    Nov 2013
    8
    Hi,
    I am new to this and have a very weird issue:
    Recently I upgraded the CVDs to steel CVDs (TRX7151X) and found out afterwards that I put the diffs too tight, so I loosen up them a bit and then they would hardly turn once it would be attached to the driveshaft. So I put it all apart and tighten the diffs just a bit, removed the dirt and still have the same issue.
    Even weirder, the wheels turn fine if the front and the back are removed from the chassis. Then I thought that maybe it would be the transmission that would be the problem, but when the front and back are removed, the driveshaft runs smoothly.
    When I put it all back together, the wheels and the driveshaft don't run smoothly.
    Do you guys have any ideas why this is happening?
    Thanks
    Also Im wondering, should the wheels be moving smoothly if only the front or the back is attached to the e revo?
    Alma, Michigan
    12,311
    It is a 4WD RC... all the wheels are attached to one another so there is going to be resistance.
    Also, if the differential is not assembled correctly it will bind up and not function very well. I have done this a few times during diff fluid changes on mine... I found the best way for me was to slowly tighten down two of the three screws and spin the differential around when it was getting closer to snug to make sure all three of the little gears are seated into place. Leaving the third screw out for access diff fluid to squirt out before inserting the last screw.
    Nov 2013
    8
    What kind of oil do you use?
    I put some diff-lock silicone oil 30,000 wtg on the teeth outside of the diff... Wonder if that might be the issue.
    Alma, Michigan
    12,311
    I ran 30k/50k/30k in it when it handled best. I also had a center differential installed.
    I also ran the ring and pinion dry. The bulkhead is not sealed so grease/oil + dirt = sandpaper like goo that wears parts FAST.
    I would not consider 30K to be anywhere near diff-lock thickness. I run 500K in my MT4 center and it is not locked up!
    Nov 2013
    8
    Thanks, it turned out the front diff was in the opposite direction
    Jul 2012
    Yakima, Washington
    1,439
    Ya been there done that.
    Sep 2011
    Iowa City, Iowa, USA
    2,395
    There is a screw that holds the bottom part of the rear bumper in. If you screw it in too far it grinds agenst the rear diff ring. I believe it is the one on the left side. Try backing it out a bit.
    lipo power!!!!!
    60% of the time I'm right every time.
    Aug 2012
    Riverton, Utah
    228
    Yes, try that. I was having the exact same problem. Backing the screw out just a little fixed it
    Sent from my iPod touch using Tapatalk
    MERV, Broken Alias.
