Results 1 to 2 of 2
    Oct 2013
    Question Upgrading a Smartech Speedy Car to trx .15 pro
    Hello all,
    I am new to the RC hobby. Bought a rustler VXL about 2 months ago and totally love the Traxxas brand now. I recently found an old Smartech Speedy car which is a 1:10 Nitro buggy laying waste in a friend's backyard. Was totally surprised that is actually works. All I had to do was buy a new remote for it.
    Anyway, my question is that will the TRX .15 engine fit on this buggy? Although there seems to be nothing wrong with the current engine, I dint mind upgrading it if it'll perform better. I could even just order it and keep it on the side until the current one goes bad.
    I have no idea about Nitro RCs at all so would much appreciate some advice and anything else I can do to upgrade it. Below are the specs for the car:
    Specifications
    Item NO.: UW1005396
    Description:1:10 RC Smartech Speedy Tiger RTR Nitro Car
    hot rc nitro car 1:10
    1:10 Off-road nitro rc c
    Item NO.: UW1005396
    Description: 1:10 RC Smartech Speedy Tiger RTR Nitro Car
    Pack: C/B
    Specification: 41.0024.5016.80 CM
    Measurement: 59.0030.5070.50 CM
    Q'ty/Ctn: 3PCS/CTN
    Measurement: 0.127 CBM/4.48CUFT
    G.W/N.W. 14.50/12.60(KGS)
    (15 power engine)
    Features
    Semi-assembled chassis.
    Powerful 15CXP engine equipped with slide carburetor and pull-starter.
    Original muffler and air filter.
    Four wheel drive system with shaft drive.
    Differential with built-in front and rear bevel gears.
    Double wishbone suspension arms with adjustable width.
    Oil filled dampers.
    Stiff and sturdy aluminium chassis.
    Disc brake system.
    All spare parts are compatible with Smartech Winner Sports Buggy.
    Specifications
    Length: :400 mm
    Width :245mm
    Wheelbase :270 mm
    Track (F/R) :245mm
    Tyres size (F/R) :88 mm
    Low speed Gear Ratio :5.78:1
    High-speed Gear Ratio :8.24:1
    Weight :2000 g
    Engine :15 CXP
    Colour Availability :Yellow & Green
    12,016
    Best to contact the manufacturer of the car to determine what can/cannot fit. With enough money anything can fit and it may be in your benefit to take a look at the specs of the TRX .15 to determine if it meets your needs.
