Results 1 to 10 of 10
    May 2013
    Concord,NH
    70
    p4de rear wheels have no power?
    so all of the sudden when i drive my stammy, the back wheels have no power. but if i hold it in the air it is 4x4 again... wth lol is it a diff problem? help plz!
    RC Champion No One's Avatar
    May 2005
    Minnesota
    1,177
    Check the hexes on the back wheels and see if one is stripped.
    Sent from my SCH-I545 using Tapatalk
    Slash 4x4
    Stampede 4x4
    South of St Louis
    6,310
    So the fronts run normally, but the rears don't have power? Sounds like the differential ran out of grease.
    May 2013
    Concord,NH
    70
    I just remembered, about a month ago, when i was still a noob to the hobby, i cleaned of my p4de and washed out the diffs... i wonder if that has something to do with it :3 what grease should i run?
    Wales in the UK
    6,462
    Any good diff grease will do but I would put money on the rear hexes stripped out...........peace
    May 2013
    Concord,NH
    70
    turns out the grubscrew that holds the center drive shaft to the slipper assemblie came loose! time for some locktite
    Wales in the UK
    6,462
    Dude I am glad it was just the grub and not your wheel hex.......peace
    May 2013
    Erie, PA
    719
    Quote Originally Posted by waya7 View Post
    ??? When you say you washed out the diffs, do you mean that you took apart the diff housing, took off the ring gear, and cleaned out the diff cup? or just pulled out the whole diff and cleaned out the housing. Because if you took apart the whole diff and washed it out and did put and fluid back in you will wear your gears out in no time. Fill the rear diff cup with 30k oil and some of your favorite grease on the ring gear.
    And I may be wrong but if your grub screw on the drive hub came loose, I would think that you would loose power to the front and not the back. Wouldn't the slipper assembly still spin allowing power to the back only via slipper shaft into the rear ring diff assembly. The drive hub would be stationary (cuz the grub screw is loose) while the slipper shaft is turning not allowing the drive shaft to turn the front wheels. If I am wrong someone please correct me.
    The message above or below may or may not be true
    May 2013
    Concord,NH
    70
    turns out it was the grub screw AND the rears are striped lol and all i cleaned out was the diff housing i never opened the gears
    Wales in the UK
    6,462
    Dude that's not cool but hope you get back up and running soon........peace
