Results 1 to 13 of 13
    Aug 2013
    36
    Bogging? Reving & more!
    Is not going into second gear is a high speed problem? To lean?
    Also, when pinching the fuel line and it revs up for 9 seconds mean its too rich?
    And sill no wheelies
    Riverton Utah
    5,476
    It could be too lean, but it could be too rich also. Is there a thick smoke trail?
    Is owning 25 RC's too many?... Nope!
    Aug 2013
    36
    It's more darker than light but I wouldnt say its thick... & that is for which needle?
    Riverton Utah
    5,476
    It's when it's at full throttle... If it's not shifting into 2nd gear, and there is a thick smoke trail, try leaning out the hsn. Also, yes, it sounds like your lsn is too rich.
    Aug 2013
    36
    Which needle is related with wheelies?
    or is it a combination of both?
    Riverton Utah
    5,476
    It's really mostly about the lsn, but it can be both.
    Aug 2013
    36
    So a rich lsn will cause the engine to rev up and rev longer when shutting off the engine n also limit torque when going for wheelies?
    Riverton Utah
    5,476
    Yep, and yes.
    Aug 2013
    36
    Thanks! Do I tune while running or can I tune when its off?
    Jun 2013
    Clanton, AL
    71
    Quote Originally Posted by ApolloDPC3 View Post
    Running and in 1/8 turn increments with a test in between adjustments.
    Aug 2013
    36
    Thanks! This site is the bomb diggity lol
    Toronto
    196
    Read the owners manual! You can get it off of the traxxas site in the support section. Best thing to do at this point is putting your needles back to factory settings and re tune.
    Jato 3.3 Pede 2.5R Rusty 3.3
    Oct 2013
    6
    Quote Originally Posted by StixXxJaTo88 View Post
    +1, sounds like your tune is way off. I would revert it all back to stock (4 turns out from closed with the HSN, and the LSN sitting flush with the inner bezel, and idle gap in carb should be around a 1mm gap.), and re-tune. Once the HSN needle is dialed in, and you get the LSN tuned properly, it'll be wheelies on demand!
