Thread: Hm that's odd
    May 2013
    Ohio
    477
    Hm that's odd
    Okay, I was charging my 2s lipo on my EZ-Peak Plus charger. I had to go somewhere so I stopped the charging process and unpluged the charger. When I came back I started back up again and went to work on stuff at my desk.
    I went to check on it and I noticed that both cells were at 4.2 volts, but the charger was still charging the pack at 4 amps. I thought the charger will stop charging the cells when they were at 4.2 v or cut back on the amps when it reached it peak. I stopped it since it was a full charge but I thought the charger will stop charging it when the pack was full.
    Did you say Traxxas?
    Yes with or without lipos.
    16,883
    Were you performing a full 6-Amp charge or did you start at 4 Amps?
    Alt-248 on the number pad =
    May 2013
    Ohio
    477
    I had at 4 amps since the lipo is 4000 mah. Double checked everything before I started charging it. Had it charged for 5 or 10 minutes before I turned the charger off to leave my house.
    16,883
    For how long did you witness it at 4 amps and 4.20V/cell?
    May 2013
    Ohio
    477
    Not that long like less than a minute before I turned it off not taking a chance to start a fire.
