Page 2 of 17 FirstFirst 123412 ... LastLast
Results 41 to 80 of 659
  1. #41
    Alma, Michigan
    12,314
    Quote Originally Posted by malonefamily2003 View Post
    That's news to me but a washer might work if not I will just get rid of the servo saver. Not a big fan of them at slow speeds anyway
    My 402in/oz servo maxes out the saver even with washers... just a heads up. One less issue to trouble shoot yourself with those monster servos and tires in there.
  2. #42
    Sep 2013
    Maysville,Ky. USA
    779
    Quote Originally Posted by reod12x2 View Post
    the servo's that im talking about are the hitec hs-7980th .maxed out on 7.4v they can do 611-oz/in
    but at about $200 a pop. i couldnt see haveing 220-oz/in extra over the savox servo's
    I will stick with the Savox and put the extra 250 bucks into some other parts
  3. #43
    Sep 2013
    Maysville,Ky. USA
    779
    Anyone know of a good heavy duty slipper clutch for the Summit?
  4. #44
    Alma, Michigan
    12,314
    Tmaxx brake disc... KSB uses one I believe.
  5. #45
    19,295
    I've modified a few machines to use the brake disc.
    T-Maxx brake disc, p/n 4964
    Modification to parts consists of:
    • widening (toward the outside edge) every other pair of the holes in the disc; and
    • shaving the inside of the gear cover to clear the slipper assembly since it is now slightly wider due to the brake disk being wider than the slipper pads.
    I've got an awful lot of use on these discs, both with ERBEs and Summits and wear is negligible. However, the "sweet spot" for the slipper adjustment seems a lot bigger.
    Alt-248 on the number pad =
  6. #46
    Oct 2010
    Parsippany, NJ
    752
    I have the Hitech 79?? (forget exact model but I think it's the 7950), just over 300oz/in. I feel like it was a bit sluggish with the slingers when crawling.
  7. #47
    Alma, Michigan
    12,314
    Have you put any washers in the servo saver?
  8. #48
    Sep 2013
    Maysville,Ky. USA
    779
    Not yet but i am still running stock tires and everything seems to work fine. When the big tires go on i have a few ideals to test . Maybe adding a smaller spring or some hard rubber in the center of the servo saver spring ,finding a bigger spring at the nearest auto parts store , or just replacing the spring with a thick aluminum spacer if all else fails.
  9. #49
    Alma, Michigan
    12,314
    That was directed toward Mr Hammer... his steering will probably feel sluggish if he hasn't tightened up that servo saver.
    With the spring being cone shaped, I have not even tried a standard straight spring... it would be interesting to see if a straight one will work or not. That would open up quite a few options if it will!
  10. #50
    Jun 2010
    New Hampshire
    341
    A newb question here...what is the washer mod and what does it do? Sorry to inturupt
    "Duct tape and superglue are my spareparts"
  11. #51
    Sep 2010
    59
    Nice Raptor body...been looking for one of those...not sure if the toy is d/c-ed by the manufacturer, but it looks great on a summit may work well for a slash crawler project, too..
  12. #52
    Oct 2010
    Parsippany, NJ
    752
    Jimmie,
    Never tried fussing with the servo saver as I have no experience doing so. It's on my to do list for the weekend. Will post results ASAP. Thanks for suggestion!
  13. #53
    Alma, Michigan
    12,314
    Quote Originally Posted by slashbasher24 View Post
    Adding a washer to compress the spring in the servo saver to tighten it up so as to make it harder for it to give which directs more power into turning rather than the flex of the saver.
    I have a body washer in mine.
  14. #54
    Sep 2013
    Maysville,Ky. USA
    779
    Does anyone know if the Integy gear box/transmission for the Erevo will work on the Summit? From the one and only pic of it i cant tell if it has the Hi/Low shifter .It looks as though the stock Traxxas Erevo and Summit trans are the same but on the Erevo trans they just put a blue plug in the hole where the shift rod should go. I'm just wondering if Integy machined the hole for the shift rod or if they just totally left it out.
  15. #55
    19,295
    The Integy description is specific to the E-Revo. That's strike one. The product is Integy. That's strike two and three.
  16. #56
    Sep 2013
    Maysville,Ky. USA
    779
    Guessing someone is not a fan of Integy. I haven't tried their stuff but it looks nice
  17. #57
    Sep 2009
    Victoria B.C Canada
    5,426
    He is not alone in that feeling.lol
    Sent using lipo power
    Mountains cant stop me
    they have tried
  18. #58
    Alma, Michigan
    12,314
    Really not alone... looks nice is all they do. Their parts are great for shelf queens though!
    They are not true billet machined aluminum parts... they are cast and then machined. The casting process allows pockets of air to exist throughout the aluminum making it quite weak.
  19. #59
    19,295
    Huge Traxxas Summit OVERKILL
    Yes, their looks are great. There - I said something nice.
  20. #60
    Sep 2013
    Maysville,Ky. USA
    779
    Wow 3 out of 3 not looking good for Integy. Does anyone make an aluminum trans for the Summit that's not junk?
  21. #61
    Apr 2013
    Ontario, Canada
    778
    Ive never had issues with my stock ones, Is the upgrade purely cosmetic?
  22. #62
    Sep 2013
    Maysville,Ky. USA
    779
    Really just want something stronger but something shinny helps to
  23. #63
    Sep 2013
    Maysville,Ky. USA
    779
    I did some more work on my axle shafts [IMG][/IMG]Stock long shaft in front with improved shaft behind it.[IMG][/IMG]Looks good as new installed[IMG][/IMG]
  24. #64
    Sep 2013
    Maysville,Ky. USA
    779
    Got started on another body[IMG][/IMG]
    Put some chains on just for S&G
  25. #65
    Sep 2013
    Maysville,Ky. USA
    779
    Made some dual rate springs to help with the extra weight. I just chopped about 3/4 of an inch off each end of a silver rated spring and soldered that onto some blue rated springs
  26. #66
    Sep 2013
    Maysville,Ky. USA
    779
    Decided to go with a Hot Racing slipper clutch. Its got 1 large clutch pad instead of several small ones. If it starts slipping too much i think it will be easier to make just 1 aluminum clutch pad.[IMG][/IMG] Had to shave down the ends on the 3 screws that hold it to the spur gear [IMG][/IMG]
  27. #67
    Sep 2013
    Maysville,Ky. USA
    779
    Does anyone make an extended aluminum chassis for the Summit? Only need it to be 2 inches longer to fit the big bodies.
  28. #68
    Newcastle, Australia
    969
    Kershaw Designs makes a 5T conversion for the E-Revo which is the same chassis? Don't know if it would be too much of an extension though..
    Check this out: http://kershawdesigns.com/E-Revo-5TConversion.htm
  29. #69
    Sep 2013
    Maysville,Ky. USA
    779
    That one is gonna be to long at around 22 inch wheel base. The stock Summit is around 15 inches so I need one around 17 inches for these bodies which I believe are 1/6 scale.
  30. #70
    Apr 2013
    Ontario, Canada
    778
    That HR Slipper looks nice....
  31. #71
    Sep 2013
    Maysville,Ky. USA
    779
    Just hope it can handle the CC 2028 motor on 8s.
  32. #72
    Apr 2013
    Ontario, Canada
    778
    it will probably need to be pretty tight.
  33. #73
    Sep 2013
    Maysville,Ky. USA
    779
    The heart of the Beast [IMG][/IMG][IMG][/IMG]
  34. #74
    Oct 2012
    Canmore, AB
    330
    Oh my lord!
    Working hard to appear reasonably sane.
  35. #75
    Sep 2013
    Maysville,Ky. USA
    779
    Getting pretty close to having the Summit stage 1 up and running. Received my motor mount and several goodies today from L.E.M [IMG][/IMG]
    The only thing left is a good pinion the 1 on it now is to small and wont contact the spur. [IMG][/IMG] [IMG][/IMG]
    [IMG][/IMG] [IMG][/IMG] I know the wiring looks like crap but not a lot of room left to hide it all . Had to add a few y-harnesses and several extensions to get everything where i wanted it.
  36. #76
    Sep 2013
    Maysville,Ky. USA
    779
    Does anyone know of a rear motor mount for the CC 2028 that will work on the Summit. This motor is so long and heavy its gonna need a rear mount . I looked at a few pics on here of a rear motor mount for the smaller 1717 motor but nothing for this monster.
  37. #77
    969
    You might have to look into making your own if you're good in that department
  38. #78
    Alma, Michigan
    12,314
    I doubt it... not for how much motor he has. Front and rear mounts are going to be the most secure.
  39. #79
    Sep 2013
    Maysville,Ky. USA
    779
    So i got tired of waiting on the pinion gear so against my better judgement I rigged this cracked pinion to test run for a few minutes. I used the CC field link to turn the power down and tightened the slipper up all the way. Well lets just say the clutch has no chance at full power. It all lasted about 5 min until the pinion came flying off. So back to the waiting game.
  40. #80
    Sep 2013
    Maysville,Ky. USA
    779
    I saw that motor mount just a few days ago it looks much stronger then mine but not sure if my motor has the same bolt pattern as the 1717. After getting my motor mounted i noticed i only had about 2mm clearance between the motor and shock mount bolts . I cut some hard plastic and used liquid gasket to hold it to the bolt heads . Later i plan to place a thin piece of weather stripping on top of that so the motor has some cushion but doesn't move to much.
