Results 1 to 12 of 12
Thread: Pull start 3.3
    Nov 2013
    12
    Pull start 3.3
    Just bought a slayer with the 2.5. The engine is getting weak so I was thinking about doing a 3.3 upgrade. Are the pull starts worth the extra money or is it a waste? Thanks
    Nov 2013
    12
    Does anyone have any input on pull starts?
    Gurley, Alabama
    794
    I like a pull start, simple and easy. But if your new to tuning, I wouldn't recommend it.
    Nov 2013
    12
    Why does pull start make a difference with tuning?
    Traxxas Employee TireSlinger's Avatar
    Sep 2010
    575
    If you're not experienced at tuning the engine is likely to stall a lot and/or be difficult to start. It really has no direct impact on tuning. I've seen times when an engine is being difficult that people walk away with blisters from the pull starter. (Some sort of glove helps.)
    Typically if an engine is well tuned and in decent shape it will fire after just a couple pulls.
    Nov 2013
    12
    10-4 thanks for the info
    May 2006
    Dayton Nv.
    3,182
    If you get a new engine it will come with a pull start already on it also the slayer never had the 2.5 engine it came with the 3.3 engine stock from the start.
    Nov 2013
    12
    From what I have seen the slayer did originally come with a 3.3. Somewhere in the past someone put the 2.5 in it.
    Gurley, Alabama
    794
    That's unusual, most people want more power not less.
    Nov 2013
    12
    I just put the 3.3 in it and burnt up the spur gear in 15 mins.. Any ideas?
    10,448
    Stripped or melted the middle? Stripped you'll need to make sure the mesh is correct; if it is, take a look at the engine mount to see that it is not broken or the chassis under the engine is not bent. If melted, tighten the slipper up.
    Nov 2013
    12
    Yea its melted.
