Results 1 to 2 of 2
    148
    Can I use docking base & telemetry with a castle esc and motor
    I am thinking of getting a castle motor and esc for my new stampede 4 x 4 build. I have a tqi with docking Can i use it with the castle motor? Will Telemetry work?
    Jul 2013
    Anchorage, Ak.
    24
    Yes. The telemetry will work fine. The only thing the telemetry needs to work properly that is from Traxxas (aside from the sensors.) is the receiver and transmitter with dock and ipod/iphone. The temp sensor mounts to whatever motor you want as long as the zip tie that holds the mount is long enough. The voltage sensor is attached to the battery side of the ESC by either the adapter if you use Traxxas connectors or soldered to the Positive ESC wire from the battery if using other types of connectors.
    Time to run the Rustler
