Results 1 to 15 of 15
    Apr 2013
    368
    Water Coming in thru stuffing tube?
    Does anybody have a fix for this? Installed a wire drive on both of my spartans and both have water coming up the stuffing tube.
    Please help!
    RC Qualifier PowerDemon's Avatar
    Jun 2011
    Fredericksburg, VA
    401
    Do you have the teflon liner installed and is there any visible wear or dry rot on the transom gasket?
    37 Fightercat Shocker
    Traxxas Spartan
    Apr 2013
    368
    yup on the liner.
    I just replaced the rear grommet because I thought It was coming thru there
    Jun 2011
    965
    You shouldn't have water coming in up the stuffing tube.
    The motor end is higher than the water level, so no water should enter when stationary.
    While in motion, as the boat skims across the water, it should create a venturi action (low pressure) at the rear of the stuffing tube, and should, if anything, draw air/water/grease out the rear of the tube.
    If you in fact have water coming in up the tube, I'm at a loss to offer an explanation.
    I had water coming in and couldn't figure out where for a bit, then determined my "larger diameter" cooling lines were leaking at some of the fittings. I put zip ties on each connection and the leaking stopped.
    At 40/50+ mph there is a reasonable amount of back pressure created in the cooling system and connections that may seem tight enough, may not be.
    hog
    Apr 2013
    368
    i have zipties on every fitting....I can physically see it dripping out of the stuffing tube when the boats just beached in the lake. I have like 1-2 CUPS of water after each run on both of my spartans
    Jun 2011
    965
    That's odd, I run a wire drive in one Spartan, and no issues.
    Are you running large, heavy batteries that would cause the boat to sit low enough in the water that the drive end of the stuffing tube would be below the waterline?
    Even if this were the case, I can't explain the amount of water you are getting because it definitely shouldn't be coming in while the boat is moving.
    Have you checked to be sure the seam between the top deck and hull is intact all around? i.e. there may be a second source of entry.
    hog
    Jun 2011
    Fredericksburg, VA
    401
    Or have you moved the stuffing tube back in the boat by readjusting it with the two hex screws?
    Traxxas Spartan
    Apr 2013
    368
    I havent moved the stuffing tube back... can you even do that? And what would that do?
    Jun 2011
    965
    Quote Originally Posted by Socalirevo View Post
    You can adjust the stuffing tube forward or backward a few mm by loosening the clamp screws on the motor end.
    I have moved mine back once before to give an extra mm or two room for the collet.
    Relative to your situation, I don't think it would be a factor. You can't move it enough to make a difference in the overall rise, resulting in lowering it below the waterline.
    hog
    Jun 2011
    Fredericksburg, VA
    401
    Quote Originally Posted by hog View Post
    hog
    Thats what I had to do I got the KintecRacing .187 flex upgrade and that required a longer collet. And I thought that if you moved it back enough water could get in the stuffing tube by the tube being beneath the water line.
    Traxxas Spartan
    Apr 2005
    Tennessee
    660
    On some instances you can use a small cut off of cooling tubing. Just place it over the stuffing tube and just barely enough sticking out to slip over the flex cable. This will help keep water and grease out.
    Land, Sea & Air, A true RC Addict
    Sep 2013
    5
    Socalirevo
    Did you ever resolve the problem with the stuffing tube leak? I'm also having that problem but in my case the water is creeping up between the stuffing tube and the brass tube. I set my Spartan in the bath tub with batteries and observed water dripping at the collet end and it indeed was dripping between the two tubes. I've loaded crease it with crease to create a seal but no luck.
    Jul 2013
    576
    get some thicker marine grease?
    PM for info.....
    Apr 2013
    368
    nope never fixed em
    Apr 2013
    368
    finally got around to fixing the leak. As mentioned above little pieces of cooling hose cut and placed between the collet and stuffing tube and between the strut and hull. Had it in the bath tub for about 20-25 min and not a drop.
