    Oct 2013
    3
    VXL-3M ESC light not on but unit is, no movement
    Hello, I just purchased the Summit VXL and have been running it hard for only two days. Car was running awesome, changed the battery and the green light on the ESC is not coming on, there is no movement with the drivetrain but the steering works. All the wires are in place, nothing looks cut or frayed or cracked or anything. The battery was just charged and I recharged another one and tried that just to be sure. No change. Also I can't turn the unit off, which I was able to do by holding down the EZ Set power button again for a second.
    Thanks for the help in advance! I want to get it running again I just got it, this thing is wicked fun!!!! Boo if I have to spend $50 bucks plus shipping and have to wait forever to get it back.
    Jul 2012
    Yakima, Washington
    1,440
    Well to start with Traxxas wants you to turn off your esc by unplugging the battery. Is the esc showing a red light or no light?
    Alma, Michigan
    12,318
    Try unplugging your servo... I have seen dozens of "working" servos cause all kinds of electrical havoc.
    Oct 2013
    3
    Thanks for the responses. I am new at this so I actually had to read up on the components to figure out what servo you were referring to.
    The ESC is showing no light. Unplugging the servo from channel 1 didn't do anything. I was doing that on the phone with support at Traxxas, who recommended sending in the ESC.
    I'm actually having two issues. Besides the ESC not having a light and no movement with the drivetrain, when turning left the wheels stick and click while trying to move back. Just happened to start occuring at the exact same time.
    After another conversation on the phone with Traxxas they suggested sending in the whole car (not the body or wheels) because it sounds like that servo gear is potentially busted as well. They'll most likely honor the broken parts because its so new and this way I'll no for sure if the $100 ESC is broken or not.
    First I think I'll see what the local shop thinks too. Can't hurt and I'm so new at this might as well before sending it away from Canada for like two months
    Oct 2013
    3
    Thanks again for the responses. I confirmed the ESC was dead before sending it away to Traxxas. The issue with the steering servo was a few teeth busted off the crappy stock gears inside.
