    206
    Integy metal spur
    Ive stripped 2 spurs in the past week and im not sure about getting the metal spur
    Sent from my iPhone using Tapatalk - now Free
    So Cal
    561
    sounds like your mesh not adjusted properly - This just does not happen under normal conditions is set up properly.
    There are lots of ways to do that. Most are wrong.
    Riverton Utah
    5,391
    Not worth the money, even if it wasn't from Integy.
    http://traxxas.com/forums/showthread...etal+spur+gear
    Is owning 25 RC's too many?... Nope!
    206
    Thanks for the info, much appreciated
    89
    Ive been using metal spurs for about a month and couldnt be happier. Ive stripped 4 plastic ones. First one was using my LiPo the 2nd time. The mesh was factory set. 2nd time was i did a jump, and landed nose hard, and my pinion came loose and stripped my spur. 3rd and 4th time were from doing wheelies. I did 2 full battery runs each time before I did wheelies. The mesh was done with the paper method. But when I meshed with my metal spur and pinion, I didnt use the paper method this time. I tapped toothpick to a dial indicator, and meshed it like that. I put at .0001" I think. Dont remember. Been running like that for about a month and not a problem.
    228
    I go Metal a long time ago. Wont use plastic anymore.
    Gesendet von meinem GT-I9300 mit Tapatalk 2
