    Aug 2012
    Warner Robins, Georgia
    1,761
    Using EZ Peak Plus with dual Lipo charger adapter.
    OK I've searched here and read the instructions for both the charger and the adapter (tra 2917) but did not see what I was looking for.
    1. When I want to charge and/or discharge my two 2s 5000mah batteries do I put the charger on 4s?
    2. Also will the charger do a storage charge at the same time?
    RC Champion trax de max's Avatar
    1,895
    1) It makes the two 2s packs into one 4s.
    2) it'll storage as a 4s using the adaptor.
    Clicky instructions.
    You may not get 5A for the charge though. I forgot what the chargers power ratings are.
    Google search trumps Wiki. Refer to user guide.
    Aug 2012
    1,761
    So would I still charge at 5 amps because they are 5000mah?
    Alma, Michigan
    12,316
    Yes. Series charging does nothing to capacity, only voltage changes.
    Aug 2012
    1,761
    Ok, and when doing a storage charge I can do both on the 2 amps? It will probably take forever though won't it lol
    Aug 2012
    1,761
    The charger only charges at 5 amps. Which is perfect for my 5000mah batteries but what if I had a 5400, 6200 or even an 8200 mah battery. Would I still just put it on 5 amps and it just take longer to charge or is that not enough to charge a bigger battery like that?
    Hope that makes sense.
    Alma, Michigan
    12,316
    It would just take longer.
    Aug 2012
    1,761
    Thanks Jimmie. That's what I figured but wanted to make sure.
