texas
    1,202
    ok...your soldered joint broke loose.
    That pin will have to be pulled out...and have the wire soldered back onto it.
    The the pin can be pushed back into the connector.
    Your LHS should be able to help you out with that.
    R.I.P Paul Walker
    Dec 2013
    201
    What pin? And what is soldering?
    Alma, Michigan
    12,314
    Maybe this will help with the picture issue:
    First, the picture needs to be uploaded to a web host; like photobucket, flicker, or even a locked folder on facebook (like I do). Then after it is uploaded; you view the picture online, right click, and select "copy image location". At this point you come back to the forum and select the third icon from the right; the one that says "image" when you hover over it, and paste your image location into the box in the popup, then click "ok". Then the picture will be shown like this:
    More information:
    http://traxxas.com/forums/showthread...sting-Tutorial
    SE Texas
    1,202
    Quote Originally Posted by Summit to the limit View Post
    The pin is the metal plate that's inside of the connector.
    Soldering is the method that attaches that wire to the plate.
    Definitely take it to a hobby shop. They will know what to do to fix it.
    And just for the topic...here's your pic...
    R.I.P Paul Walker
    Dec 2013
    201
    Thanks for your help.... ill try and find a local one
